| Lord Percy |
 Lord Percy World Chat Champion
 Posted: 18:30 - 22 Sep 2012 Post subject: Hole in exhaust. What effect will in have? |
Started it while cold today and smoke came out of the wrong bit. I don't mind replacing it, but I'm just interested in what the actual effects are of a hole being there? On my bike the hole is more than halfway up the exhaust.
And I suppose I may as well ask if there's a way of patching it up..?
Cheers!  |
| Matt- |
 Matt- World Chat Champion
 Posted: 18:58 - 22 Sep 2012 Post subject: |
Nothing much will happen to it, most defiantly it will make it louder.
If you have the money replace it for maybe a aftermarket system
Matt ____________________ RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010 |
| Lord Percy |
| Matt- |
 Posted: 19:24 - 22 Sep 2012 Post subject: |
| sa1988 wrote: | Yep it's louder, quite embarrassing actually, hah. It sounds sort of cool but the speed of the bike doesn't match it. I had some guy overtake me the other day, beeped his horn at me and looked over, laughing and did a little pisstake action of a biker-boy-racer revving a motorbike, then carried on driving. Haha.
I dunno much about aftermarket exhausts. Although I remember reading in my Haynes book that the exhaust system for my bike (jsut a GN125) is pretty well optimised as it is, so sticking a new one on would usually be worse or have no effect.
I have no idea though. What are my options...? |
Well depending on how big the hole is and how thin the metal is you could weld it, even possible to get some exhaust paste if it's a smaller hole, if you don't have a welder get your local
Mechanic to weld it, but if you can get hold
Of one, clean up the exhaust with A grinder, then weld it up, then clean with grinder then VHT ( heat resistant paint )
A new one may be expensive.
| at106 |
 at106 Brolly Dolly
| Lord Percy |
| at106 |
 at106 Brolly Dolly
 Posted: 20:25 - 22 Sep 2012 Post subject: |
Not much help now but some suzuki 125's have a 2 piece exhaust and i have a spare header bit which you could of had.
If there are any engineering places around, you should be able to get it welded for around £10  |
| janner_10 |
 janner_10 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:30 - 22 Sep 2012 Post subject: |
Ah, diamond geezer Vinny again?
Baked bean tin, gun gum and a jubilee clip will patch it up for a while, but it's likely rotting from the inside out. Break out the piggy bank.
When you replace the exhaust, yes, fit a new gasket, just whatever's cheapest. Make sure you dig the old one out, it can be squashed so flat that it's hard to tell that it's separate from the exhaust port. ____________________ Biking is 1/20th as dangerous as horse riding.
| MaybeGuy |
 MaybeGuy Super Spammer
| Lord Percy |
| Lord Percy |
 Posted: 20:45 - 22 Sep 2012 Post subject: |
oh and his name keeps popping up because my bike has had SO MANY PROBLEMS since I bought it from him! So I make sure to give his name a plug each time I make a new topic with another problem.  |
| Matt- |
 Posted: 21:14 - 22 Sep 2012 Post subject: |
If you can't weld it, do the exhaust paste trick...
If its got to much back pressure and it blows the paste out,
Get a new exhaust
 Posted: 21:16 - 22 Sep 2012 Post subject: |
A hole in the exhaust will affect smooth running and reduce your accelleration. Better to get it fixed or replaced. ____________________ a.k.a 'Geri'
| Lord Percy |
 Posted: 21:21 - 22 Sep 2012 Post subject: |
Exhaust paste!! Amazing! I'll get some tomorrow. CHEERS!!!!!!!!!  |
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:58 - 22 Sep 2012 Post subject: |
Paste ("gun gum") is likely to just blow straight out of the hole. You can spend ages prepping it in the hope of getting a good solid key, or you can wrap a bean tin and a jubilee clip (or just twist some wire) around it.
Either way, a replacement exhaust sounds so cheap that you should think twice before starting down the mend-and-make-do route - the time and cost of repeated bodging will quickly add up. ____________________ Biking is 1/20th as dangerous as horse riding.
| Lord Percy |
| Alpha-9 |
 Alpha-9 Super Spammer
| Lord Percy |
| Alpha-9 |
 Posted: 15:48 - 25 Sep 2012 Post subject: |
Post up some pics of your bike and the hole from different angles  ____________________ Fzr-600 1999 |
| Lord Percy |
| Lord Percy |
| tomh |
 tomh Scooby Slapper
| Lord Percy |
The last post was made 13 years, 168 days ago. Instead of replying here, would creating a new thread be more useful? |
