Removing a dent from a petrol tank?
talcumpowderb...
PostPosted: 18:34 - 06 Oct 2012    Post subject: Removing a dent from a petrol tank? Reply with quote
Hi, just wondering if anyone could suggest the best/easiest way of removing a dent, possibly a suction cup type method maybe? Never tried it before. the dent it self is about 2-3 inches in diameter on a vfr 400 nc30. Thanks. Thumbs Up
Nexus Icon
PostPosted: 18:38 - 06 Oct 2012    Post subject: Reply with quote
You could try pressurising it with an airline through a rubber bung.
Greetings from Shitsville!
talcumpowderb...
PostPosted: 19:14 - 06 Oct 2012    Post subject: Reply with quote
Cheers will look into that!
Noxious89123
PostPosted: 19:19 - 06 Oct 2012    Post subject: Reply with quote
Would have thought that if the pressure was great enough to pop out a dent, it would also be powerful enough to deform the tank where you didn't want it to! Compressed air and fuel vapour? Don't blow yourself up Exclamation
Snorty
PostPosted: 19:34 - 06 Oct 2012    Post subject: Reply with quote
My friend did the compressed air and rubber bung trick. The tank went with a bang. Try at your peril.
Suction cup is the best idea.
dransy
PostPosted: 19:41 - 06 Oct 2012    Post subject: Reply with quote
Just do what I did and put a dint in the other side with a hammer Smile
DMCpro
PostPosted: 23:07 - 06 Oct 2012    Post subject: Reply with quote
Plug both holes and fill it up with water then put it in your freezer over night will remove all imperfections
Honda CB-1, TS125X
VW Golf Estate
Nexus Icon
PostPosted: 23:24 - 06 Oct 2012    Post subject: Reply with quote
Why would it? A little bit of finesse goes a long way.
Ichy
PostPosted: 23:34 - 06 Oct 2012    Post subject: Reply with quote
It is important to understand how deep / sharp the dent is.
If it is a half decent dent then it will need to be knocked out or pulled.
like this https://www.youtube.com/watch?v=tjOjYvT0jEU
Posting an idea that you read on the internet is retarded.
The thickness of a tank wall means the ideas that others have copied and pasted are unlikely to work.
Air pressure will deform the tank before it forces the dent out.
A sucker will not work.
Freezing? Just lol!
DMCpro
PostPosted: 23:44 - 06 Oct 2012    Post subject: Reply with quote
Freezing? Just lol!
Are you saying my idea wouldn't work? I've done it too many times and it's the easiest way. Also works on exhausts.
Honda CB-1, TS125X
VW Golf Estate
Nexus Icon
PostPosted: 23:56 - 06 Oct 2012    Post subject: Reply with quote
Freezing? Just lol!
Sure. I've seen air pressure remove dents with my own eyes.
Noxious89123
PostPosted: 00:04 - 07 Oct 2012    Post subject: Reply with quote
I don't doubt that airpressure *could* remove a dent, it's just that I think it would deform the tank elsewhere, before it popped the dent out. Depends on the shape of the tank really.
Ichy
PostPosted: 07:39 - 07 Oct 2012    Post subject: Reply with quote
Soft impacts yes, sharp damage no.
Ichy
PostPosted: 07:50 - 07 Oct 2012    Post subject: Reply with quote
Water expands equally in all directions. How does the freezing differentiate(?) between a dent and a formed surface or a weak joint? How does it cope with stretching? Removing imperfections is different, I've completely removed small soft dents from panels simply by hitting a different part of the panel.
Please show me how this works because I would be really interested, it could save me a lot of time.
This is damage.
https://i93.photobucket.com/albums/l41/marki_03/GS125/oldtank.jpg
Tenantry13
PostPosted: 08:04 - 07 Oct 2012    Post subject: Reply with quote
Just fill the dent, and put a sticker over it. Thumbs Up
ian505050
PostPosted: 23:01 - 07 Oct 2012    Post subject: Reply with quote
remove tank from bike fill with water, seal it, put in large freezer and it will pop out
Frost
PostPosted: 23:12 - 07 Oct 2012    Post subject: Reply with quote
Well the paint is shit so it can be removed. Then either drill a hole and pull the dent out using it, or weld a rod on and pull it using that.
There is also a dry ice method that works on shallow dents. It works by contracting one specific area of metal. So if you put the tank in the oven on full blast then use dry ice on the dent. 225c, -80c is quite a temp difference and should give some big results.
Ichy
PostPosted: 05:49 - 08 Oct 2012    Post subject: Reply with quote
I'd already done it Laughing
https://i93.photobucket.com/albums/l41/marki_03/GS125/newtank.jpg
No air, no ice, no suckers, no filler just a couple of bars, hammers and a file.
talcumpowderb...
PostPosted: 19:52 - 08 Oct 2012    Post subject: Reply with quote
Used nitro mors to get all the paint off, keeping it at a metal finish! cheers everyone for all the reply's. Still deciding if i am going to try and fix it or not ! cheers Thumbs Up
Rogue_Shadow
PostPosted: 20:29 - 08 Oct 2012    Post subject: Reply with quote
Shocked
How?
Frost
PostPosted: 20:32 - 08 Oct 2012    Post subject: Reply with quote
The hammers and bars were distributed to his pikey mates who aided him in mugging the tank of the bike of some 17 year old who didn't look like he could handle himself.
Ichy
PostPosted: 21:10 - 08 Oct 2012    Post subject: Reply with quote
Rogue_Shadow wrote:
How?
Magic!
https://www.bikechatforums.com/viewtopic.php?t=205036&postdays=0&postorder=asc&highlight=gs125&start=0
Noxious89123
PostPosted: 22:04 - 08 Oct 2012    Post subject: Reply with quote
Marki wrote:
Rogue_Shadow wrote:
How?
Magic!
I do believe you mean...
https://media.tumblr.com/tumblr_mb4bex3tC51r95741.gif
That is pretty good though!
Rogue_Shadow
PostPosted: 00:12 - 09 Oct 2012    Post subject: Reply with quote
Marki wrote:
I just read through the entire thread Thumbs Up
Can't believe it got stolen Sad
Epic skills Mr Marki, cheers for the link.
Ichy
PostPosted: 05:48 - 09 Oct 2012    Post subject: Reply with quote
Have you had a look at Chri5s Turbo bike? Clever lad and he is only like 12 or something Wink
https://www.bikechatforums.com/viewtopic.php?t=206009
The last post was made 13 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 132.14 Kb
