Help finding this
Priliars125
PostPosted: 17:45 - 29 Sep 2012    Post subject: Help finding this Reply with quote
Im looking for a tool to tighten my grub screw up or the name of it theres a certain tool for the rs125 any help be good
Regards
thomp1983
PostPosted: 21:59 - 29 Sep 2012    Post subject: Reply with quote
what screw/bolt is it your trying to tighten exactly?
Frost
PostPosted: 22:32 - 29 Sep 2012    Post subject: Reply with quote
grub screw usually requires an allen key.
Priliars125
PostPosted: 14:40 - 30 Sep 2012    Post subject: Reply with quote
The grub screw has a 10mm nut on a Allen key but you have to hold the Allen key and tighten the nut it keeps coming loose iv tried everything iv searched the net just can't find one and I'm not 100% its a 10mm its pissing me off unreliable atm lol please somebody must know
Thanks
thomp1983
PostPosted: 17:53 - 30 Sep 2012    Post subject: Reply with quote
where abouts on the bike is the bolt?
janner_10
PostPosted: 21:37 - 30 Sep 2012    Post subject: Reply with quote
Stick up a pic of it
Priliars125
PostPosted: 15:51 - 01 Oct 2012    Post subject: Reply with quote
Il try getting a pic ASAP itson the clutch case it's the grub screw on the clutch lever arm that pushes the pressure plate to release the plates and change gear
thomp1983
PostPosted: 20:41 - 01 Oct 2012    Post subject: Reply with quote
i assume you mean the screw that's behind the plastic cover in the centre of the case covering the clutch? the screw itself is turned using a flat blade screwdriver, you need to loosen the nut around it first though, you then need to adjust the grub screw to get the clutch set how you want it then manage to hold the grub screw still while tightening up the screw around it. aprilia use a special hollow spanner for the job can't remember how i did it a couple of weeks ago but it wasn't anything fancy, i either used a swan next spanner or loosened the nut, put a socket over the nut held the nut with that by hand then and put a screwdriver through the socket to adjust the grub screw
chris
Priliars125
PostPosted: 21:41 - 01 Oct 2012    Post subject: Reply with quote
It's a Allen key through the. Middle I did that iv adjusted these many times but iv lost my tool that's the main reason I want another there not expensive and a good tool to have I have no problem on how to actually adjust it but yes that's the exact place it is!
Thanks
thomp1983
PostPosted: 20:41 - 02 Oct 2012    Post subject: Reply with quote
the part number for the tool is 276 040 an aprilia dealer is probably your best bet
chris
The last post was made 13 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 61.05 Kb
