| mikey909 |
 mikey909 Two Stroke Sniffer
| _Iain_ |
 _Iain_ Banned
 Posted: 15:14 - 03 Oct 2012 Post subject: |
It's a little odd you're getting a spark from the thing without it spinning over.
Does the engine turn over & bump start? If not it may be seized. & the starter could be perfectly fine. Have you removed the starter motor itself & checked that it spins freely? Does the starter spin up if connected directly to a known good battery??
Either way sounds like you've just held the starter button in without it spinning over till the batterys boiled itself to death. ____________________ Please be aware that the above post may be full of complete nonsense.
| mikey909 |
| _Iain_ |
 _Iain_ Banned
| mikey909 |
| _Iain_ |
 _Iain_ Banned
 Posted: 23:45 - 03 Oct 2012 Post subject: |
Right,
Does it fire on the kickstart. You need to find out if the engine spins over or if its locked solid. Not the starter, the engine. You may have to pull a cover off and get a socket/spanner on the end of the crankshaft if there isnt a kickstart. The aim of the game isnt to start it, but to find out if the crankshaft will rotate without any problems. It will be very stiff unless the sparkplug is removed.
The more you press that button the more damage you are doing to the bike. If you replace the battery & starter & the engines locked up then you'll have another burnt out battery & starter within 30 seconds & have wasted £££ on a fucked engine.
The fact you've boiled a battery without realising makes me wonder if the "timing cog" you've altered was done correctly. If you've altered a cam chain & seized the engine, bolted it back together & held the starter till it burnt out wondering why it wouldnt start then its a whole new engine you need. But again, i've got no idea. When did the thing stop starting?? After you'd messed with it & had it running or before?
To the point,
Stop pressing the starter.
Find out if the crankshaft spins by hand without the plug in.
List up EVERYTHING you've touched on the engine & transmission.
I cant help with half the story. ____________________ Please be aware that the above post may be full of complete nonsense.
| Vincent |
 Vincent Banned
| _Iain_ |
 _Iain_ Banned
| Vincent |
 Vincent Banned
| mikey909 |
| mikey909 |
| tahrey |
 tahrey World Chat Champion
| tahrey |
 Posted: 17:10 - 09 Oct 2012 Post subject: |
| mikey909 wrote: | right, ive tried turning the crankshaft. it will turn, then i'll hear a metal to metal clang, and i can no longer turn the crankshaft. im going to pull the engine apart anyway and see what i can find... |
Is that with the sparkplug out?
Pint of virtual bitter says that you've misjudged the cam timing and the clang noise is the piston banging against an open valve.
At least, hopefully that's what it is. Otherwise the next most likely thing is you've dropped something in the crankcase.
If so, then you've actually got off quite lucky, though you might not think so with a knackered motor / battery (/ wiring). It might have been just slightly off, started, and ended up causing a lot more damage as they warmed up and whacked together with more force. The starter can only smack the bits together "so" hard. Just need to readjust the cam timing, and replace the broken bits, which are all essentially "external" to the oily stuff.
Did it turn on the starter *at all* the first time you tried it, even a little tiny bit? |
| _Iain_ |
 _Iain_ Banned
 Posted: 23:37 - 09 Oct 2012 Post subject: |
| tahrey wrote: | Pint of virtual bitter says that you've misjudged the cam timing and the clang noise is the piston banging against an open valve.
At least, hopefully that's what it is. Otherwise the next most likely thing is you've dropped something in the crankcase. |
Hence why, when rebuilding an engine, altering ANYTHING to do with valve gear, timing belts/chains or bits what move inside the engine you ALWAYS rotate the engine by hand first by putting a socket on the end of the crankshaft & spinning it over. Turn it over at least three times listening for any clunks, bangs, and feeling for any stiffnes. If there is anything the engine is likely to suffer serious damage when it's cranked.
Had your engine actually fired the piston could have hit an open valve at several thousand RPM, smashing the top of the piston in, scuffing the shit out of the barrel & mashing half a valve into the top of the head. Whilst it span down & you pulled over if you diddnt get the clutch in quick enough you could very well lock the back wheel up & come off!
Point two.
When something doesnt work first time, try it again. Do NOT, EVER EVER EVER just press and hold the button till smoke, burning & shit catches fire. Investigate the problem. Is there battery voltage? Is the battery connected? Is the starter solenoid connected & clicking? What happens if the starter solenoid is shorted out? If i remove the starter motor does it spin freely? With the starter motor out does it spin up? Not, press. Oh doesnt work. Press and hold till the smoke comes out. I've done some pretty stupid shit, but have NEVER boiled a battery by holding it on like that! damn!
However, it's a learning curve. Now you know, now you'll tell your mates and a few people will benifit from the misfortune. So all is not lost.
Back to the starter causing a short to the batttery;
Internals look a bit like this;
https://www2.mae.ufl.edu/designlab/Class%20Projects/Background%20Information/Electric%20DC%20motors_files/image004.jpg
Which simplified into block diagrams look like this;
https://gaullyblog.files.wordpress.com/2011/11/dcmotor.gif
Electricity passes to the brushes. Brushes connect to coils on the armature. When the electricity goes through em they magnetise (think electro magnet) and pull themselves towards the magnet on one side.
At which point the commutator rotates, thus charging the next coil, moving that towards the same magnet, rotating the armature a little more.
Which in turn brings the next one round, and energises that coil. Pulling it again. By which point the motors armature has spun all the way round 360 degrees & the brushes are touching the commutator in a way that engages the first coil, pulling it towards the magnet again & starting the cycle all over again.
The chain reaction is what causes it to spin, which generates heat.
Now.
Assuming we dont let it spin. We jam it solid. powers coming in on one of the brushes, passing through the commutator to the first coil of wire, it earths out on the negative. Now instead of connecting for half a second, then being shut off whilst the other two coils cycle so it can cool it sits there geting hot.
Like one of theese does;
https://airproheatingandac.com/wp-content/uploads/2011/05/Toaster-Heating-Elements.jpg
Course it then gets hotter and hotter and hotter as it's got the battery in a short. The positive current is going through the coil of wire & straight back out the other brush to the earth on the battery. The wiring gets hotter. The commutator cant hack the heat, neither can the brushes. They burn up. Then the wiring starts to burn up. The battery boils....
And you end up with a very expensive repair bill.
HTH  ____________________ Please be aware that the above post may be full of complete nonsense.
| mikey909 |
 Posted: 12:45 - 10 Oct 2012 Post subject: |
much appreciation for you help guys ive removed the engine, taken the cover off the cam shaft, and removed the cam chain (spark plug has been removed also). ive found that when i hold the cam chain loose, i get that same clang sound, and the rotation stops. but when i hold the chain taught and rotate the engine, its perfect. i get the feeling that i probably messed up somewhere on the cam chain. yep i agree, its all a learning curve as the bike has been built from frame up...i'll just try not to burn the bike down this time  |
| tahrey |
| tahrey |
| mikey909 |
 Posted: 16:35 - 10 Oct 2012 Post subject: |
| tahrey wrote: | Oh ... chain not tensioned up somehow?
So, one presumes, if you've followed proper procedure and timed the engine up to TDC (so the valves are shut anyway), it's managed to turn the cam loosely at first, enough to open one or other of the valves enough to interfere with the piston, but then started slipping and left the valve open far too long? |
yes. i think that, thats where i was going wrong. the tdc, and the head cog alignment was ok. i rekon there was not enough tension on the cam chain. the slackness was causing the chain to get caught up, and that was the "clang" i was hearing.
however, i have now made the necessary adjustments, and im able to turn the crankshaft with no noise. there is an element of stiffness though every now and again when the notch on the camshaft hits the valve to open it up, is this normal? |
| Vincent |
 Vincent Banned
| _Iain_ |
 _Iain_ Banned
 Posted: 17:08 - 10 Oct 2012 Post subject: |
If it's just valve springs compressing then you should be feeling two bits of stiffness to every one rotation of the camshaft.
Once for the exhaust valve, once for the inlet.
However - if one valve is bent up then that valve will get very stiff when it opens or shuts, and the other will operate smoothly.
If you only feel one bit bit of stiffness this could be potential bad news.
On the other hand you might just have left the sparkplug in and be feeling the compression stroke.  ____________________ Please be aware that the above post may be full of complete nonsense.
| mikey909 |
 Posted: 08:46 - 11 Oct 2012 Post subject: |
| _Iain_ wrote: | If it's just valve springs compressing then you should be feeling two bits of stiffness to every one rotation of the camshaft.
On the other hand you might just have left the sparkplug in and be feeling the compression stroke.  | yes thats the stiffness im feeling (no pun intended. It occurs only when the notches are being raised. Other than that, rotation is smooth. I have a starter motor on the way, so we'll see what happens when i try to start the bike this time....and remember NOT to press and hold the ignition if it fails to start. |
| tahrey |
 Posted: 11:19 - 11 Oct 2012 Post subject: |
If you find it difficult to line the cam up so it's in the dead centre of the "stiff" area (ie with the tallest bit of the lobe pushing the valve fully open) even with the plug out - because once you go a little past in either direction the spring pushes it round to the flatter bit - and it does it evenly for both valves, then that's probably a good sign.
(It's a right pain trying to line the cam up on my CG so I can do the clearances because of this ... it spins so far past the inlet valve opening point I have to backtrack to line it up on TDC )
Mikey, were you editing your post at the same time I was submitting mine? It seems we've ended up duplicating info "in our own words", sort of. I didn't see all the part surrounding the picture of the toaster elements before! |
| mikey909 |
| tahrey |
 Posted: 11:12 - 22 Oct 2012 Post subject: |
What bike was it again?
Having just put my CG (mostly) back together, I found that the lower idler cog for the starter - the one that meshes onto the flywheel ring - will happily go in either way round despite being two slightly differently sized gears welded together on a common axle, and will spin just fine in seeming mesh with said ring.
However when you then pop the starter / stator assembly back on, and insert the upper idler gear (one large, small toothed gear welded on a small, large toothed one), it will jam solid unless you've put the lower one in the right way.
Guess which way I put it in... yep. Had to take all the bolts, wires and covers back off, unhitch the assembly, turn said cog around 180 degrees, and then put it all back together, at which point everything was just dandy.
And the brilliant thing is, thanks to the flywheel cog being on a freewheel mechanism, you can't even tell unless you either try the starter or attempt to turn the crank backwards a bit. You just assume it's in right because, of course, the lower gear wouldn't fit in place if it wasn't the right way round, and the upper one wouldn't fit inside it's own slot if the lower gear wasn't properly aligned ... right? Wrong.
By the way, have you any way of kick / bump / pull-starting the engine without the electric starter? Just to make sure it will actually go and there's nothing seriously dragging on it?
You have put oil in, right?
(Yeah, guess what else I didn't do before my first test-start ... luckily realising within a couple seconds and killing the ignition straight away. The top end and piston/barrel had been dosed, but the bottom end was reliant only on whatever residual was left in the bearings themselves...) |
| mikey909 |
 Posted: 17:30 - 24 Oct 2012 Post subject: |
| tahrey wrote: | What bike was it again?
ive managed to solve the issue now. it was the outer pulley that was not aligned properly, causing the starter pinion to become stuck once it tried to turn the outer gear.
however, with that problem solved, another crops up. the engine will now try to start up, but wont fire. there is fuel in the bike, and it is going to the carb (i have clear hoses), and there is motor oil in the bike. for the record, the bike is a gilera dna 125 (4 stroke) |
The last post was made 13 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
