Dead Gamma :( Please Help
gammamanuk
PostPosted: 23:02 - 26 Oct 2004    Post subject: Dead Gamma :( Please Help Reply with quote
My poorly RG suzuki gamma 125 has died.
Ive not been on here for months.
What happened was i come over a hill, a bloody short steep up and over style hill to quick and a car stopped in front, i lost the front end and bang down went me and the bike.
This is a 1987 e reg half faired gamma, so the headlight bracket got bent,clocks got smashed, tank got serverely dented, water pump casing now has a hole, indicators snapped, panels cracked, levers snapped, brake fluid reservoir sanded down, etc etc
Now it ran fine once i slapped a load of car body filler on the water pump casing she ran fine, took me to work and back a few times, completely jailbait to ride but it beats payin 6 pound for a taxi there and back.
One day i just came down the dual carrigeway to work and it died, just cut out, neeooooooor, pfffft and then wouldnt go again.
Had fuel,spark etc, it now starts after a load of kickstarting, sweating and running down the road with it in gear like a idiot, but it effortlessly ticks over for 5 seconds then dies out, if you give it any sort of throttle it drowns itself and chugs and stalls.
Cleaned carb more times than i care to remmeber, changed the spark plug the lead etc, seems to have compression.
the bike would never run with its element in the air filter, it would always misfire like a sod so i left it out, sounded so nice though and the carb is all standard and standard exhaust, carb is set up fine.
Now 3 months on its sat outside next to my car, partially stripped, battered,rusty,wet,damp bruised and going no where, now i want to get it back up again running well, so whats wrong with it?
Its been owned by 2 boy racers and subject to 70mph stints down 30 - 40 limit road most of the last 8 months, 30 thousand on the clock so its had a good thrashing , before that it sat in a barn for 8 years after some old geezer decked it through a hedge.
Any ideas why it won't run? I fancy getting the top end off and having a look at the barrel/rings/piston
Where can i buy parts for these bikes online??
Frost
PostPosted: 23:06 - 26 Oct 2004    Post subject: Reply with quote
Check over the eletrics, perhaps the battery has given in to the weather and thrashings. otherwise the engine may just be down on compression, and have trouble starting and running.
gammamanuk
PostPosted: 23:08 - 26 Oct 2004    Post subject: Reply with quote
But if its sparking it should be fine, its just strange how it died like that thats why i think the top ends gone, my nsr did the same.
electrics would play up for a while surely and give you grief wouldnt they?
PostPosted: 23:16 - 26 Oct 2004    Post subject: Reply with quote
I would check the top end out for damage. Running without an air filter will allow any old cack into the engine, and one piece of grit could quite easily score the barrel.
gammamanuk
PostPosted: 23:30 - 26 Oct 2004    Post subject: Reply with quote
Thanks keith, i never could understand why it wouldnt run with a air filter element in? its just got the box on at the moment minus the top piece and the foam, thats how it always was.
its still taxed.motd till march/april nexyt year aswel Sad
PostPosted: 23:42 - 26 Oct 2004    Post subject: Reply with quote
Suspect someone has played with the jetting and left it running rich, and the air filter richens it up even more.
gammamanuk
PostPosted: 00:45 - 27 Oct 2004    Post subject: Reply with quote
Yerh, the main jet is standard, playing with the needle height or the mixture screw doesnt affect it much makes it worse if u play with the needle height
one strange thing is when you take off the float bowl beside the main jet is a little jet, it has a black rubber bung type ting covering it if you pop the black bit off you can see a jet inside? Think soneone said it was a pilot jet? its a mikuni carb.
Top ends coming off tommorow.
california_rookie
PostPosted: 00:58 - 27 Oct 2004    Post subject: Reply with quote
Definitely sounds interesting. Best of luck to ya. Thumbs Up
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
The last post was made 22 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 56.6 Kb
