ignition and backfire problems
Mantzy
PostPosted: 02:09 - 23 Oct 2004    Post subject: ignition and backfire problems Reply with quote
Okay, sometimes it starts when I fire the ignition, other times it does bugger all. Doesn't even tick over. Nothing at all. And then when I get it going and pulling away, when it hits about 7k rpm it backfires. Oh and the left rear indicator doesn't work/keeps blowing.
ANy suggestions would be grateful...other than sell it on on ebay
Current Bikes: 2010 Triumph Sprint ST 1050
Previous Bikes: 2002 Sachs XTC, 1999 Kawasaki ZX6R, 2004 GSX-R 600 K4, 2006 Yamaha XT660X
Odie
PostPosted: 13:51 - 23 Oct 2004    Post subject: Reply with quote
What bike has the problem.
Mantzy
PostPosted: 23:05 - 23 Oct 2004    Post subject: Reply with quote
If you look at my signature you'll see what bike it is, and even a picture too if you want. Sorry if that sounds sarcastic.
Mantzy
PostPosted: 14:00 - 25 Oct 2004    Post subject: Reply with quote
can no-one help?
Finglonga
PostPosted: 15:39 - 25 Oct 2004    Post subject: Reply with quote
I think the above sealed your fate. Rolling Eyes
Andy Sez....
F.Y.Y.F.F.
Mantzy
PostPosted: 19:55 - 25 Oct 2004    Post subject: Reply with quote
Yeah, I know...I'm sorry! When I wrote it I was being a miserable git. I apologise. Hope I didn't cause any offence. Could someone help me though? I've got a Sachs XTC and it keeps backfiring in first while I'm pulling away and i have to bump start it all the time as the leccy start won't work. Don't think it's a specific problem with XTCs in general...and the garage I go to cost a bloody fortune in labour costs, so don't really want to go there if I can order the parts and fix it myself.
Any hints?
PostPosted: 00:35 - 26 Oct 2004    Post subject: Reply with quote
Certainly sounds electrical. You sure Sachs isn't an Itallian company in disguise? Laughing
Well, could be any number of things. I think a systematic approach is best.
First off. Idiot switches. I am willing to bet that bike is riddled with them. There will be one under the clutch and one at the sidestand which act as 'safety interlocks' to stop you 1) riding off with the sidestand down. and 2) Attempting to start the bike in gear without the clutch pulled in. Either could have gone tits-up. Sidestand switches are a favourite. Unless you are a complete numpty who is going to ride off with the stand down more than once (you always do it once), solder the two wires that go into the switch together and shrinktube them to bypass the switch, if it isn't causing a problem now, you can bet it will (and on a cold dark night in the middle of nowhere).
Battery? it is the time of year for spontaneous battery death. Try it with a different battery on (or jump starting it from a car). If this works, buy a new battery. We recently had a problem with my mates bike, you could turn it over on the starter with no-joy. Changed the battery and away she went.
Regulator? voltage regulator randomly dumping current to earth? measure the voltage accross the battery as you rev the bike. It should go up to around 14 volts.
Solenoid? Follow the big fat wire coming from the battery positive, it should connect to the solenoid, there will be other wires attaching here too (sometimes even a fuse). Check all the terminals are free from corrosion as they are prone to it.
I would then check the usual plug, cap, lead, coil combo. Then a systematic check and clean of all the terminals you can find. Finally worry about the CDI unit.
I bet it is the sidestand switch Wink
Mantzy
PostPosted: 20:46 - 26 Oct 2004    Post subject: Reply with quote
Nope, neither of them. Riding off with stand down is impossible...uber-spring pulls it back with toe-breaking power. And there just isn't one under the clutch. It PREFERS to start when in gear at the moment.
Shouldn't be, it's a newish battery, but will try charging it again
It has got worse this evening. Before it only backfired in 1st and 2nd which was bad enough, now it's backfiring throughout. May leave work early tomorrow to take it in to the shop. I can't ride it as it is. Everytime it fires it jolts forward, not very nice on roundabouts. I can get them to fix my left rear indicator while they're at it. Keeps on blowing. I'm sure its all fuse related. This all started when I changed my indicators to Motrax ones.
It's getting me exceedingly pissed off thats for sure. I can't sell it in its current condition.
PostPosted: 21:05 - 26 Oct 2004    Post subject: Reply with quote
I had a bike that developed a peculiar fault assosciated with the indicators when one phase of the rectifier broke down. The flasher come on (with the switch off) and every time it flashed, the engine cut-out.
I have no idea to this day why it happened.
Kram
PostPosted: 21:41 - 26 Oct 2004    Post subject: Reply with quote
i would say (after rebuilding bike electrics). the right rear indicator blowing would either be a bad earth (which would also result in backfires as the CDI + generator cannot generate a charge cos theres no where for it to go). or the solenoid coulod be bad. i've gone through 2 in a year (i should really fix that.. oh well bikes totaled now;)). these, you just undo the 2 bolts, and attack it with a wire brush. on the terminals, to remove any crap that's there.
there also might be a lose wire shorting on the fram (possible on the indicator loom. just check this one over as well. is the bike kept out of rain, or is it always outside (your generator might be sat in a puddle of water Evil or Very Mad )
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
The last post was made 21 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 68.29 Kb
