Correct procedure for turning left or right?
maxp
PostPosted: 15:40 - 07 Oct 2012    Post subject: Correct procedure for turning left or right? Reply with quote
Im due to start my mod1/mod2 training in a fortnight and am trying to get prepared.
I always thought the correct procedure for turning was: mirror, signal, lifesaver, maneuver.
However Ive just seen a learn2ride yotube video that states: lifesaver, signal, mirror, lifesaver, manuever.
This seems slightly over the top to me?
Can anyone confirm the correct procedure?
mark111
PostPosted: 15:52 - 07 Oct 2012    Post subject: Reply with quote
On my CBT it was Mirrors , Lifesaver , Signal , maneuver , Then another Lifesaver before the turn
swampy
PostPosted: 16:52 - 07 Oct 2012    Post subject: Reply with quote
A lifesaver should be done after after signalling and before moving... It's a lifesaver not a blind spot saver.
Flamzypants
PostPosted: 16:58 - 07 Oct 2012    Post subject: Reply with quote
'Blind spot saver' may well end up saving your life, don't see why it'd need a different name for the same action :p But to the OP, second post is dead on what I've been taught.
CBT - 30/06/11. RIP Sinnis Stealth 18/07/11. Theory passed! CBR125R 16/08/12. Mod 1 Booked.
paulie82
PostPosted: 17:14 - 07 Oct 2012    Post subject: Reply with quote
Read in one of the official DSA books that it was OSM (PSL). Observation, Signal, Manoeuvre. The Manoeuvre being Position, Speed, Lifesaver.
'Observation' doesn't specify so maybe it's a judgement call. I was trained on the CBT recently to use mirrors first though.
Theory Test: Pass 25/07/12 CBT: Pass 16/09/12
Module one: Pass 14/11/13 Module two: Pass 05/12/13
Yamaha YBR 125(sold), Yamaha Fazer 8
leecook385
PostPosted: 17:26 - 07 Oct 2012    Post subject: Reply with quote
I agree the lifesaver is done before moving but it is a blind spot check just like in a car, push bike etc.
I was told the lifesaver is done just before you move in to a new position. so changing lanes, leaving rounderabouts making turns etc.
I understand the process to be observation,signal, manoeuvre.
the manoeuvre being broken down to Position,Speed and Look.
so for a left turn i would do
Observation, so check mirrors to know whats behind, good check in left mirror here looking for cyclists etc
Signal, so left hand signal on so people know what you are going
to do.
Now Manoeuvre,
This is where I would check my left blind spot, So LIFESAVER before moving to position
Position would be to the left. not to close to the kerb.
Speed, so this is braking and then the correct gear for the speed to make the turn.
Look, this is where you look in to the road you are about to turn into watching for people crossing,obstructions in the road, bus pulling in to stop etc.
This is the way I am doing it while practicing for my mod 2.
I am not having lessons, but I have been reading the Official DSA guide to riding so hope I am getting it right Smile
cbr 600 f
PostPosted: 17:52 - 07 Oct 2012    Post subject: Re: Correct procedure for turning left or right? Reply with quote
Was that for pulling away from a stop, by any chance?
If it was a general rule, then it's didactic bollocks.
"Rear observation", signal, lifesaver if appropriate, engage manoeuvring thrusters.
Rear observation means whatever's appropriate for the situtation, be that mirror, quick look to the side, or full on rubberneck. Even the lifesaver isn't an absolute rule. Think about overtaking at speed: the hazards are far more likely to be in front than behind.
matto
PostPosted: 19:14 - 07 Oct 2012    Post subject: Reply with quote
OSM-PSL is a one sized fits all routine to get into your head for any manouvre on the road.
However what you do in each part of the routine is entirely situational and it's only experience that will allow you to make the correct decisions each time.
Observations - might be a glance in the mirrors, or a full rearward look, depends whether you are pulling away or heading towards a very quiet single lane roundabout.
Signal - you might signal, you might not, but it's good to consider whether one is needed or not.
Manouvre:
Position - where you need to be to get safely where you want to go
Speed - ensure your going to be at a safe speed for the manouvre/
Look - generally a lifesaver on a motorbike but again only if needed, also at fast moving junctions it could include a final 'is it still clear' check.
Obviously you have to start this a long way from any junction/obstruction/etc. to fit it all in, if you can't then bits of it have to missed out but only experience will allow you to make the right calls to keep yourself safe and most importantly the examiner happy.
TLDR: everything is situational, only experience is going to make sure you do the right things each time.
DonDino
PostPosted: 19:29 - 07 Oct 2012    Post subject: Reply with quote
My instructor's system is:
Left turn
Look behind (either turn head or mirrors)
Signal
Speed & gears
Lifesaver
Manoeuvre
Right turn
Signal
Lifesaver
Move to centre/right side of road (unless lanes are marked)
Speed & gears
Lifesaver
Manoeuvre
Obviously adjusted for the conditions, i.e. for open or closed junctions, if you decide you need to stop at the line, etc.
janner_10
PostPosted: 19:50 - 07 Oct 2012    Post subject: Reply with quote
Left turn
Signal
Speed & gears
Lifesaver
Manoeuvre
Right turn
Signal
Lifesaver
Speed & gears
Lifesaver
Manoeuvre
Why are you looking behind you twice for?
People seem to teach the un-needy lifesaver these days, for example lifesaver after turning left? Why? turn left then gun it and look forward.
I thought you should life saver before making a turn or a change of position, not just for indicating.
If I adopted that, I would spend half my time during a turn looking behind, in my experience, the danger is in front of me.
DonDino
PostPosted: 20:00 - 07 Oct 2012    Post subject: Reply with quote
janner... yes!! Thank you!! That's what I asked my instructor, with a face showing utter confusion, after a couple of lessons where it was just not working for me. I told him I would just use the mirrors to 'look behind' and not turn my head - he reluctantly accepted it.
Without turning your head, following this system, you are not looking behind twice, but you are doing two lifesavers before turning right, which is a bit overkill.
I'm 100% with you about the unnecessary lifesavers, esp. on turning left, if you just know that nobody can be on your blind spot because you've been checking your mirrors and you know what you've passed just moments ago, unless it's some sort of tiny rocket-powered cyclist Laughing , you should be ok to make the left turn!
matto
PostPosted: 20:36 - 07 Oct 2012    Post subject: Reply with quote
People teach the 'un-needy lifesaver' because there are situations when you should do it, like turning left in very slow moving city traffic.
It's a belt and braces approach to learners as most are not experienced enough to assess the situations when it is needed and the examiners will not mark you down for doing it when you didn't need to, vice versa however...
cimbian
PostPosted: 20:43 - 07 Oct 2012    Post subject: Reply with quote
Changing road position and changing lanes and crossing carriageways.
Left turn (major-to-minor)
Mirror, signal, left shoulder-check move from P2 to P1. Slow right-down, left shoulder-check, manoeuvre.
Right turn (major-to-minor)
Mirror, signal right should-check move from P2 to P3.
If into another lane (ghost island etc.) right should-check move from lane to new lane.
slow right down.
right shoulder-check BEFORE crossing carriageway
Mod-2 passed with flying Doodahs last week using the above.
All in my VERY humble opinion, of course. Smile
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
janner_10
PostPosted: 21:00 - 07 Oct 2012    Post subject: Reply with quote
Then thats a life saver to do in slow moving traffic, not every turn. But yes, I suppose it removes the learner having to think should I or should'nt I, if taught to do it every time it removes that doubt.
DonDino
PostPosted: 21:12 - 07 Oct 2012    Post subject: Reply with quote
I am very much inclined to go on for the Enhanced Rider Scheme and on to Advanced Rider courses, and I'm wondering if they will teach me to do things differently from what I learned in order to pass mod2...
The last post was made 13 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 91.27 Kb
