bike will spark, but starter motor will not turn
mikey909
PostPosted: 14:36 - 03 Oct 2012    Post subject: bike will spark, but starter motor will not turn Reply with quote
i just want to check so that i dont purchase the wrong part. when i press the ignition, i get the click from the relay, i get a spark from the HT coil to the plug, but i get no response from the starter motor. initially i thought it was the starter that was the problem, but i found that after a few tries at the ignition, the battery would die and i would have to charge it again. now the battery has become really hot and has developed a swelling at the side. although when fully charged the battery reads 12.7v, i do believe that it doesent have enough power to drive the starter motor. alongside the battery, would i also have to replace the starter motor as well?
mikey909
PostPosted: 16:14 - 03 Oct 2012    Post subject: Reply with quote
_Iain_ wrote:
It's a little odd you're getting a spark from the thing without it spinning over.
Does the engine turn over & bump start? If not it may be seized. & the starter could be perfectly fine. Have you removed the starter motor itself & checked that it spins freely? Does the starter spin up if connected directly to a known good battery??
Either way sounds like you've just held the starter button in without it spinning over till the batterys boiled itself to death.
youre right, i think i have just burned the battery right out Sad as for the starter motor, i dont have another battery to test it. however, i have opened the starter up, and instantly get a kind of burning smell . it also looks like the insides have broken. i have included an image.
mikey909
PostPosted: 22:20 - 03 Oct 2012    Post subject: Reply with quote
_Iain_ wrote:
Image fail Laughing
Does the engine spin or is it locked solid?
IF the engine seized then holding the button will have burnt the motor out, then the battery.
Whilst they now need replacing, you could put the new parts in and find that the bike just burns out all the new parts. You could find a starter clutch has seized and spun the starter up to silly speed & fried it that way? Impossible to tell.
Put on centre stand, remove plugs, remove starter, first gear and see if the engines actually moving by spinning the back wheel.
i cant hear the engine spinning up. just the relay clicking when i press the ignition. the piston was moving when i had align the timing cog. the starter is most definately burned out as well.
its a moped/scooter so i cant manually adjust the gears unfortunately.
mikey909
PostPosted: 19:16 - 05 Oct 2012    Post subject: Reply with quote
_Iain_ wrote:
Right,
Does it fire on the kickstart. You need to find out if the engine spins over or if its locked solid. Not the starter, the engine. You may have to pull a cover off and get a socket/spanner on the end of the crankshaft if there isnt a kickstart. The aim of the game isnt to start it, but to find out if the crankshaft will rotate without any problems. It will be very stiff unless the sparkplug is removed.
The more you press that button the more damage you are doing to the bike. If you replace the battery & starter & the engines locked up then you'll have another burnt out battery & starter within 30 seconds & have wasted £££ on a fucked engine.
The fact you've boiled a battery without realising makes me wonder if the "timing cog" you've altered was done correctly. If you've altered a cam chain & seized the engine, bolted it back together & held the starter till it burnt out wondering why it wouldnt start then its a whole new engine you need. But again, i've got no idea. When did the thing stop starting?? After you'd messed with it & had it running or before?
To the point,
Stop pressing the starter.
Find out if the crankshaft spins by hand without the plug in.
List up EVERYTHING you've touched on the engine & transmission.
I cant help with half the story.
i had checked that the crankshaft was turning a while ago. it was turning ok. anyway, it seems like its locked solid, i only have to take the water pump case off and turn the flywheel as it will turn the crankshaft as well. i shall post up my findings...
mikey909
PostPosted: 16:39 - 09 Oct 2012    Post subject: Reply with quote
right, ive tried turning the crankshaft. it will turn, then i'll hear a metal to metal clang, and i can no longer turn the crankshaft. im going to pull the engine apart anyway and see what i can find...
tahrey
PostPosted: 17:03 - 09 Oct 2012    Post subject: Reply with quote
Vincent wrote:
Wouldn't that just drain the battery?
Not necessarily. They're not meant to be left shorted like that... as if someone's dropped a spanner bridging the terminals. Normally the fuses would protect it from this kind of abuse, but... sometimes the starter isn't actually fused because of the huge, but momentary drain it puts on the system. The user is expected to recognise that holding the button when the starter doesn't turn is unproductive, but also expected to be a bit pissed off if cranking a crotchety engine for 30 seconds on a cold morning causes the fuse to pop.
(Erm? I think? Or maybe I'm talking out my arse and the fuse has either been replaced with one that's rated far too high, or been bypassed entirely during a botched rebuild?)
Engine or starter jammed for some reason and button held = classic electric motor stall = ALL of the power it would otherwise be sending to the crankshaft gets dissipated as heat in the windings = motor gets very hot very quickly as several hundred watts are shoved into a fist-sized object = things melt and hopefully burn out, going open-circuit. Quite possibly in this case they instead melted and created a straight short between the two battery terminals, with all of the available current therefore being dissipated in the wiring and the electrolyte. And as the main limiter in the equation would be the battery's own rather low internal resistance (rather than the relatively high resistance of the motor / lights / etc), the current is potentially very high indeed.
It doesn't even have to get super hot itself to suffer from elevated internal pressure and deform. Hydrogen is a typical byproduct of discharging a lead-acid battery, and there are small vent holes to let out the typical buildup of it (this is why unsealed batteries occasionally need topping up with water). But only small ones to reduce the spill and contamination risk. Too much hydrogen (and steam?) produced all at once from rapid discharge = very high internal pressure = the thin plastic walls bowing outwards.
The above might even be why the plug is sparking despite the engine not turning over - unless the crank just so happens to be positioned just at the right position before TDC on the ignition stroke to trigger the ignition system each time. Or, it could be the short is such that it's simulating the coil / whatever passes for it as the connection is made and broken.
tahrey
PostPosted: 17:10 - 09 Oct 2012    Post subject: Reply with quote
Is that with the sparkplug out?
Pint of virtual bitter says that you've misjudged the cam timing and the clang noise is the piston banging against an open valve.
At least, hopefully that's what it is. Otherwise the next most likely thing is you've dropped something in the crankcase.
If so, then you've actually got off quite lucky, though you might not think so with a knackered motor / battery (/ wiring). It might have been just slightly off, started, and ended up causing a lot more damage as they warmed up and whacked together with more force. The starter can only smack the bits together "so" hard. Just need to readjust the cam timing, and replace the broken bits, which are all essentially "external" to the oily stuff.
Did it turn on the starter *at all* the first time you tried it, even a little tiny bit?
mikey909
PostPosted: 12:45 - 10 Oct 2012    Post subject: Reply with quote
much appreciation for you help guys Very Happy ive removed the engine, taken the cover off the cam shaft, and removed the cam chain (spark plug has been removed also). ive found that when i hold the cam chain loose, i get that same clang sound, and the rotation stops. but when i hold the chain taught and rotate the engine, its perfect. i get the feeling that i probably messed up somewhere on the cam chain. yep i agree, its all a learning curve as the bike has been built from frame up...i'll just try not to burn the bike down this time Crying or Very sad
tahrey
PostPosted: 13:04 - 10 Oct 2012    Post subject: Reply with quote
^ This.
I've spent so much time amongst a world full of brushless AC motors and the like I forgot that yer typical cheap starter motor is likely to just be a simple brushed-DC affair.
Which is quite literally a free-to-rotate heating element surrounded by a strong magnetic field that, through the wonders of electromagnetism, means that all the energy being transported by the electrons gets converted into kinetic (movement) rather than internal (heat) energy in the material it's flowing through.
Stall one of those, it heats up in pretty short order, and as the battery forms the other end of the loop, it suffers a similar effect. The saving grace is that, although the resistance is quite low in order to get the most power going through the motor (power = current x voltage, and current = voltage divided by resistance), it's still a looong length of wire, so it's nowhere near as low as a spanner dropped across the terminals would be. You have to abuse it for quite a while before it actually gets to the battery-killing point.
tahrey
PostPosted: 13:07 - 10 Oct 2012    Post subject: Reply with quote
Oh ... chain not tensioned up somehow?
So, one presumes, if you've followed proper procedure and timed the engine up to TDC (so the valves are shut anyway), it's managed to turn the cam loosely at first, enough to open one or other of the valves enough to interfere with the piston, but then started slipping and left the valve open far too long?
mikey909
PostPosted: 16:35 - 10 Oct 2012    Post subject: Reply with quote
yes. i think that, thats where i was going wrong. the tdc, and the head cog alignment was ok. i rekon there was not enough tension on the cam chain. the slackness was causing the chain to get caught up, and that was the "clang" i was hearing.
however, i have now made the necessary adjustments, and im able to turn the crankshaft with no noise. there is an element of stiffness though every now and again when the notch on the camshaft hits the valve to open it up, is this normal?
mikey909
PostPosted: 08:46 - 11 Oct 2012    Post subject: Reply with quote
_Iain_ wrote:
If it's just valve springs compressing then you should be feeling two bits of stiffness to every one rotation of the camshaft.
Once for the exhaust valve, once for the inlet.
However - if one valve is bent up then that valve will get very stiff when it opens or shuts, and the other will operate smoothly.
If you only feel one bit bit of stiffness this could be potential bad news.
On the other hand you might just have left the sparkplug in and be feeling the compression stroke. Thumbs Up
yes thats the stiffness im feeling (no pun intended. It occurs only when the notches are being raised. Other than that, rotation is smooth. I have a starter motor on the way, so we'll see what happens when i try to start the bike this time....and remember NOT to press and hold the ignition if it fails to start.
tahrey
PostPosted: 11:19 - 11 Oct 2012    Post subject: Reply with quote
If you find it difficult to line the cam up so it's in the dead centre of the "stiff" area (ie with the tallest bit of the lobe pushing the valve fully open) even with the plug out - because once you go a little past in either direction the spring pushes it round to the flatter bit - and it does it evenly for both valves, then that's probably a good sign.
(It's a right pain trying to line the cam up on my CG so I can do the clearances because of this ... it spins so far past the inlet valve opening point I have to backtrack to line it up on TDC Very Happy)
Mikey, were you editing your post at the same time I was submitting mine? It seems we've ended up duplicating info "in our own words", sort of. I didn't see all the part surrounding the picture of the toaster elements before!
mikey909
PostPosted: 19:40 - 18 Oct 2012    Post subject: Reply with quote
right, ive fitted a new stater motor. when i pres the ignition, the motor will turn, but then will get stuck in the outer cog (i let go of the ignition this time). only once, i heard the crackshaft move when i pressed the ignition. i can move the crankshafe by hand though, so its not seized.
tahrey
PostPosted: 11:12 - 22 Oct 2012    Post subject: Reply with quote
What bike was it again?
Having just put my CG (mostly) back together, I found that the lower idler cog for the starter - the one that meshes onto the flywheel ring - will happily go in either way round despite being two slightly differently sized gears welded together on a common axle, and will spin just fine in seeming mesh with said ring.
However when you then pop the starter / stator assembly back on, and insert the upper idler gear (one large, small toothed gear welded on a small, large toothed one), it will jam solid unless you've put the lower one in the right way.
Guess which way I put it in... yep. Had to take all the bolts, wires and covers back off, unhitch the assembly, turn said cog around 180 degrees, and then put it all back together, at which point everything was just dandy.
And the brilliant thing is, thanks to the flywheel cog being on a freewheel mechanism, you can't even tell unless you either try the starter or attempt to turn the crank backwards a bit. You just assume it's in right because, of course, the lower gear wouldn't fit in place if it wasn't the right way round, and the upper one wouldn't fit inside it's own slot if the lower gear wasn't properly aligned ... right? Wrong. Evil or Very Mad
By the way, have you any way of kick / bump / pull-starting the engine without the electric starter? Just to make sure it will actually go and there's nothing seriously dragging on it?
You have put oil in, right?
(Yeah, guess what else I didn't do before my first test-start ... luckily realising within a couple seconds and killing the ignition straight away. The top end and piston/barrel had been dosed, but the bottom end was reliant only on whatever residual was left in the bearings themselves...)
mikey909
PostPosted: 17:30 - 24 Oct 2012    Post subject: Reply with quote
ive managed to solve the issue now. it was the outer pulley that was not aligned properly, causing the starter pinion to become stuck once it tried to turn the outer gear.
however, with that problem solved, another crops up. the engine will now try to start up, but wont fire. there is fuel in the bike, and it is going to the carb (i have clear hoses), and there is motor oil in the bike. for the record, the bike is a gilera dna 125 (4 stroke)
The last post was made 13 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 2.54 - MySQL Queries: 13 - Page Size: 155.52 Kb
