| wots |
 wots World Chat Champion
 Posted: 16:36 - 05 Oct 2012 Post subject: Riding in the wet |
No-one can have failed to notice the weather today! I've only been riding a month and midway between Mod 1 & Mod 2.
Literally just before Mod 1 (probably practicing prior to it), something snapped in me and I was able to lean and transfer weight to make the thing go where I wanted it to. Roundabouts were a doddle, even mini's, was able to properly ride round them. Really felt I was getting somewhere.
Now in the wet, obviously I'm being more cautious, but I'm back to swan necking (sometimes severely). In a car I'd push it to the limit of adhesion and find out where the limit is and then feel confident. If I do that on a bike, I'll no doubt lose it.
Is there any safe way to gain the confidence in the wet, it's only really roundabouts I'm struggling with. Left and right turns are ok.
The thing is, Mod 1 was wet, I had no problem. Even blasting through the speed trap and doing the swerve avoidance heading towards a stop in standing water. I don't want to fail Mod 2 because it's a wet day and I'm being too over-cautious. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Flatbadger |
 Flatbadger World Chat Champion
| U_W v2.0 |
 U_W v2.0 World Chat Champion
| banditjohn |
 banditjohn Nova Slayer
| Flamzypants |
 Flamzypants Nova Slayer
| yaigi |
 yaigi World Chat Champion
| barrkel |
 barrkel World Chat Champion
 Posted: 18:50 - 05 Oct 2012 Post subject: |
| yaigi wrote: | What the heck is swan necking?! |
It's when you make a turn by swinging out in the opposite direction first, like a bus or articulated truck would. It reduces the radius of the corner. It's also not recommended by roadcraft, and it can be dangerous if it misleads other road users - as it is, with trucks for whom it is expected, it still kills lots of cyclists.
| wotsthestory wrote: | Is there any safe way to gain the confidence in the wet, it's only really roundabouts I'm struggling with. |
Don't push it on roundabouts in the wet. Especially roundabouts near petrol stations. It's not worth the risk. Extremely easy to lose it without warning. Traction is unpredictable in the wet. Only place you can really open it up is on naturally (i.e. mostly straight) fast roads, and even then you may get the odd slide with only slight lean angles.
Clean wet road has good grip, but you can't see which bits are clean, so ride smoothly to a fairly low expectation of grip. If you push it, you'll probably be lucky until you aren't. I've crashed about 4 times in the wet, lowsides and one highside, and several close calls. I don't push it anymore, especially in urban areas. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| Ellerker9 |
 Ellerker9 Borekit Bruiser
| wots |
 Posted: 19:00 - 05 Oct 2012 Post subject: |
One thing I should point out, is that I'm fairly confident and I'm not afraid of the weather. My intention is to commute as much as possible, in all weather. It's so much easier than the car. I've got a fabulous car, really nice, comfortable with all the gizmos. But on the commute, it's not a patch on my little 125. On the dual-carriageway the 125 starts to become laborious, but I'm not on it for long.
ANYWAY, my point being, I want to save money and not having to leave extremely early to avoid traffic. Even with the earlier stress of concentrating hard, trying to get used to it all, it is less stressful.
I'm not afraid as such, of my Module 2. I went into Module 1 expecting a fail, as I was having a stab to see what happened. I passed without any errors at all. So I'm determined to pass my Module 2 this year, A2 but I'm 38 and the 2 year probation will be good on a bike that sips fuel and whizzes through traffic.
There is a turning near my office, it's very wide, slightly odd camber. But with a manhole cover right in the middle of the natural path. The first time I went over it when it was slightly damp, I couldn't believe how that upset the bike. You can feel the back twitch. I obviously knew about avoiding these sort of things, but I was amazed. I didn't panic, in fact I rarely do, but I'm trying to get it right and ensure that I don't overdo the caution to the point where it actually makes my riding worse, for myself and others. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| barrkel |
 Posted: 19:11 - 05 Oct 2012 Post subject: |
| wotsthestory wrote: | One thing I should point out, is that I'm fairly confident and I'm not afraid of the weather. |
I ride about 30k a year, 365 days a year. I'm not afraid of the weather either; I just wear more waterproof gear. Don't confuse confidence in the wet with pushing your luck. It's easy to build up false confidence IMO. Confidently taking turns within the 99.9% percentile of grip will look nice and smooth, but you will crash 0.1% of the time, and if you ride in all weathers, the numbers work against you. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| wots |
 Posted: 19:18 - 05 Oct 2012 Post subject: |
| barrkel wrote: |
I ride about 30k a year, 365 days a year. I'm not afraid of the weather either; I just wear more waterproof gear. Don't confuse confidence in the wet with pushing your luck. It's easy to build up false confidence IMO. Confidently taking turns within the 99.9% percentile of grip will look nice and smooth, but you will crash 0.1% of the time, and if you ride in all weathers, the numbers work against you. |
Balanced point and well put! Coming home today I had my textile jacket and textile over trousers, along with 'binmen' trousers as well, just really thin reflective but water/crud resistant. Apart from a minor bit of water ingress in the cuff area (to be expected, you can't get it perfect), I was dry as a bone. That includes the A3 at 50mph, the section I ride on is 3 lane 50mph, 50mph is pretty much a minimum not to get into bother, unless you can follow something even then that isn't always ideal.
In fact the only time I got wet, was when I got home locking up the bike and putting the cover on!  ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| s1h |
 s1h Nova Slayer
| cimbian |
 cimbian World Chat Champion
 Posted: 19:50 - 05 Oct 2012 Post subject: |
Your issue of 'swan necking' is possibly due to your caution bringing your vision in very close. Try keeping your head-up and look at where you want to be rather than at the front wheel wondering if it will let go on you.
Look ahead for clues of diesel spillage and keep your braking distances-up and you should be fine. ____________________ 22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker |
| WannaBeDude |
 WannaBeDude World Chat Champion
| wots |
| ScaredyCat |
 ScaredyCat World Chat Champion
 Posted: 20:30 - 05 Oct 2012 Post subject: |
Ride like a granddad in the wet, if it's tipping it down ride even slower.
Don't use your brakes when changing lanes, even something as simple as that can cause an off like this. Taught me a lesson anyway
Andy ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
| wots |
| ScaredyCat |
| Spudly |
 Spudly World Chat Champion
 Posted: 20:51 - 05 Oct 2012 Post subject: |
| ScaredyCat wrote: | Ride like a granddad in the wet, if it's tipping it down ride even slower.
Andy |
Jesus Andy, I know you said you touched the brakes, but it looked like someone kicked the front wheel away. ____________________ The Old Apprentice |
| Magnet |
 Magnet Crazy Courier
 Posted: 20:57 - 05 Oct 2012 Post subject: |
I don't worry about riding in the wet, I just make sure I have my proper gear on so it hurts less if I fall off  ____________________ It’s not that I’m so smart, it’s just that I stay with problems longer.
GPZ600R Sold, Now ZZR600 |
| C1REX |
 C1REX Traffic Copper
 Posted: 21:02 - 05 Oct 2012 Post subject: |
| awrowe wrote: | | ScaredyCat wrote: | Ride like a granddad in the wet, if it's tipping it down ride even slower.
Andy |
Jesus Andy, I know you said you touched the brakes, but it looked like someone kicked the front wheel away. |
I had very similar situation last December (no ice).
I just touched the front brake. My bike broke my ankle. (proper gear on)
I was shocked myself as I was riding at maybe 15mph.
I would recommend to ride like a grandpa in rain and be super gentle with front brake. Use rear first and add front if necessary. You can't brake and turn at the same time on wet. You shouldn't do it on dry but must not on wet.
Better save that sorry. ____________________ MCForum meetup - One of the biggest motorcycle clubs in UK |
| WannaBeDude |
| Alpha-9 |
 Alpha-9 Super Spammer
 Posted: 21:13 - 05 Oct 2012 Post subject: |
Think you'll find the correct braking procedure is I believe 60 front 40 rear using the front to lead, you have a far bigger chance of skidding your rear than losing the front, when the front goes it's gone
Just be gentle on leaning and careful on down shifting too hard
The important thing is not how much brake you use but how quickly you use it, you need to be gentle and gradual and not snatch it else the front will just bottle in the wet
If you were really that gentle with it then perhaps your brake needed adjusting
It takes very little pressure on a disc brake for it to start applying really
andy saw your spill, are those stock tyres? ____________________ Fzr-600 1999
| Flamzypants |
The last post was made 13 years, 124 days ago. Instead of replying here, would creating a new thread be more useful? |
