Aprilia rs crank resistance
Priliars125
PostPosted: 17:32 - 24 Sep 2012    Post subject: Aprilia rs crank resistance Reply with quote
Hi all I'm a little stuck on what maybe my problem I replaced my centre gasket as was leaking with gasket seal paste but when I put the cases together I finger tightened the bolts up and the crank had so much resistance wtf lol It was ok before is it due to using gasket seal paste or could it be something else just to add when the gearbox side was removed the crank has play init not the big bearing I actually mean it wiggles like there's room on the crank bearing (flywheel side) is this a possible problem ( no play when case is together though) sorry if this is a little confusing any info/ help be great if any other info needed I can get whatever is needed for an answer Very Happy thanks in advance
Nathan
PostPosted: 19:05 - 24 Sep 2012    Post subject: Reply with quote
The sealant will possibly cause issues as it is thinner than the gasket. This might well put a load of extra side loading on the main bearings (note that on the RS you are meant to pull the crank into the crankcase half, not push the crankcase half onto the crank).
Priliars125
PostPosted: 20:01 - 24 Sep 2012    Post subject: Reply with quote
Hi thanks Keith I was hoping you would say that iv got a new gasket on order il see what happens if it's the same any other ideas like I said was ok tight before and free turning? Also if the transmission sprocket seal fails would I get a small leakage of gear oil because iv changed the centre gasket 3 times and still leaks lol only other place I can think would leak gear oil?
Regards
PostPosted: 20:06 - 24 Sep 2012    Post subject: Reply with quote
Could be. But also an over full gearbox will likely push out out of the breather hose.
Priliars125
PostPosted: 20:28 - 24 Sep 2012    Post subject: Reply with quote
It takes 600ml I only added that amount no more so il see with new gasket and update thanks
Nathan
PostPosted: 20:31 - 24 Sep 2012    Post subject: Reply with quote
There is a level plug on the clutch cover. Best to use that rather than trying to measure it in.
Worn crank seal might pressurise the gearbox and push oil out of the breather (although normally it will suck oil into the engine and burn it).
Priliars125
PostPosted: 20:37 - 24 Sep 2012    Post subject: Reply with quote
Yeh iv had that before it burns blue oil it's defo not the crank seals buddy il have to fix and investigate Very Happy
Cheers nathan
Priliars125
PostPosted: 22:00 - 26 Sep 2012    Post subject: Reply with quote
Just an update I put a new crank case gasket on and all good tight screws and no resistance Thumbs Up obviously I will never use instant gasket seal for crank case again lol
The last post was made 13 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 56.89 Kb
