| MattJ |
 MattJ World Chat Champion
| _Iain_ |
 _Iain_ Banned
 Posted: 13:33 - 21 Sep 2012 Post subject: |
generator wired up propperly? ____________________ Please be aware that the above post may be full of complete nonsense.
| MattJ |
| P.addy |
 P.addy Red Rocket
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 13:51 - 21 Sep 2012 Post subject: |
What bike is it? I would suggest checking the valve clearances and/or carry out a compression test. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| MattJ |
| MattJ |
| ZaphodBeeble |
 Posted: 14:01 - 21 Sep 2012 Post subject: |
It WOULD affect it but you wouldn't notice. It would be a loss of power which had developed over years of riding. If all else fails with the electrics then I highly recommend checking it.
Did the bike lose any oil when you stripped it/crashed it? ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| MattJ |
| bikenut |
 bikenut World Chat Champion
| Scotsman37 |
 Scotsman37 World Chat Champion
| GrumpyGuts |
 GrumpyGuts World Chat Champion
 Posted: 17:30 - 21 Sep 2012 Post subject: |
+1 for solenoid.
After refitting the solenoid earth lead, the wire was touching the exhaust thus melting it and shorting the connection. I then had the same problem as you, the bike could bump start but not from the starter button. Every time I tried to start the bike the solenoid would just make a clicking noise, the same noise it was making when my alternator was not working.
I repositioned the lead and insulated the damaged area and it fixed the problem. Starts first time  ____________________ My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012 |
| MattJ |
| Triumph1300 |
 Triumph1300 Nova Slayer
 Posted: 08:59 - 22 Sep 2012 Post subject: |
Could be battery, could be other things, it's almost certainly electrical.
Check the spark whilst cranking, also put your multimeter on the battery whilst cranking, and see what the voltage drops to.
Some CDI's don't like working much below 9/10 volts.
Report back, and we'll go from there ____________________ BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit  |
| ZaphodBeeble |
 Posted: 11:09 - 22 Sep 2012 Post subject: |
Ahh wait a minute. I had a similar problem with a CBR400 NC29. The timing pickup was very slightly too far away from the metal bit that it picks up from after the bike was dropped. Check the gap on the pickup and adjust the gap as tight as possible. I'd put money on it being this.
A bit more info; I believe this happens because the timing pickup is probably a 2 wire reluctor type sensor which requires a piece of ferrous metal to be passed across it for it to produce a current. If the metal is too far away and moving slowly (ie. when using the starter motor) then only a relatively small current will be produced. However, when you bump start it the metal moves at a higher velocity and induces a higher current in the pickup. By moving the pickup closer to the metal it should produce the higher current that the CDI needs to be able to detect a timing signal.
Later machines have a 3 wire 'hall effect' type pickup which is powered by two of the wires (positive and ground) and outputs either an off or on signal on the third wire. They are generally more accurate and reliable. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| MattJ |
| ZaphodBeeble |
 Posted: 15:30 - 24 Sep 2012 Post subject: |
No problem. Glad I could help.  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| kotachi |
 kotachi Traffic Copper
 Posted: 15:37 - 24 Sep 2012 Post subject: |
Awesome shout sir  ____________________ CBT done - 24/03/2012, theory test done - 03/04/2012.. Mod 1 done -26/06/2012, Mod 2 done - 29/06/2012. Current steed: Cage.
Suntan Sid said: "Look at it this way, your employer wants to pay you the minimum amount, it thinks it can get away with, and extract from you the maximum amount of graft. Ergo it's your responsibility to ensure that karma is restored and you do as little work as you think you can get away with, for the maximum amount of money." |
| Walloper |
 Walloper Super Spammer
| ZaphodBeeble |
 Posted: 17:43 - 25 Sep 2012 Post subject: |
I'm off the booze at the moment so that doesn't leave much of a choice...  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| MattJ |
 Posted: 18:20 - 25 Sep 2012 Post subject: |
The last post was made 13 years, 361 days ago. Instead of replying here, would creating a new thread be more useful? |
