mz kickstart is poo
mic
PostPosted: 11:11 - 22 Sep 2012    Post subject: mz kickstart is poo Reply with quote
When i try to kick it up it doesnt wanna go. Half the time it doesnt 'feel' like its trying to do anything. Ive changed the fuel tap i was having issues with so its all clean petrol etc. I had it running and gave it a little run up the street, gone back to it an hour later and it doesnt want to know. Sometimes the kickstart stops at the bottom of the kick and jams.
What part do i need to swear at??
thanks
zzr600
PostPosted: 11:17 - 22 Sep 2012    Post subject: Reply with quote
On my MZ, the kickstart works through the clutch, so if the clutch is pulled or slipping the bike won't start. That would be the first port of call.
Zen Dog
PostPosted: 01:05 - 23 Sep 2012    Post subject: Re: mz kickstart is poo Reply with quote
Well, the kickstart mechanism. I seem to remember when we put mine back together it was doing this, but its been a fair while and I cant remember exactly what it was. I think maybe the return spring had slipped from its correct position and moved around the shaft. Don't think it was a major job to sort, but then nothing really is on an MZ!
Marjay is right about the kickstart going through the clutch, so that may be contributing too.
Zen Dog
mic
PostPosted: 07:30 - 23 Sep 2012    Post subject: Reply with quote
I went back out, held the clutch lever in and it started pretty quick so not sure if it was coincidence or not. Will pop see if I can fire it up a few times today see if it doesn't make a difference
zzr600
temeluchus
PostPosted: 00:52 - 24 Sep 2012    Post subject: Reply with quote
Is it a two stroke or four stroke MZ?
mic
PostPosted: 05:02 - 24 Sep 2012    Post subject: Reply with quote
2 stroke
zzr600
temeluchus
PostPosted: 07:15 - 24 Sep 2012    Post subject: Reply with quote
try 2 kicks with the ignition off and choke off, then choke on and one kick. That usually got my MZs going first time.
PostPosted: 09:05 - 24 Sep 2012    Post subject: Reply with quote
There is a definate knack to them.
Most people try to kick them too hard, just tickle it over, you're not trying to make the piston fly out of the top of the engine.
PostPosted: 09:30 - 24 Sep 2012    Post subject: Reply with quote
On my 301 if you didn't give it any welly it would kick back and take out your shins. It wasn't a "Kicking over an old brit twin" kick, but it definitely needed a firm and decisive swing.
PostPosted: 09:39 - 24 Sep 2012    Post subject: Reply with quote
Yes, but we're talking about a 125 here.
Zen Dog
PostPosted: 11:20 - 24 Sep 2012    Post subject: Reply with quote
And a compression level designed to allow running on paraffin/lighter fluid/gravy...
Still wince thinking about the bruise on my calf muscle from the foot-slip-kickback on my 301 though.
Zen Dog
mic
PostPosted: 09:01 - 30 Sep 2012    Post subject: Reply with quote
Wouldnt start yesterday after work so did a crappy video on the iphone. Excuse the havey breathing, had been trying for a while....
When it did start up i went out for a couple of hours to give it a run, but this morning it didnt wanna know so i ended up in the car.
When kicking, its usually the end part of it that fires the bike up when it feels like it but it doesnt feel like theres anything there. If i take the side panel off will i see what should be there? Im guessing a spring?
https://youtu.be/X8V_WUq1cas
zzr600
temeluchus
PostPosted: 12:05 - 30 Sep 2012    Post subject: Reply with quote
I made the mistake of kicking over my 301 in trainers once. Limped for a week.
Boxing
PostPosted: 12:15 - 30 Sep 2012    Post subject: Reply with quote
One of my off road bikes used to do that. Turned out the kick start shaft was gone in the end. The clutch shaft went not too long later, from bump starting it, I presume.
Zen Dog
PostPosted: 14:35 - 30 Sep 2012    Post subject: Reply with quote
The design is different from the 301, so I can't help directly. It sounds like there are "teeth" inside trying to grip, but they're worn so just slipping past. I'd get a Haynes manual and examine the kickstart mechanism, and then contact Burwins about parts (which will probably be absurdly cheap).
Zen Dog
The last post was made 13 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 89.28 Kb
