| Priliars125 |
 Priliars125 Two Stroke Sniffer
 Posted: 17:32 - 24 Sep 2012 Post subject: Aprilia rs crank resistance |
Hi all I'm a little stuck on what maybe my problem I replaced my centre gasket as was leaking with gasket seal paste but when I put the cases together I finger tightened the bolts up and the crank had so much resistance wtf lol It was ok before is it due to using gasket seal paste or could it be something else just to add when the gearbox side was removed the crank has play init not the big bearing I actually mean it wiggles like there's room on the crank bearing (flywheel side) is this a possible problem ( no play when case is together though) sorry if this is a little confusing any info/ help be great if any other info needed I can get whatever is needed for an answer thanks in advance
Nathan |
| Priliars125 |
| Priliars125 |
| Priliars125 |
 Posted: 20:37 - 24 Sep 2012 Post subject: |
Yeh iv had that before it burns blue oil it's defo not the crank seals buddy il have to fix and investigate
Cheers nathan |
| Priliars125 |
 Posted: 22:00 - 26 Sep 2012 Post subject: |
Just an update I put a new crank case gasket on and all good tight screws and no resistance obviously I will never use instant gasket seal for crank case again lol |
The last post was made 13 years, 200 days ago. Instead of replying here, would creating a new thread be more useful? |
