MOD 1 speed trap. should a calibration run be allowed?
Ribenapigeon
PostPosted: 10:46 - 28 Sep 2012    Post subject: MOD 1 speed trap. should a calibration run be allowed? Reply with quote
I was raeding another topic where a rider was too slow going through the speed trap because his speedo was reading too fast. Varience in speedo accuracy seems to be quite common so should the testing authority allow a calibration run? Just a thought.
yaigi
PostPosted: 10:50 - 28 Sep 2012    Post subject: Re: MOD 1 speed trap. should a calibration run be allowed? Reply with quote
They allow you a second run if you don't hit the right speed first time anyway
Shinigami
PostPosted: 10:52 - 28 Sep 2012    Post subject: Reply with quote
simple solution, don't look at the speedo.
I found it much easier just pinning it and not looking down.
SnowTigeress
PostPosted: 10:53 - 28 Sep 2012    Post subject: Re: MOD 1 speed trap. should a calibration run be allowed? Reply with quote
you get 3 gos on the speed trap,first is like a dry run without e-stop or swerve.
they will tell you your speed
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
BravoCharlie
PostPosted: 10:54 - 28 Sep 2012    Post subject: Reply with quote
if you do the manoeuvre correctly but dont hit the speed correctly they will probably give you another shot.
the marking slip has 2 boxes to record your speed a 1st and 2nd time.
i'd just keep it in 2nd, open the throttle, and if you're too slow, he'll tell you Thumbs Up
Current: Kawasaki ZL600 Eliminator
Past: Suzuki GZ125, Kawasaki GT550, Kawasaki GPX600R, Honda vrx400,Kawasaki Zephyr 750, Suzuki SV650 K5
Dream as if you'll live forever, live as if you'll die today.
thepuma
PostPosted: 11:00 - 28 Sep 2012    Post subject: Reply with quote
To be honest, you really don't want to be looking at your Speedo as you're coming up to the trap. If you're on a 125 then just take the bend at around 20mph and floor it in 2nd gear.....you will go through it naturally at 30ish mph. I never looked at the Speedo once on mine and I did it at 31,31 and 30 on my mod1.
If you look at your Speedo then its distracting you from what you need to do and in doing so making you more likely to makea mistake.
765 RS
Ribenapigeon
PostPosted: 11:05 - 28 Sep 2012    Post subject: Reply with quote
As I said just a thought hehee.
The emergancy stop dousent phaze me anyway as I'm always doing them. Errrr that didn't sound good :-/
cimbian
PostPosted: 11:42 - 28 Sep 2012    Post subject: Reply with quote
Mod 1 done this week, wind blowing a hoolie!
Like has been said, don't look at your speedo; look where you want to be and just go for it.
If you look down and worry about the speed you'll take-out one of the avoidance cones, probably the first one and may still not be going fast enough but without a chance at another go.
Better a minor fault and second chance than a fail. All IMveryHO, of course. Wink
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
Andy_Pagin
PostPosted: 12:03 - 28 Sep 2012    Post subject: Reply with quote
Fine on a 125, on a 500 you'll go through the trap at 60mph!
ScaredyCat
PostPosted: 12:19 - 28 Sep 2012    Post subject: Re: MOD 1 speed trap. should a calibration run be allowed? Reply with quote
The controlled stop (the first one you go through the trap for) is designed to give you an idea of your speed. You should ask what your speed was if the examiner does not tell you.
Precisely why I opened up the throttle like a hooligan on my mod 1 - wasn't going to fail for being too slow Wink
Andy
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Gunhawk
PostPosted: 12:20 - 28 Sep 2012    Post subject: Reply with quote
My MOD1 examiner never even looked at the speedo devices once over my 3 runs, guess he knew from experience i was going fast enough! either that or he was hungry for lunch! (it was a lunchtime test)
Current: Honda VFR800 VTEC
Previous: Honda CBF125, Honda XL650 Transalp, Honda CBR600f3
CBT: 19/5/12 > Theory: 06/08/12 > MOD1: 29/08/12 > MOD2: 16/10/12
ScaredyCat
PostPosted: 12:21 - 28 Sep 2012    Post subject: Reply with quote
I did Very Happy E-Stop was at 62 avoidance at 57
Andy
sidewinder
PostPosted: 12:28 - 28 Sep 2012    Post subject: Reply with quote
Andy
About the same for me on the cbf600 just floored it in 2nd as soon as i got on the bend before.. Very Happy
janner_10
PostPosted: 12:51 - 28 Sep 2012    Post subject: Reply with quote
Don't get bogged down worrying about crap like this - just floor it post bend you will be fine. Thumbs Up Thumbs Up
PostPosted: 13:03 - 28 Sep 2012    Post subject: Re: MOD 1 speed trap. should a calibration run be allowed? Reply with quote
Boozehawk wrote:
I was raeding another topic where a rider was too slow going through the speed trap and his speedo was reading too fast.
EFA.
His problem was that he ate too many pies, then changed up to 3rd.
Also, what Snowie said: there is a "sighting" lap now.
Best thing would be to just sod off the speed trap altogether and rely on the examiner's judgement like for every other part of the tests. Hopefully that'll happen if we go back to a single on road test.
Andy_Pagin
PostPosted: 13:25 - 28 Sep 2012    Post subject: Reply with quote
Andy
Lol there was a psychological barrier preventing me from doing that - a wall of ten foot high iron girders at the end of the strip.
Llama-Farmer
PostPosted: 20:53 - 28 Sep 2012    Post subject: Reply with quote
Depends what bike you're on. I went through on a 650 after pinning it in 2nd and was "unnecessarily fast, slow it down, a lot, for the avoidance" was the response from the examiner
ScaredyCat
PostPosted: 21:45 - 28 Sep 2012    Post subject: Reply with quote
I did mine on a 650 (ER6-n) and pinned it, even for the controlled stop. My theory was that he'd see the speed and, for the E-Stop, would need to be pretty sharp with his hand up. That means pretty much as you enter the speed trap, which means you can shut the power off immediately you exit it. From what I saw, those on a 125 had try pretty hard to get to speed.
Might not have been the best approach but it seemed to work, plus I managed to stop sharpish too (also ABS++).
Andy
Llama-Farmer
PostPosted: 21:48 - 28 Sep 2012    Post subject: Reply with quote
Andy
Once thing I realised afterwards was the faster you're going, the further the emergency stop will take. Looks a lot better if you're within a few mph and stop in a short distance than take twice as far to stop from 15-20mph over
PostPosted: 21:56 - 28 Sep 2012    Post subject: Reply with quote
They usually write it in KM.
I did 56 and 57 on a CLR125, that never ever really did 57mph, so its definitely KM. Doing a swerve like that at 50+mph would be suicidal on their playground and you would probably fail for going too fast. I got a warning for doing nearly 40mph...
ScaredyCat
PostPosted: 21:59 - 28 Sep 2012    Post subject: Reply with quote
Yeah, this is all Km/h - not Mp/h Laughing
I might be mad but I'm not crazy Wink
Andy
herulach
PostPosted: 22:01 - 28 Sep 2012    Post subject: Reply with quote
I passed only because I was going too fast. 55 on a 500, locked the back wheel but was excused because I controlled it and stopped quickly from the speed.
YBR 125>FZS600
ScaredyCat
PostPosted: 22:04 - 28 Sep 2012    Post subject: Reply with quote
The examiner will look at the speed you did, since they need to mark it down, and assess your stopping distance based on that. It's not based on absolute distance - ie "[s]he didn't stop before the 3rd yellow cone".
Maybe if you got an examiner on a bad day, but the guy I had for mod 1 and 2 was a really nice bloke.
Andy
Llama-Farmer
PostPosted: 23:34 - 28 Sep 2012    Post subject: Reply with quote
Andy
I know, but stopping in as short a distance as possible does look like a better emergency stop
thepuma
PostPosted: 07:59 - 29 Sep 2012    Post subject: Reply with quote
Andy
Haha..can you imagine doing the swerve at 57mph Laughing
765 RS
The last post was made 13 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 133.28 Kb
