| dicknose139 |
 dicknose139 L Plate Warrior
 Posted: 20:28 - 28 Sep 2012 Post subject: Aprilia RS 125 Full Power, 9000rpm problem??? |
hi all, im new to this forum.
i have an aprilia rs 125 full power 2005, bike was running sweet until a few weeks ago. now all of a sudden it doesnt like going up to 9000rpm, it just bogs down until i ease of the throttle. things ive done that may have caused it are;
had an oil leak from somewhere, ended up being from the oil pump, took the oil pump cover off and the bolts that hold it on where just sitting at the bottom of the casing. got it back on no problems. i think since putting the oil pump back on, it might of adjusted itself? maybe thats why the bike is bogging down at around 9000rpm?
had the power valve blade out and cleaned it but nae sure if i put it back in the right way?
ive changed the cdi to a new unrestriced one (old had been deristricted badly), and got a new power valve ecu, coils, fuses, spark plug, spark plug cap and HT lead, bike was running fine with all this new stuff on it.
ive had the carb off and cleaned it, had the air filter off and cleaned. cleaned the fuel filter aswel. had the petcock out and the and the pipe that goes into the tank that connects to the fuel tap was snapped? would that cause the rpm problem? maybe there is air getting in the pipe?
actually have no idea whats wrong? please help. any advice would be fantastic. loves this bike and dont want to have to sell it for spares or repairs.
cheers guys ____________________ C.McLellan |
| Priliars125 |
 Priliars125 Two Stroke Sniffer
 Posted: 20:52 - 28 Sep 2012 Post subject: |
Pv blade I'd say just take out and check that the flat side is at the top  |
| dicknose139 |
| Matt- |
 Matt- World Chat Champion
 Posted: 21:25 - 28 Sep 2012 Post subject: |
power valve blade's cannot be put in wrong, i don't see how a power valve blade would wear that much in SO little time, some aprilias powervalve blades last for age's, all depends on the use of the bike, it could be a numder of problems, if it has been recently fitted with any performance part it may be the problem, but as it was ok then just went to 9000 it's strange.
Are you sure the powervalve is fully de restricted and is not limted ? you may have been sold a dud if your are sure it's a full power powervalve then:
i would check is the carb is cleaned correcly and the needle jet valve is working correctly, also check that air filter is clean and tidy, if that doesnt work i would suggest, taking out the REED block, looking through it and seeing if their is any gaps. if it's ok and the membranes are sealing onto the block, it's ok
Also on a side note make sure you have clean fuel.
Good Luck
Matt ____________________ RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010 |
| P.addy |
 P.addy Red Rocket
| Matt- |
| emdell |
 emdell L Plate Warrior
| dicknose139 |
| anthony_r6 |
 anthony_r6 World Chat Champion
| thomp1983 |
 thomp1983 Crazy Courier
| mr jamez |
 mr jamez World Chat Champion
| Kickstart |
 Kickstart The Oracle
The last post was made 13 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
