bike stalls when going from neutral to first? aprilia rs 125
jordey
PostPosted: 17:58 - 20 Sep 2012    Post subject: bike stalls when going from neutral to first? aprilia rs 125 Reply with quote
okay so it's my new bike - aprilia rs125 (05 plate). it starts fine, doesn't cut out when idling, but when i pull the clutch all the way in and gear up (it's gp gearing) it just cuts out. anyone know why?
matto
PostPosted: 17:59 - 20 Sep 2012    Post subject: Reply with quote
Side stand down, or switch broken would be my first checks.
jordey
PostPosted: 18:06 - 20 Sep 2012    Post subject: Reply with quote
there is no side stand, it sits on a paddock. how would i check a broken switch?
Forky
PostPosted: 18:12 - 20 Sep 2012    Post subject: Reply with quote
Make sure that the clutch is adjusted correctly too buddy
RS 125 "96" Mito 125 "01" GSXR 400 "94" "ZXR 750 "96" "ZX9R "94" CB 250 "06" GSX 600F "96" Virago 535 "94" SV 650 "01" ZX9R "99" SV650 "98" FZR 400 "88" RS 125 "01"
Current ride is a bandit 600 1996 and I Love it Wink
Matt-
PostPosted: 18:16 - 20 Sep 2012    Post subject: Reply with quote
Sure it's that gearing as it's your " New Bike " ?
Maybe Clutch cable has snapped?
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
jordey
PostPosted: 18:27 - 20 Sep 2012    Post subject: Reply with quote
yeah i can go through the gears with the clutch pulled in (when its off). i don't think the clutch cable snapped, as i was able to ride it about 3 metres (was just testing it) then i turned it off, when i tried again, it just cuts out when going into first.
jordey
PostPosted: 18:28 - 20 Sep 2012    Post subject: Reply with quote
how would i adjust it correctly? (sorry of this is a stupid question!)
Casper
PostPosted: 18:31 - 20 Sep 2012    Post subject: Reply with quote
Did it have a side stand and switch as standard? If so you cant just unplug the switch you need to cross the wires over letting the bike think the stand is up.
jordey
PostPosted: 18:35 - 20 Sep 2012    Post subject: Reply with quote
it would of yes, how do i cross the wires over?
jordey
PostPosted: 18:43 - 20 Sep 2012    Post subject: Reply with quote
really weird, i put it back on the paddock stand, tried it again, put it into first and it was fine! kinda confusing me!
Casper
PostPosted: 18:45 - 20 Sep 2012    Post subject: Reply with quote
If the switch/ plunger is still there try and tape the plunger in and start the bike and put in gear. If it works follow the wire back till you find a block connector and pull the two halfs apart. At the wire loom side of the plock stick a bent bit of wire in the two female spade connectors and tape it up.
Forky
Make sure cable is tight at both ends. I.E. not much play in the leaver, and that the arm thats by the clutch cover, is moving too it's full potential. (And is tight no slack in the cable)
Make sure that the cable is taught between these too points, if it is, and your sure that the side stand switch is disabled I would suggest taking the clutch cover off, and inspecting the clutch plates.
Smile
Forky
PostPosted: 18:49 - 20 Sep 2012    Post subject: Reply with quote
Just had a brain wave. If Idle is very low on tick over, sometimes first can be a bit clunky on the rs. This some times will cause a bike too cut out, just a suggestion.
Im off out now so wont be able too help till the morn good luck!
Casper
PostPosted: 19:10 - 20 Sep 2012    Post subject: Reply with quote
Oh and some plungers need to be out so go straight for the block connector.
jordey
PostPosted: 19:56 - 20 Sep 2012    Post subject: Reply with quote
i left the bike for like 10 minutes, went back, and it was all fine.
should i look in to this more or just leave it?
also, the gearing feels a bit weird, don't know if this is because there is a problem or just that it's a different bike.
Noxious89123
PostPosted: 23:48 - 20 Sep 2012    Post subject: Reply with quote
Describe weird. Idea
shereen
PostPosted: 00:01 - 21 Sep 2012    Post subject: Reply with quote
This, had the same issues on the nc30. How far can you let the clutch out before it bites?
jordey
PostPosted: 17:29 - 21 Sep 2012    Post subject: Reply with quote
well i haven't riden it past 1st gear since im not insured on it yet, but when i go through the gears when its on the paddock, with the shifter all the way to the top (its gp style) neutral is a bit hard to get into, then past that, it only feels like theres 2 more gears
jordey
it's about 3/4 let out
The last post was made 14 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 98.54 Kb
