Protecting chrome?
koolio
PostPosted: 12:01 - 28 Sep 2012    Post subject: Protecting chrome? Reply with quote
Sorry if this is for some is a very basic question.
Other than using chrome cleaner regularly is there any long term fix for protecting chrome parts?
I was considering lacquering chrome parts?
P.S. This is not for chrome parts on the engine of course.
janner_10
PostPosted: 12:29 - 28 Sep 2012    Post subject: Reply with quote
Ive used chrome wax in the past to put a nice protective layer on, tried WD40 but that seemed to not last long.
Something like this
https://www.ebay.co.uk/itm/WHEEL-WAX-CANUBA-RIM-WAX-CHROME-ALLOYS-PROTECTION-Z0059-/230742861842?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35b958a812#ht_1392wt_1163
PostPosted: 12:53 - 28 Sep 2012    Post subject: Reply with quote
ACF50
koolio
PostPosted: 13:29 - 28 Sep 2012    Post subject: Reply with quote
I know about ACF 50 but you keep having to reapply it same with a wax.
I wanted a fixed long term solution other than stainless steel (which I can't do everything with unfortunately).
I know people lacquer polished aluminium to keep it from losing its shine.
Surely this can be applied to chrome?
PostPosted: 13:41 - 28 Sep 2012    Post subject: Reply with quote
The ironic thing is. Chrome doesn't rust, that's why they put it on.
It's the steel underneath the chrome that rusts and it only shows through when there is a hole in the chrome.
Nexus Icon
PostPosted: 13:52 - 28 Sep 2012    Post subject: Reply with quote
Yes, you can lacquer chrome.
Greetings from Shitsville!
PostPosted: 14:01 - 28 Sep 2012    Post subject: Reply with quote
A couple of times a year, it's hardly a huge effort. How are you planning to protect the non chrome bits? Buy a litre bottle, quick spray and wipe whenever you can be bothered, it'll last you for years.
Suntan Sid
PostPosted: 14:07 - 28 Sep 2012    Post subject: Reply with quote
Paint it matt black!
Chrome is, sooooo, last season darling!
koolio
PostPosted: 14:57 - 28 Sep 2012    Post subject: Reply with quote
Very true.
Everything that can be is stainless steel or aluminium, non-stainless parts are powdercoated or painted. I've already given too much attention to my bike and it really saps my time, I always ACF before winter but I really prefer minimum cosmetic maintenance.
And it holds / Protects against rust?
symonh2000
PostPosted: 15:05 - 28 Sep 2012    Post subject: Reply with quote
Vaseline does a good job or protecting chrome.
Four strokes is two strokes too many.
PostPosted: 15:06 - 28 Sep 2012    Post subject: Reply with quote
I bet vinyl wrap would stick to degreased chrome like shit to a blanket.
You could even use chrome effect vinyl.
koolio
PostPosted: 23:35 - 28 Sep 2012    Post subject: Reply with quote
Is this actually serious?
Not sure it would give the desired effect.
Whats the problem with just lacquering certain smaller chromed parts?
Nexus Icon
PostPosted: 23:39 - 28 Sep 2012    Post subject: Reply with quote
Lacquer can chip, after all it's just a pigment-free paint, but it holds. Chrome doesn't rust so I'm not totally sure of the point though.
Noxious89123
PostPosted: 00:11 - 29 Sep 2012    Post subject: Reply with quote
Because if you get it wrong, it'll look pants.
Ichy
PostPosted: 00:20 - 29 Sep 2012    Post subject: Reply with quote
No problem at all, it just serves no purpose.
symonh2000
PostPosted: 14:56 - 29 Sep 2012    Post subject: Reply with quote
Yes, Vaseline is oil based and doesn't wash off.
People also use it on battery terminals as well as the other obvious uses. Laughing
koolio
PostPosted: 23:02 - 29 Sep 2012    Post subject: Reply with quote
Well anyone who has seen old chrome parts will know that they do rust and pit.
Maybe the chrome itself doesn't but there is actually a very fine content of chrome in chromed parts and it is more dependent on the thickness of the nickel and in a good job copper below it.
So the point is does lacquering provide any future protection against rust?
There is a reason people with classic bikes like to go stainless, like I am doing but some parts are prohibitively expensive to do so.
Ichy
PostPosted: 09:04 - 30 Sep 2012    Post subject: Reply with quote
Just keep it clean. I don't use abrasive cleaners on chrome, just window cleaner.
This bike is 26 years old and was used pretty much daily. Virtually all of the major parts are original.
https://i93.photobucket.com/albums/l41/marki_03/xv1000/PICT1740c.jpg
The fork lowers were polished alloy without any coating, just wiped with ethanol to stop them corroding.
There are only three problems with corrosion on chromed parts that I am aware of on bikes. Abrasive cleaning removing the coating, rotting from the inside out and micro fractures. All of these can be significantly reduced with regular cleaning using the right stuff.
The best you can do to protect the chrome would be a clear plastic coating.
Nick 50
PostPosted: 09:42 - 30 Sep 2012    Post subject: Reply with quote
+1 for symonh2000 suggestion.
When I bought my GZ, the previous owner had caked the chrome in Vaseline. It worked really well over winter.
The proof is in when you try and take the bugger off the chrome, it takes ages..........
lwincott07
PostPosted: 22:32 - 30 Sep 2012    Post subject: waxoil Reply with quote
When ur not using in paint on some wax oil. Itll clean off like new when u want too. Itll protect it from rain, salt & all sorts. Just an idea for you Smile
The last post was made 13 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 108.97 Kb
