Bike won't start
MattJ
PostPosted: 13:32 - 21 Sep 2012    Post subject: Bike won't start Reply with quote
I crashed my bike about a month ago and had a bit of trouble getting a generator cover and fitting it but after I finally got that done the bike wouldn't start.
All the lights come on as they should do and when I press the starter button the engine turns over but just will not fire no matter how long I hold the button for or how wide the throttle is open. However, the bike will bump start without problem and runs absolutely fine.
I changed the spark plugs today hoping that this would sort the problem but it still won't start from the button. The old plugs weren't in a terrible condition either, 2 of them were a bit fowled but that's it.
I've no idea what the problem could be but hopefully someone on here will have an idea.
Thanks.
MattJ
PostPosted: 13:39 - 21 Sep 2012    Post subject: Reply with quote
Yes but as far as I'm aware that wouldn't affect the starting of the bike anyway.
PostPosted: 13:46 - 21 Sep 2012    Post subject: Reply with quote
Do you get a decent spark?
The pulse coil (think its called that) is under the left hand engine casing. They are expensive to replace...luckily mine was intact. What's the state of yours?
ZaphodBeeble
PostPosted: 13:51 - 21 Sep 2012    Post subject: Reply with quote
What bike is it? I would suggest checking the valve clearances and/or carry out a compression test.
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
MattJ
PostPosted: 13:54 - 21 Sep 2012    Post subject: Reply with quote
There's isn't anything under there, mine is the 4JH model though remember.
Haven't tested spark because it bump starts but I will test it. Brother is dropping his multimeter off soon too so I will be able to check the battery but I will be surprised if that is the problem.
MattJ
PostPosted: 13:56 - 21 Sep 2012    Post subject: Reply with quote
FZR600R
Wouldn't that affect the how the bike runs as well as how it starts though? There is no problem running when it has been bump started.
ZaphodBeeble
PostPosted: 14:01 - 21 Sep 2012    Post subject: Reply with quote
It WOULD affect it but you wouldn't notice. It would be a loss of power which had developed over years of riding. If all else fails with the electrics then I highly recommend checking it.
Did the bike lose any oil when you stripped it/crashed it?
MattJ
PostPosted: 14:36 - 21 Sep 2012    Post subject: Reply with quote
Not as far as I'm aware.
bikenut
PostPosted: 14:56 - 21 Sep 2012    Post subject: Reply with quote
:karma: so it starts with a bump start! but not off starter!
bump start whizzes engine over fasster than on starter motor?
is the starter whizzin the engine over fast enough fopr cdi ign system to, produce a good spark??
Scotsman37
PostPosted: 15:19 - 21 Sep 2012    Post subject: Reply with quote
Just a suggestion closely inspect your starter solonoid by removing the main fuse and check for signs of heat damage, and remove the four prong connector that plugs into it and give them a thorough clean. If there is signs of heat damage to the fuse and/or solonoid replace it, as there is now a wide enough gap where the fuse fits to cause an eletrical arc and therefore you will not get enough/ no electrical current to reach the ignition coils. It will just keep damaging the solonoid unit.
GrumpyGuts
PostPosted: 17:30 - 21 Sep 2012    Post subject: Reply with quote
+1 for solenoid.
After refitting the solenoid earth lead, the wire was touching the exhaust thus melting it and shorting the connection. I then had the same problem as you, the bike could bump start but not from the starter button. Every time I tried to start the bike the solenoid would just make a clicking noise, the same noise it was making when my alternator was not working.
I repositioned the lead and insulated the damaged area and it fixed the problem. Starts first time Thumbs Up
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
MattJ
PostPosted: 21:44 - 21 Sep 2012    Post subject: Reply with quote
It's not the solenoid. As I said the engine cranks over but doesn't fire up.
Could it be anything to do with the stator, as it is a little bit damaged but it's only taken a little bit of the plastic coating off it.
Triumph1300
PostPosted: 08:59 - 22 Sep 2012    Post subject: Reply with quote
Could be battery, could be other things, it's almost certainly electrical.
Check the spark whilst cranking, also put your multimeter on the battery whilst cranking, and see what the voltage drops to.
Some CDI's don't like working much below 9/10 volts.
Report back, and we'll go from there
BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit Smile
ZaphodBeeble
PostPosted: 11:09 - 22 Sep 2012    Post subject: Reply with quote
Ahh wait a minute. I had a similar problem with a CBR400 NC29. The timing pickup was very slightly too far away from the metal bit that it picks up from after the bike was dropped. Check the gap on the pickup and adjust the gap as tight as possible. I'd put money on it being this.
A bit more info; I believe this happens because the timing pickup is probably a 2 wire reluctor type sensor which requires a piece of ferrous metal to be passed across it for it to produce a current. If the metal is too far away and moving slowly (ie. when using the starter motor) then only a relatively small current will be produced. However, when you bump start it the metal moves at a higher velocity and induces a higher current in the pickup. By moving the pickup closer to the metal it should produce the higher current that the CDI needs to be able to detect a timing signal.
Later machines have a 3 wire 'hall effect' type pickup which is powered by two of the wires (positive and ground) and outputs either an off or on signal on the third wire. They are generally more accurate and reliable.
MattJ
PostPosted: 18:47 - 22 Sep 2012    Post subject: Reply with quote
I fucking love you! It now starts! All I did was tighten the generator cover up about half a turn more and it started first time.
Thank you so much!
ZaphodBeeble
PostPosted: 15:30 - 24 Sep 2012    Post subject: Reply with quote
No problem. Glad I could help. Thumbs Up
kotachi
PostPosted: 15:37 - 24 Sep 2012    Post subject: Reply with quote
Awesome shout sir Clapping
CBT done - 24/03/2012, theory test done - 03/04/2012.. Mod 1 done -26/06/2012, Mod 2 done - 29/06/2012. Current steed: Cage.
Suntan Sid said: "Look at it this way, your employer wants to pay you the minimum amount, it thinks it can get away with, and extract from you the maximum amount of graft. Ergo it's your responsibility to ensure that karma is restored and you do as little work as you think you can get away with, for the maximum amount of money."
Walloper
PostPosted: 15:46 - 24 Sep 2012    Post subject: Reply with quote
As a measure of gratitude I believe either an extended and wet blowjob or a pint should be coming your way.
ZaphodBeeble
PostPosted: 17:43 - 25 Sep 2012    Post subject: Reply with quote
I'm off the booze at the moment so that doesn't leave much of a choice... Shocked
MattJ
PostPosted: 18:20 - 25 Sep 2012    Post subject: Reply with quote
Shocked
The last post was made 13 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 111.12 Kb
