Yamaha jog sluggish
davelester
PostPosted: 22:07 - 25 Sep 2012    Post subject: Yamaha jog sluggish Reply with quote
Hi all newbie here, I have a Yamaha Jog RR 50cc and have recently fitted a Tecnigas exhaust....only because my old exhaust fell off and this was the cheapest 2nd hand one on ebay! anyway..when i pull off my bike seems to be really sluggish and slow and get stuck at about 25mph but if i stay on a road long enough at full throttle you hear the bike go for it then im hitting over 50mph but its taking 20-30secs at slowwww speeds to get to the point where it picks up. what can be causing this? some 1 suggested rollers to me but im a newb when it comes to bikes. any help would be great thanks Thumbs Up
The Artist
PostPosted: 22:09 - 25 Sep 2012    Post subject: Reply with quote
what colour powerband you got on it?
I had a jog r before, check my sig.
davelester
PostPosted: 22:13 - 25 Sep 2012    Post subject: Reply with quote
I have no idea where the power band is or what 1 looks like.
Matt-
PostPosted: 22:15 - 25 Sep 2012    Post subject: Reply with quote
Roller's will be an issue,
But also it will need be up jetted as a 2 Stroke which run's lean is very dangerous and can cause damage.
Chance's are someone on here will know what roller's you will need.
Contact Adrenaline Pedstop ( Performance scooters ) and ask them what roller's they suggest fitting to a Jog RR with " your " exhaust fitted. they will be able to tell you everything.
As for the jetting it's just a case of figuring out what main jet you need, you normally go up by 4 - 6 in jet's example if your main jet is 90 you will need to go up to 94, you do this by doing " plug chops " running the scooter up till warm, taking the bike flat out until it wont rev higher, then ignition off , grind to a holt , remove plug, then see what color it is.
Here is a color diagram...
https://motomalaya.net/blog/2011/08/10/spark-plug-colour-condition-for-carburetor-tuning-guide/
You need to be at least " good " in the picture above. ( brownish )
I am also sure if you go on the Yamaha forum you will find PLENTY of information about jetting & roller's.
Good Luck
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
x alex x
PostPosted: 22:17 - 25 Sep 2012    Post subject: Reply with quote
You just need lighter rollers, I see you're coming around to the idea of rollers over jetting Matt :p
Rides: Yamaha FZR 750 & KMX 200
Drives: 2007 Fiat grande Punto Sporting 1.9 Multijet, Remapped, 194BHP Smile
Matt-
PostPosted: 22:20 - 25 Sep 2012    Post subject: Reply with quote
I am sticking to what i said in the other thread alex Wink
I could be wrong, if i am i will bow down and apologies to your humble self Wink
davelester
PostPosted: 22:21 - 25 Sep 2012    Post subject: Reply with quote
where on the bike are the rollers? and wheres the best place to but these gems from?
Matt-
PostPosted: 22:26 - 25 Sep 2012    Post subject: Reply with quote
You will find them in the variator, undo the engine casing, pop it off,
You will have to read a guide on your bike to replacing them.
Alex seems to have done a lot of rollers Wink
eBay of course or adrenaline pedstop online
Matt
Matt-
PostPosted: 22:28 - 25 Sep 2012    Post subject: Reply with quote
https://www.youtube.com/watch?v=2FDIo1NH2LY
Watch this video very helpful Thumbs Up
Is not your model / make but all the same basics Mr. Green
Matt
davelester
PostPosted: 23:13 - 25 Sep 2012    Post subject: Reply with quote
Right it dont seem to hard..is there anything i can fuck up by doing it myself? And how do i know what weight rollers to buy? thanks
davelester
PostPosted: 20:13 - 27 Sep 2012    Post subject: Reply with quote
got my rollers today. i got 4.2g and also got a new air filter and spark plug. hopefully sort the problem out. Any other tips would be appreciated.
Matt-
PostPosted: 20:22 - 27 Sep 2012    Post subject: Reply with quote
Make sure everything is done properly if your not sure ASK
Make sure everything is done up tight but not SO tight it brake's anything.
Follow the video and you should be fine Thumbs Up
Good Luck Thumbs Up
Matt
davelester
PostPosted: 20:34 - 27 Sep 2012    Post subject: Reply with quote
need to get jets still. Will my jet have size on it so i know what size to get up? forgot to order from ebay and wont be here for weekend. so need to find a shop that sells them. would it have to be Yamaha shop or is there other shops that stock parts like these?
thanks
davelester
PostPosted: 18:13 - 28 Sep 2012    Post subject: Reply with quote
Went to Yamaha today to buy jets and told him the problem and he said he would not upjet. He seems to think the rollers shuld sort the problem out. Im just a little worried after ppl saying bike might be running to rich or lean and might fuck my bike
Matt-
PostPosted: 18:19 - 28 Sep 2012    Post subject: Reply with quote
Yes dealer is correct however...
Running rich is ok, well it's not but it won't do your engine much harm
Running lean is BAD, if you look at your spark plug you will be able to tell.
You will need to do " Plug Chops " take the scooter on a run with the new rollers in, warm it up first, take it for a run up the road and back, which ignition off, roll to a stop, take the spark plug out and see what the color is like:
https://www.apriliaforum.com/forums/showthread.php?253881-Sparkplug-Color!
Should be brownish...
Good Luck
Matt
davelester
PostPosted: 15:54 - 29 Sep 2012    Post subject: Reply with quote
having a right shit time with this! ive took the cover off but when trying to undo the big nut ive snapped a tooth on the bit im trying to remove! im doing what is said with a screw driver but it just is not working and coming undone. Any tips would be great!
Matt-
PostPosted: 16:15 - 29 Sep 2012    Post subject: Reply with quote
Be careful 1 tooth should be ok...
Take a photo of it?
If the nut is to tight you may have to give up on it for now until you find a holder, or a impact gun for the nut, if you have a compressor it's fine but chances are you will have to take it down your local mechanics garage.
davelester
PostPosted: 16:47 - 29 Sep 2012    Post subject: Reply with quote
ill up a photo later mate. its not a tooth i snapped its like a blade of a fan! i need an impact wrent or air gun of some sort i reckon. God damn bike just wanted to get it sorted this weekend!
Matt-
PostPosted: 16:49 - 29 Sep 2012    Post subject: Reply with quote
I know what you mean i think,
All good fun...
Upload the picture and we can take it from their mate Very Happy
Matt
davelester
PostPosted: 21:02 - 29 Sep 2012    Post subject: Reply with quote
https://s17.postimage.org/3nvlwt8aj/3variator_sized.jpg I snapped 2 blades/teeth on that fan on the front![/img]
Matt-
PostPosted: 10:07 - 30 Sep 2012    Post subject: Reply with quote
That's ok, that should be fine, it's only a scooter.
How's it going, got the Nut off yet?
Matt
davelester
PostPosted: 12:53 - 30 Sep 2012    Post subject: Reply with quote
Not yet just waiting for bloke across the road to set up his compressor then we gonna have a go at it with the impact wrench! U reckon i'll still have to jam it to stop it moving? Also how tight do i do it back up if i get it off lol
davelester
PostPosted: 13:15 - 30 Sep 2012    Post subject: Reply with quote
As for fitting my air filter do i just take this box off https://www.pedparts.co.uk/product/302/aerox-standard-airbox-filter
and replace with mine?
The last post was made 13 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 115.39 Kb
