Deep clean
Davenaylor
PostPosted: 11:01 - 30 Sep 2012    Post subject: Deep clean Reply with quote
Hi,
I'm embarking on the first deep clean on my bike. I'm replacing the rear mud guard, chain and sprockets and also hammeriteing the shit out of the frame at the same time.
Question is, I plan to use wd40 to clean away the grease, but then I'm not sure what to clean away the wd40 with. Would muc off to the trick.
A YouTube video I watched said that wd40 is an oil based cleaner and that I have wash that away with a water based cleaner. I'm just unsure if muc off fits the bill?
Thanks
base
PostPosted: 11:19 - 30 Sep 2012    Post subject: Reply with quote
gunk degreaser would be choice for remove general engine grime etc hose off with water
Islander
PostPosted: 13:02 - 30 Sep 2012    Post subject: Reply with quote
Forget the WD40, Gunk or Jizer will do the job nicely. Thumbs Up
WannaBeDude
PostPosted: 13:07 - 30 Sep 2012    Post subject: Reply with quote
Degreasers and wet wipes Smile Thumbs Up Idea
Davenaylor
PostPosted: 21:01 - 30 Sep 2012    Post subject: Reply with quote
01001001 00100000 01100110 01110101 01100011 01101011 01101001 01101110 01100111 00100000 01101000 01100001 01110100 01100101 00100000 01101101 01100101 01100011 01101000 01100001 01101110 01101001 01100011 01100001 01101100 00100000 01110011 01101000 01101001 01110100
I knew there was a reason why I understand the above and why I don't know a Phillips from a Stevens screw driver.
I wanted to paint the section the rear foot rests attach to, got a big fuck off bolt half way out before realising it held the swing arm on!!!
Chain guard bolt fucked, sheered off, had to drill it out, re thread the hole.
Rear sprocket nut, 3 came off fine, 1 was stuck solid
Pissed it down with rain in the afternoon
Couldn't get the new chain on, couldn't find pliers to set the pin
All back together in the dark with a broken security light that goes off every 60 seconds, rear wheel doesn't spin freely.
Looks like I'm taking the car tomorrow! So pissed off.
Still saved an arm and a leg, if it works.
Islander
PostPosted: 21:17 - 30 Sep 2012    Post subject: Reply with quote
01001001 01110100 00100000 01101010 01110101 01110011 01110100 00100000 01110100 01100001 01101011 01100101 01110011 00100000 01110000 01100001 01110100 01101001 01100101 01101110 01100011 01100101 00100000 01100001 00100000 01100010 01101001 01110100 00100000 01101100 01101001 01101011 01100101 00100000 01100011 01101111 01101110 01110110 01100101 01110010 01110100 01101001 01101110 01100111 00100000 01000001 01010011 01000011 01001001 01001001 00100000 01110100 01101111 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 00111011 00101001
Davenaylor
PostPosted: 21:25 - 30 Sep 2012    Post subject: Reply with quote
And a big fuck off hammer!!
The last post was made 13 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.83 - MySQL Queries: 13 - Page Size: 56.21 Kb
