Throttle cable or blown engine?
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Kram
PostPosted: 21:52 - 26 Oct 2004    Post subject: Reply with quote
this could possibly be a kink in the throttle cable, have you straightened the cable again?, and does the engine tick over normally. as you may have knocked the carb(s) a bit. it might just need a bit of a gentle knock;)
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
loply
PostPosted: 22:02 - 26 Oct 2004    Post subject: Reply with quote
Air leak?
PostPosted: 23:50 - 26 Oct 2004    Post subject: Reply with quote
Would expect a throttle cable being damaged could be felt, and should not affect throttle response (just how hard you have to pull the throttle).
Possible you have damaged the engine. Electrics often either work or don't. I would hope that it would be carb related. Might be worth taking the carb off and apart and checking it out to make sure nothing is dislodged.
PostPosted: 00:47 - 28 Oct 2004    Post subject: Reply with quote
The floats move in the float chamber. They should not really rattle although you should hear them move. Also the bits you need to clean out are the jets and they are got to by taking off the float chamber (single 14mm headed bolt).
PostPosted: 01:02 - 28 Oct 2004    Post subject: Reply with quote
The pilot jet is on the side of the carb, either towards the front or back depending on if it is a air screw or mixture screw.
https://www.bikechatforums.com/viewtopic.php?t=17124
The last post was made 21 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.19 - MySQL Queries: 13 - Page Size: 73.09 Kb
