headlight relay clicking when ignition switch pressed
mikey909
PostPosted: 14:50 - 19 Sep 2012    Post subject: headlight relay clicking when ignition switch pressed Reply with quote
when i start my bike with the electric ignition, the headlamp relay clicks, and the headlamp indicating light shows up on the clockset. also, the indicators, horn, and the clockset lights do not work. the battery is fully charged, and the earth connections have been check. does anybody know what could be the issue behind all this?
Fizzer Thou
PostPosted: 00:31 - 20 Sep 2012    Post subject: Reply with quote
I am not sure to which bike you are referring to,but on some bikes there is a large multi-pin connector supplying power to and from the headlight/clocks/switchgear.Sometimes one or more of those small male/female pins can become corroded.If you pull apart as many connectors as you can find and spray them with something like GT85 or WD40 then this may well help your situation.
Always have a 'Plan B'
mikey909
PostPosted: 02:09 - 20 Sep 2012    Post subject: Reply with quote
its ok. ive sorted the issue. i think that i had one of the connectors wrong. for the record, the bike (well, scooter), is a gilera dna 125. thanks for your help though.
The last post was made 14 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 35.77 Kb
