CG125 Leaking Engine Oil- Cracked Crank Case
crazymotorbik...
PostPosted: 23:11 - 27 Sep 2012    Post subject: CG125 Leaking Engine Oil- Cracked Crank Case Reply with quote
Hi,
I've just finished fixing the fork seals and clutch on my little CG125.
Before i fixed the clutch oil weeped slightly from the bottom of the casing and a small area of oil would normally form over night under the bike.
After rebuilding the clutch and replacing the casing it still bloody leaks!! A new genuine gasket was used and both surfaces were spotless.
It doesn't leak enough to cause a serious problem. IE Seizure. Will it pass its MOT leaking a small amount of oil?
Cheers,
Shaun R.
DMCpro
PostPosted: 23:26 - 27 Sep 2012    Post subject: Reply with quote
MOT is for road safety. if it causes a hazard it should fail.
leaks arent really what an mot tester is looking for though, you should really try and get it sorted, next time use a bit of gasket sealant.
Honda CB-1, TS125X
VW Golf Estate
PostPosted: 23:28 - 27 Sep 2012    Post subject: Reply with quote
You really are a gimp.
Any leaks will fail an MOT. Not being able to contain fluid is a fail..
To get it through, gaffer tape will do.
crazymotorbik...
PostPosted: 23:31 - 27 Sep 2012    Post subject: Reply with quote
Hi,
It doesn't cause a safety issue so fingers crossed it will pass.
Completely agree with you on fixing it but been cash strapped it will have to wait. Think i will try some Hylomar Blue.
Cheers,
Shaun R.
DMCpro
PostPosted: 23:34 - 27 Sep 2012    Post subject: Reply with quote
you clearly havent read my message. Like I said if it causes a hazard it should fail. ive got an mot cert with an advisory of "slight petrol leak" on it to prove that what you've just said is made up.
Honda CB-1, TS125X
VW Golf Estate
Matt-
PostPosted: 23:36 - 27 Sep 2012    Post subject: Reply with quote
Gaffer could work,
I would just put some black siloken on it Laughing
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
PostPosted: 23:40 - 27 Sep 2012    Post subject: Reply with quote
Well even my fantastically easy going MOT guy failed because the carb was dripping. A petrol leak is a fail. Petrol > hot engine > warm penis.
Feel free to scan the MOT, I'll eat a lemon Thumbs Up
DMCpro
PostPosted: 23:50 - 27 Sep 2012    Post subject: Reply with quote
will dig it out tomorrow and scan it if you like pal.
I always tip my local garage.
I am still in training at college most technitions seem to think stupid things will pass and they do amazes me sometimes.
Honda CB-1, TS125X
VW Golf Estate
blurredman
PostPosted: 00:03 - 28 Sep 2012    Post subject: Reply with quote
I can confirm this. I have such advisories for 'Slight oil leak' sometimes. It does not cause an outright fail.
Saying that, I don't know if an MOT tester will even bother to look under the engine.
69chris
PostPosted: 00:07 - 28 Sep 2012    Post subject: Reply with quote
oil leak is a 'non component advisory' although there is a box to tick if you think its dangerous Smile
crazymotorbik...
PostPosted: 20:16 - 29 Sep 2012    Post subject: Reply with quote
Hi,
Thanks for the replies Karma all round.
I found a rather nice 4 inch hairline crack on the underside of the RH crankcase. The crack runs between the footrest bolt holes and to the outer edge of the crankcase. Possibly caused by an off putting pressure on the footrests?
I have glued it with DP110 structural epoxy resin (Got a huge bottle from work Very Happy ) for now and it has stopped the leak however i hate bodges and would like a more permanent fix.
Does anyone know if these can be welded?
Cheers,
Shaun.
kramdra
PostPosted: 22:50 - 29 Sep 2012    Post subject: Reply with quote
If it was the cover then easy, but crank case you will have to strip it first Sad
got a picture?
crazymotorbik...
PostPosted: 23:21 - 29 Sep 2012    Post subject: Reply with quote
Hi,
Unfortunately i have no picture. It looks like there are a few other small cracks in the crankcase also Sad
I'm incredibly skint so buying a second hand case is not possible at the moment. I cant even afford to strip it down as i'll need a gasket set etc. Was hoping it could be done in situ then i'd only need a new clutch gasket. Also have the added bonus of my old man been a welder Smile
The glue seems to have done the trick but seems less than permanant as fixes go.
I need the bike to start saving money on fuel but have no money to repair it. Talk about a catch 22!
Cheers,
Shaun.
DMCpro
PostPosted: 00:30 - 30 Sep 2012    Post subject: Reply with quote
crazymotorbiker wrote:
Hi,
Cheers,
Shaun.
If your very careful you won't need to replace clutch gasket. I done my clutch earlier and didn't have a gasket, I used silicone sealant. Not the best fix but it will do!
I wouldn't say you Would need to strip it out if your dads a welder, does he have a tig welder? Tig welders are the easiest to weld aluminium with.
I know how you feel about the cg, mine was a little bit of a money pit when I first got it but now it's had work done to it it won't need anything for a long while as long as I keep on top of the oil changes air filter clean etc
Honda CB-1, TS125X
VW Golf Estate
The last post was made 13 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 83.55 Kb
