Hole in exhaust. What effect will in have?
Lord Percy
PostPosted: 18:30 - 22 Sep 2012    Post subject: Hole in exhaust. What effect will in have? Reply with quote
Started it while cold today and smoke came out of the wrong bit. I don't mind replacing it, but I'm just interested in what the actual effects are of a hole being there? On my bike the hole is more than halfway up the exhaust.
And I suppose I may as well ask if there's a way of patching it up..?
Cheers! Thumbs Up
Matt-
PostPosted: 18:58 - 22 Sep 2012    Post subject: Reply with quote
Nothing much will happen to it, most defiantly it will make it louder.
If you have the money replace it for maybe a aftermarket system Smile
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Lord Percy
PostPosted: 19:18 - 22 Sep 2012    Post subject: Reply with quote
Yep it's louder, quite embarrassing actually, hah. It sounds sort of cool but the speed of the bike doesn't match it. I had some guy overtake me the other day, beeped his horn at me and looked over, laughing and did a little pisstake action of a biker-boy-racer revving a motorbike, then carried on driving. Haha.
I dunno much about aftermarket exhausts. Although I remember reading in my Haynes book that the exhaust system for my bike (jsut a GN125) is pretty well optimised as it is, so sticking a new one on would usually be worse or have no effect.
I have no idea though. What are my options...?
Matt-
PostPosted: 19:24 - 22 Sep 2012    Post subject: Reply with quote
Well depending on how big the hole is and how thin the metal is you could weld it, even possible to get some exhaust paste if it's a smaller hole, if you don't have a welder get your local
Mechanic to weld it, but if you can get hold
Of one, clean up the exhaust with A grinder, then weld it up, then clean with grinder then VHT ( heat resistant paint )
A new one may be expensive.
Matt
at106
PostPosted: 19:49 - 22 Sep 2012    Post subject: Reply with quote
Whereabouts is the hole, and is your exhaust made up of one or two parts?
Lord Percy
PostPosted: 20:01 - 22 Sep 2012    Post subject: Reply with quote
New one looks to be around £50+.
The exhaust is a whole unit so I think it needs to be a straight swap if I do get a new one.
The hole is halfway up the big back end bit, facing towards the inside of the bike, so I can't see exactly because it's at a point which is really hard to view. The main thing is that every bit of smoke was coming out of this unknown point when I revved the engine. I think this hole is quite a new development. However the bike was bought from E TWO MOTORCYCLES so who knows if the exhaust already had a hole and he just gave it a quick patching up before selling it on.
Anyway if it comes to it I'll just have to fork out the 50 and fit a new one. If i do change the exhaust, what else do I need to consider? When I look on ebay there are various copper and alloy 'exhaust gaskets' to choose from. Would I need to get another one of those too? I take it it's the seal between the engine and the exhaust...?
at106
PostPosted: 20:25 - 22 Sep 2012    Post subject: Reply with quote
Not much help now but some suzuki 125's have a 2 piece exhaust and i have a spare header bit which you could of had.
If there are any engineering places around, you should be able to get it welded for around £10 Thumbs Up
janner_10
Stick up a pic mate, someone could advise how to repair it.
PostPosted: 20:30 - 22 Sep 2012    Post subject: Reply with quote
Ah, diamond geezer Vinny again?
Baked bean tin, gun gum and a jubilee clip will patch it up for a while, but it's likely rotting from the inside out. Break out the piggy bank.
When you replace the exhaust, yes, fit a new gasket, just whatever's cheapest. Make sure you dig the old one out, it can be squashed so flat that it's hard to tell that it's separate from the exhaust port.
MaybeGuy
PostPosted: 20:32 - 22 Sep 2012    Post subject: Reply with quote
Why does this name keep popping up??
Lord Percy
PostPosted: 20:39 - 22 Sep 2012    Post subject: Reply with quote
Ahhh man too late and too dark to start dicking around with exhausts!
It can't be seen without removing the thing, and as far as I know the hole is probably a typical one, most likely down to rust or wear at a point where it's been rattling too much against the frame.
Aside from this leak, the whole thing is in totally fine condition - no bad bits or rust anywhere. I can't even see rust in the area where the hole is, but I can't specifically see the hole so there might be some in the deep dark corner where it's buried. The exhaust is a matte black one, which is odd because the standard one is chrome. However the old Haynes says there is also a matte black option for the bike, so I guess mine has it!
Lord Percy
PostPosted: 20:45 - 22 Sep 2012    Post subject: Reply with quote
oh and his name keeps popping up because my bike has had SO MANY PROBLEMS since I bought it from him! So I make sure to give his name a plug each time I make a new topic with another problem. Laughing
Matt-
PostPosted: 21:14 - 22 Sep 2012    Post subject: Reply with quote
If you can't weld it, do the exhaust paste trick...
If its got to much back pressure and it blows the paste out,
Get a new exhaust Smile
Matt
PostPosted: 21:16 - 22 Sep 2012    Post subject: Reply with quote
A hole in the exhaust will affect smooth running and reduce your accelleration. Better to get it fixed or replaced.
Lord Percy
PostPosted: 21:21 - 22 Sep 2012    Post subject: Reply with quote
Exhaust paste!! Amazing! I'll get some tomorrow. CHEERS!!!!!!!!! Thumbs Up
flumpy7
PostPosted: 21:52 - 22 Sep 2012    Post subject: Reply with quote
Depending on where it is....exhuast bandage might be a better/slightly longer lasting bodge.
2012 Sinnis apache
PostPosted: 21:58 - 22 Sep 2012    Post subject: Reply with quote
Paste ("gun gum") is likely to just blow straight out of the hole. You can spend ages prepping it in the hope of getting a good solid key, or you can wrap a bean tin and a jubilee clip (or just twist some wire) around it.
Either way, a replacement exhaust sounds so cheap that you should think twice before starting down the mend-and-make-do route - the time and cost of repeated bodging will quickly add up.
Lord Percy
PostPosted: 22:27 - 22 Sep 2012    Post subject: Reply with quote
Yeah, very fair point actually. I bought the bike in unexpectedly shite condition, so it's become a bit of a goal for me to get into perfect order, if anything so I can at least come close to selling it for the amount I paid! Although I might try keeping it forever. Apparently lots of people wish they'd kept their first bike...
Alpha-9
PostPosted: 11:45 - 23 Sep 2012    Post subject: Reply with quote
Where is the hole?
Is it big?
Long as it isn't the drain hole which is meant to be there, I thought mine was a hole too but it was just that, noticed when I ACF50'd my exhaust and the next day steam/smoke came out the hole
Fzr-600 1999
Lord Percy
PostPosted: 15:41 - 25 Sep 2012    Post subject: Reply with quote
Ok so here's a picture showing where the holes are. Yep, the hole is now 'holes'. I found them and there are a few holes - blatant rust - halfway along at the bottom.
I've attached a 'diagram' to show exactly where.
So I now do have a new one coming in the post. However I'm still interested in what effect these holes will have? The reason I ask is that my bike seems to have a fucking terrible top speed, so I wonder if these holes might have been the cause of it.
Alpha-9
PostPosted: 15:48 - 25 Sep 2012    Post subject: Reply with quote
Post up some pics of your bike and the hole from different angles Thumbs Up
Fzr-600 1999
Lord Percy
PostPosted: 17:57 - 25 Sep 2012    Post subject: Reply with quote
Oh man, this is like BCF homework! I guess it's still just about light enough.....
Lord Percy
PostPosted: 18:17 - 25 Sep 2012    Post subject: Reply with quote
Hard to make out but there are three holes at the point where it just starts to widen out. They're centre-left on photo. Pretty tough to spot but they're undoubtedly there. All about 3-4mm in size. And that's the only angle I could get because of how tucked away that bit is.
tomh
PostPosted: 18:25 - 25 Sep 2012    Post subject: Reply with quote
Vince will have painted it himself, he does it to every bike... after a month the paint will look shit if it is anything like mine was. I removed the paint with some emery paper and cleanned the chrome up which wasn't in that bad of a condition anyway, just a section with the chrome missing.
On my CG, where you say your hole is in your diagram there is a drain hole which gets rid of excess water in the pipe. It noticeably blows fumes through the hole but is completely normal. It could be similar on your bike as well.
Lord Percy
PostPosted: 20:31 - 25 Sep 2012    Post subject: Reply with quote
Ah right ok, that's interesting. It's just that the bike sounds like it's trying to be a chopper at the moment, which I assumed wasn't right. Anyway I've already ordered a new one because the holes really don't look like they should be there, so we'll see!
The last post was made 14 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 124.41 Kb
