| Skyblue |
 Skyblue Renault 5 Driver
| ocatoro |
 ocatoro World Chat Champion
 Posted: 00:01 - 02 Oct 2012 Post subject: |
you can fit them to anything....
but i'd say that's not really the best way to be riding
all you are doing is avoiding learning how to use the clutch and throttle properly... ____________________ CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None but shed project H100 (first bike )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 00:47 - 02 Oct 2012 Post subject: |
Looks like this as stock?
https://www.seastarsuperbikes.co.uk/Kawasaki%202011/W800/w800%20hbar.jpg
See if there's any sort of end cap on the throttle and clutch tubes. If not, you'll just have to slice the ends off (or carefully cut a hole in them), then you can fit "universal bar ends" (Google for that) into the handlebar tube.
While you're about it though, have you considered fitting heated grips? I'd thoroughly recommend them if you're planning to ride through winter, and that bumps the operation up to the level where you can palm it all off to a garage with your Man Honour intact, and say "Oh, and just pop these bar ends in while you're about it, my good man."  ____________________ Biking is 1/20th as dangerous as horse riding.
| Matt B |
 Matt B World Chat Champion
| snikks |
 snikks Spanner Monkey
 Posted: 11:32 - 02 Oct 2012 Post subject: |
Concur with others, you probably can fit bar ends without much hassle, but it's probably a better idea to learn to control the bike better.
From what you're describing, it sounds to me as if your problem may be that you're leaning on the handlebars to support yourself, making fine throttle control very difficult as you have your weight on the throttle. Therefore you've trained yourself to lean partially on the bar end, and use your hand/fingers to adjust the throttle, to make it easier.
I could be wrong, but I suggest this because it's what I used to do, when I very first started riding, having got used to riding racing bicycles with very leant forward positions. Gave me terrible hand cramps when I rode slow for too long.
What you should be doing, is being very light on the bars, support your weight on the seat, that's what it's there for. Grip the tank with your knees, and you'll find you can control the throttle far better when you're not leaning on it. ____________________ - CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F |
| psychodame |
 psychodame Nitrous Nuisance
 Posted: 11:38 - 02 Oct 2012 Post subject: |
| snikks wrote: | it sounds to me as if your problem may be that you're leaning on the handlebars to support yourself, making fine throttle control very difficult as you have your weight on the throttle. Therefore you've trained yourself to lean partially on the bar end, and use your hand/fingers to adjust the throttle, to make it easier.
What you should be doing, is being very light on the bars, support your weight on the seat, that's what it's there for. Grip the tank with your knees, and you'll find you can control the throttle far better when you're not leaning on it. |
This sounds as if I'm doing this in part too... I get terrible hand cramps but have put it down to an age thing rather than bad habits, but having just read this it's entirely possible that it's a bit of both. I'm going to try your suggestions all the same, as gripping the tank with my knees seems a better plan than being tempted to do a death grip on my handlebars which I still do at times when slow riding.
As ever, thanks! I always seem to learn useful stuff on here. ____________________ Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence or stupidity.
-Anonymous |
| Alpha-9 |
 Alpha-9 Super Spammer
| stinkwheel |
| SamWise72 |
 SamWise72 Trackday Trickster
| Alpha-9 |
 Posted: 13:12 - 02 Oct 2012 Post subject: |
| stinkwheel wrote: |
I disagree with all of you.
Slow speed control is all about looking where you are going, not at your hands and the speed is controlled using the back brake. |
I think if you can't ride slowly without using the clutch you've not mastered slow speed control.
not that i'm amazing at it, depends how slow is slow, I try to avoid putting my feet down for as long as possible though
But sometimes that makes me wobble the bars left and right to keep steady
Noone actually looks at their hands lol surely?, speedo and revs maybe, they are distracting
Yes the CBT teaches that as above, had the same thing, but I think that's for ease rather than getting 'better' at it
teflon-mike had a post about it in the BCF abyss somewhere
Why do I space my lines like this, looks really annoying
Dont really use my back brake in slow speed, it's too squeaky and rubbish, need to sort it  ____________________ Fzr-600 1999 |
| Polarbear |
 Polarbear Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:42 - 02 Oct 2012 Post subject: |
If he doesn't fit bar ends, how is he going to attach the tassles? Bigger picture, chaps.
On my CBT, they had us do lap after lap at high throttle and speeding up and slowing down using just the clutch, and then maintaining a constant speed by dragging the clutch while revving the nuts off the bike. I thought it was heavy handed at the time, but it was actually excellent training. ____________________ Biking is 1/20th as dangerous as horse riding.
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 14:51 - 02 Oct 2012 Post subject: |
I use the back brake, although at very low rpm a bit of clutch slip and a whiff of revs helps smooth things out.
To the OP though, cant you just use your index finger against the throttle body to achieve the same effect?
Zen Dog ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| MCW |
 MCW World Chat Champion
| stinkwheel |
| Skyblue |
| cimbian |
 cimbian World Chat Champion
 Posted: 18:10 - 02 Oct 2012 Post subject: |
Busy engine, slip the clutch and only cover the rear brake for the occasional dab if needed. Worked for me. Also really important for major to minor left and right junctions. ____________________ 22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker |
| Matt B |
| barrkel |
 barrkel World Chat Champion
 Posted: 12:11 - 03 Oct 2012 Post subject: |
Doing it all with the throttle will certainly teach fine throttle control. But if the bike isn't smooth at very low revs, it may not be feasible to do neatly without also using the back brake quite a bit.
A problem once I had was moving the handlebars changed my position on the throttle a little - I wasn't in a death-grip or anything, light as can be, but it still changes all the angles up and it's hard to keep everything constant. So now I put my index finger on the front brake lever to create a fixed reference point for the rest of my hand.
Unfortunately that risks panic-pulling the front brake, especially if you're a beginner, so I wouldn't recommend that form for the test.
On my scooter, for really fine control I use piles of rear brake, especially since it doesn't have a manual clutch. Biggest thing that rear brake gives you is keeping the transmission taut; transmission slack, if you ever let the rear wheel go faster than the engine, can make things really jerky. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Islander |
 Islander World Chat Champion
| baggylastard |
 baggylastard Nova Slayer
| Islander |
| Ribenapigeon |
 Ribenapigeon Super Spammer
 Posted: 14:17 - 04 Oct 2012 Post subject: |
Bar ends just make the bike two inches wider anyway. Screw that I value my super hero filtering action too much.
I feel sick here's someone who's got a full licence and still can't intuitivly control their bike at slow speed while I'm still on L plates and when in traffic hardly have to think about.
Roll on my next theory test! |
| Alpha-9 |
The last post was made 14 years ago. Instead of replying here, would creating a new thread be more useful? |
