Aprilia RS 125 Full Power, 9000rpm problem???
dicknose139
PostPosted: 20:28 - 28 Sep 2012    Post subject: Aprilia RS 125 Full Power, 9000rpm problem??? Reply with quote
hi all, im new to this forum.
i have an aprilia rs 125 full power 2005, bike was running sweet until a few weeks ago. now all of a sudden it doesnt like going up to 9000rpm, it just bogs down until i ease of the throttle. things ive done that may have caused it are;
had an oil leak from somewhere, ended up being from the oil pump, took the oil pump cover off and the bolts that hold it on where just sitting at the bottom of the casing. got it back on no problems. i think since putting the oil pump back on, it might of adjusted itself? maybe thats why the bike is bogging down at around 9000rpm?
had the power valve blade out and cleaned it but nae sure if i put it back in the right way?
ive changed the cdi to a new unrestriced one (old had been deristricted badly), and got a new power valve ecu, coils, fuses, spark plug, spark plug cap and HT lead, bike was running fine with all this new stuff on it.
ive had the carb off and cleaned it, had the air filter off and cleaned. cleaned the fuel filter aswel. had the petcock out and the and the pipe that goes into the tank that connects to the fuel tap was snapped? would that cause the rpm problem? maybe there is air getting in the pipe?
actually have no idea whats wrong? please help. any advice would be fantastic. loves this bike and dont want to have to sell it for spares or repairs.
cheers guys
C.McLellan
Priliars125
PostPosted: 20:52 - 28 Sep 2012    Post subject: Reply with quote
Pv blade I'd say just take out and check that the flat side is at the top Smile
dicknose139
PostPosted: 21:08 - 28 Sep 2012    Post subject: Reply with quote
ok dude will give it a try tomorrow.
cheers
C.McLellan
Matt-
PostPosted: 21:25 - 28 Sep 2012    Post subject: Reply with quote
power valve blade's cannot be put in wrong, i don't see how a power valve blade would wear that much in SO little time, some aprilias powervalve blades last for age's, all depends on the use of the bike, it could be a numder of problems, if it has been recently fitted with any performance part it may be the problem, but as it was ok then just went to 9000 it's strange.
Are you sure the powervalve is fully de restricted and is not limted ? you may have been sold a dud if your are sure it's a full power powervalve then:
i would check is the carb is cleaned correcly and the needle jet valve is working correctly, also check that air filter is clean and tidy, if that doesnt work i would suggest, taking out the REED block, looking through it and seeing if their is any gaps. if it's ok and the membranes are sealing onto the block, it's ok Thumbs Up
Also on a side note make sure you have clean fuel.
Good Luck
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
PostPosted: 21:51 - 28 Sep 2012    Post subject: Reply with quote
The RS one can. Some people put it upside down.
Matt-
PostPosted: 16:33 - 29 Sep 2012    Post subject: Reply with quote
How could people get it wrong though, just put it in the way it came out. simple Laughing
How is the issue going by the way ?
Matty
emdell
PostPosted: 16:49 - 29 Sep 2012    Post subject: Reply with quote
does it rev cleanly when not under load? i.e if it's in neutral will it rev past 9k easily?
when you say bog down - does it start to splutter or does it feel like it's hitting a wall?
dicknose139
PostPosted: 16:02 - 30 Sep 2012    Post subject: Reply with quote
no even in neutral it it doesnt rev past 9, its like it is red lining at 9000rpm when i give it full throttle in neutral.
it just splutters like crazy, and i lose power until i ease off the throttle.
i checked the power valve yesterday and it was in the right way round, not sure if its actually working though? i dont have a voltage meter/amp meter.
it also smokes quite a bit on start up and when its warmed up and on idle, goes away.
think it might be running rich.
heres my setup;
34mm carb, pipercross cone airfilter, standard exhaust with arrow end can. the carbs main jet is a 165. is it too big??
cheers for the help so far guys
C.McLellan
anthony_r6
PostPosted: 17:09 - 30 Sep 2012    Post subject: Reply with quote
You can get a multimeter for <£10 - I suggest you go get one if you think it could help. Any way of getting a video up of it?
thomp1983
PostPosted: 17:50 - 30 Sep 2012    Post subject: Reply with quote
with the weather begining to turn now are you sure your not suffering from either carb icing or your cone filter being wet?
chris
mr jamez
PostPosted: 18:01 - 30 Sep 2012    Post subject: Reply with quote
Your original post is not very clear on what has happened in what order. Was the bike running fine after you had added the new ECU, valve controller etc?
I am assuming you cleaned out the filters, discovered the snapped pipe etc after the problems started?
I'd double check the oil pump is set correctly and you have the power valve blade the correct way up. Also this "snapped pipe" is it the fuel hose or does the RS125 have a vacuum fuel tap?
Also cone filters can cause all sorts of problems with the mixture.
PostPosted: 20:50 - 30 Sep 2012    Post subject: Reply with quote
Possibly the power valve, although I would expect it to just feel flt at higher revs if in upside down. Possibly the valve not opening, in which case I would expect it to be gutless from about 8k, and might well drop right off by 9k.
Beyond that check the main jet is clear and possibly find somewhere quiet and use a strobe timing light to check the ignition timing isn't doing anything silly at high revs.
Loads of other things it could be, but those are probably the most likely and easily checked things.
The RS one can and commonly is (seen a bike with the valve in upside down fitted by a main dealer). To confuse people the blanking plate on restricted ones has the end at the opposite angle to the actual power valve.
The last post was made 13 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 74.65 Kb
