ZX6R Temperature
RichieZX6R
PostPosted: 13:55 - 22 Sep 2012    Post subject: ZX6R Temperature Reply with quote
Hi All,
On a slower ride today with a 125 doing some stop start riding though the town, while sitting at a set of traffic lights the bike got upto 104 degrees before we set off. When i got home i left the bike running for a min or 2 and the temp got to 101 degrees then i turned it off. Fan never kicked in at home.. Is this normal or should the fan have came on?
Thanks
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
Matt-
PostPosted: 13:57 - 22 Sep 2012    Post subject: Re: ZX6R Temperature Reply with quote
RichieZX6R wrote:
Hi All,
Thanks
a 100 sound's a bit hot to be honest, can you get to any of the Rad pipes ?
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
RichieZX6R
PostPosted: 14:01 - 22 Sep 2012    Post subject: Reply with quote
yeah i can reach 1 or 2 of them from the rad.
Matt-
PostPosted: 14:07 - 22 Sep 2012    Post subject: Reply with quote
Do you know where the Thermostat is & are their any pipes coming off it ?
If so run the bike up for say 5 Mins, leave it running for 2 minutes on idle then sit their at 3,000 For 1 minute then leave it for an extra 2 minutes, while doing this keep an eye on the bike's temp guage and make sure it does not go above 105.
Fell pipe coming off thermo is it hot or cold ?
Also before you do all of this take some basic steps and make sure everything is connected properly and no wires are disconnected or frayed or part broken.
Matt
RichieZX6R
PostPosted: 14:31 - 22 Sep 2012    Post subject: Reply with quote
Well I just went out and checked it and all the pipes felt hot. It got to about 105 then the fan kicked in and took it to about 98 then turned off. Still seems a little hot I think. Not 100% sure where the thermostat is, would have to consult the manual.
Matt-
PostPosted: 14:35 - 22 Sep 2012    Post subject: Reply with quote
It's cooling system is working then just not correctly,
you say it cut in 105, look in a haynes manual or online manual for the correct fan cut in time.
If it's out it's proberly a faulty tempreture sensor Thumbs Up
Matt
0l0dom0l0
PostPosted: 16:54 - 22 Sep 2012    Post subject: Reply with quote
104 degrees is fine on a hot day in traffic.
janner_10
PostPosted: 17:01 - 22 Sep 2012    Post subject: Reply with quote
Sounds very similar to my cbr - fan comes on at about 105 then takes it down to 98 or so when standing still.
Doesn't concern me though.
EDIT: Just found this topic on some yank forums:
https://www.kawasakiforums.com/forum/ninja-zx-6r-zx-6rr-16/what-temperature-do-fan-start-up-27644/
RichieZX6R
PostPosted: 20:24 - 22 Sep 2012    Post subject: Reply with quote
Thanks for the advice guys. Might flush the cooling system just to be on safe side.
Matt-
PostPosted: 21:02 - 22 Sep 2012    Post subject: Reply with quote
Yeah very good idea Smile
Matt
stonesie
PostPosted: 23:37 - 22 Sep 2012    Post subject: Reply with quote
Another vote for it being normal, my bike gets to 103, fan kicks in, temp climbs slowly to 105 then drops to 98, fan off and repeat.
Flushing the system is always a good idea if you don't know when it was last done, like brake fluid it's supposed to be done every 2 years.
Remember that a pressurized cooling system will NOT boil at 100, more like 120 because the pressure stops gas bubbles forming... Take the pressure cap off with it at 105 and the lot will boil instantly, so don't do that, ever!
RichieZX6R
PostPosted: 06:36 - 23 Sep 2012    Post subject: Reply with quote
Oh right I didn't know that. Thought it may have been boiling at 100!
Thanks for the advice Karma
R-Johnny
PostPosted: 07:37 - 23 Sep 2012    Post subject: Reply with quote
+1 for normality.
My ZX6R gets to 102 then the fan kicks in and drags it down.
Kawasaki Ninja ZX6R P8F
nowhere.elysium
The Pork Lord
PostPosted: 08:11 - 23 Sep 2012    Post subject: Reply with quote
The whole point of coolant is to raise the boiling point above 100c. Start worrying when it gets to ~115/120 - that's the point when it'll start to cause problems. The fan should be kicking in at around 100c.
spaz
PostPosted: 19:02 - 23 Sep 2012    Post subject: Reply with quote
Nope, pressurizing the coolant system raises the boiling point.
Coolant simply assists the water in absorbing the heat from the engine and prevents oxidisation in the coolant system.
"If it's got tits or an engine, it'll be trouble"
RichieZX6R
PostPosted: 19:09 - 23 Sep 2012    Post subject: Reply with quote
I did get worried when I seen the temp at 103 thinking the water would have boiled but checking the level and it's still at max when the engine was cold so im less worried about it now. Still going to change it since I have a week off.
nowhere.elysium
The Pork Lord
PostPosted: 19:10 - 23 Sep 2012    Post subject: Reply with quote
spaz wrote:
Science
Fair enough. The point remains that there's nothing to worry about at 100C, though.
The last post was made 14 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 95.19 Kb
