Squeaking Brake
AcID ZeR0
PostPosted: 20:38 - 26 Oct 2004    Post subject: Squeaking Brake Reply with quote
My front brake has started squeaking when I pull up I depend on the front disk brake a lot as my rear drum brake isn't half as effective. Is there anyway I can stop it squeking without tampering as I don't feel confident taking the brake apart.
goony
PostPosted: 20:44 - 26 Oct 2004    Post subject: Reply with quote
bit of copper grease on back of pad`s usually help`s and check the wear.
Retro-Man
PostPosted: 20:45 - 26 Oct 2004    Post subject: Reply with quote
short of removing and deglazing the pads
I am assuming you have checked that there is in fact material left on the pads
You could try blasting out the caliper area with either an aerosol brake cleaner or carefully using your local jetwash
this might help Thumbs Up
https://domharnessphotography.webs.com
mr.z
PostPosted: 20:50 - 26 Oct 2004    Post subject: Reply with quote
Get into the habbit of useing both, i know the feeling, i'd stand bugger all chance stoping on just my rear brake, but then i can say the same for the front...
Squeeking is not anything to worry about, there will be a way of checking the pad wear, appart from that, if your still stopping then dont worry...
Haveing knowlageble friends will make your life easyer, or a trused mechanic wou can have a look/listen for you...
+ Like retro man said, break cleaner is your friend Smile
Flip
PostPosted: 22:58 - 26 Oct 2004    Post subject: Reply with quote
Don't forget that the rear brake only gives a third of the braking power and should never be used alone. (The rear disc / drum brake is tiny) . I only use it for hill starts and e stops. Some of my biker mates are the same Thumbs Up
aqualung1
PostPosted: 23:32 - 26 Oct 2004    Post subject: Reply with quote
if not confident about brakes, understandabble
please try and find a knowledgeable mate and then check all are clean and if necessary copper grease rear of pads.
it could be as said if relying heavily on front very worn down
please if not sure dont, a squeeking brake is better than no brake
good luck
"still no idea where poohsticks bridge is"
www.bosunsbikes.com
haGGard
PostPosted: 00:50 - 27 Oct 2004    Post subject: Reply with quote
I have squeeky brakes too. I'll try some copper grease, but i need to ask, where is the rear of the pad? Confused Is it the part that rubs on the disk?
PsychoHippy
Jammy Git
PostPosted: 01:01 - 27 Oct 2004    Post subject: Reply with quote
Definately not the part that rubs on the disk.
I spend all my money on bikes and beer, the rest I simply waste!
PostPosted: 01:31 - 27 Oct 2004    Post subject: Reply with quote
No! Shocked Shocked If you did that you might as well not have brakes!
The rear of the pad is the other side, the side away from the disc. Thumbs Up
haGGard
PostPosted: 01:35 - 27 Oct 2004    Post subject: Reply with quote
How would that stop the squeeking? Its the rubbing thats making the squeeking. Confused
PsychoHippy
Jammy Git
PostPosted: 02:08 - 27 Oct 2004    Post subject: Reply with quote
The squeaking is often caused by vibration between the rear of the pad and the piston that pushes it onto the calliper.
stryker
PostPosted: 08:46 - 27 Oct 2004    Post subject: Reply with quote
Recently on here there was a chap who had his front wheel lock. It was suggested his pads were so badly worn it poped out and got jammed between the caliper/pad holder and the disc.
I'd check they are not overly worn if I were you.
Now what?
The last post was made 22 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 72.31 Kb
