CAN'T GET MY SWING ARM SPINDLE TO UNDO!
Bike Chat Forums Index -> New Bikers Goto page 1, 2, 3, 4  Next
Dannylewis27
PostPosted: 20:06 - 09 Oct 2012    Post subject: CAN'T GET MY SWING ARM SPINDLE TO UNDO! Reply with quote
Hi there,
I'm quite agitated :@
I'm trying to remove my aprilia rs125 engine from the frame so I can change the gearbox
But I can't seem to loosen/undo the swing arm spindle!
I've loosened every other mounting bolt this is the last one!
I k ow it has a special tool to get some sort of threaded locking washer on it, I got that off without it but I can't get the spindle to budge
I've snapped my Allen key and bent my adjustable spanner
This thing isn't budging!
Any help please?
Derbi senda R, 03
Aprilia RS 125 Extrema, 98
The Artist
PostPosted: 20:10 - 09 Oct 2012    Post subject: Reply with quote
1. Not sure how you bend an adjustable spanner unless it is made of cheese.
2. Swingarm spindles are notorious for being a PITA to remove. Is it spinning at all? If not, get it spinning. Borrow some proper tools, preferably an impact gun electric/air to get it freed up a bit. Then hammer the other end WITH THE NUT ON flush with the top of the thread so you don't mushroom the end so it won't come out.
thomp1983
PostPosted: 20:27 - 09 Oct 2012    Post subject: Reply with quote
you don't need to remove it, remove the locking washer as you have then you can undo and remove the bolt from the clutch side of the bike, no need to remove the allen key bit on the other side
chris
Dannylewis27
PostPosted: 22:45 - 09 Oct 2012    Post subject: Reply with quote
But it won't seem to come out?
I've removed the castleated lock and I can loosen the clutch side with a socket wrench all day long it doesn't seem to actually do anything?
Am I missing some plain obvious thing here?
Derbi senda R, 03
_matt
PostPosted: 00:12 - 10 Oct 2012    Post subject: Reply with quote
I bent an adjustable spanner last week, trying to get the rear wheel spindle out of a Honda CG.
Spanner on -> Jump up and down on spanner till the bloody thing loosened up -> bend spanner 45 degrees -> realise ive got a blowtorch to heat it up instead -> jobdone
1990 Yamaha XV 535 (Alive Again!) / 2007 Jinlun Texan 125-11 (formerly 2k3, wrong details, now going rusty in the back garden )
Dannylewis27
PostPosted: 11:06 - 10 Oct 2012    Post subject: Reply with quote
Would a blowtorch just expand the metal?
Derbi senda R, 03
thomp1983
PostPosted: 11:15 - 10 Oct 2012    Post subject: Reply with quote
Get a punch/drift that fits inside the Allen key hole on the right side and tap the bolt out with a hammer
thomp1983
Dannylewis27
PostPosted: 12:32 - 10 Oct 2012    Post subject: Reply with quote
A what now? I've never heards of a punch/drift
Derbi senda R, 03
The Artist
PostPosted: 12:53 - 10 Oct 2012    Post subject: Reply with quote
Google is your friend
thomp1983
PostPosted: 14:30 - 10 Oct 2012    Post subject: Reply with quote
A punch is a hardened piece of metal with different profiled ends you place against something you want to move or mark then hit with a hammer. A drift is similar but usually a softer metal than your hitting against so you don't damage or mark the workpiece. In your case an old screwdriver that fits in the hole would do
Chris
thomp1983
PostPosted: 14:31 - 10 Oct 2012    Post subject: Reply with quote
Chris
thomp1983
PostPosted: 14:38 - 10 Oct 2012    Post subject: Reply with quote
And if you've already removed the other 3 engine mount bolts all the engine weight will be on that last bolt making it harder to get out
Chris
Dannylewis27
PostPosted: 14:46 - 10 Oct 2012    Post subject: Reply with quote
Alright thanks
Sorry I'm not too knowledgable this is my first time working in a bike or using special tools :/
Derbi senda R, 03
matto
PostPosted: 17:56 - 10 Oct 2012    Post subject: Reply with quote
You gotta learn somewhere and you'll learn that removing the stuck/corroded/fcknbstrd nuts is what seperates the men from the boys Smile
Penetrating oil, heat, impact driver/wrench and patience, lots of patience because the worst thing is breaking something else while giving the stuck bit some welly.
Dannylewis27
PostPosted: 19:48 - 10 Oct 2012    Post subject: Reply with quote
Exactly! I gotta learn somehow, now
Can I just verify HOW it comes out, once I have removed the castellated lock, does it just tap out? (From the right out te left side)
Why does it have an Allen key hole in it if it doesn't loosen?
The left side (with a socket wrench) will undo until the cows come home but doesn't seem to actually unthread anything, and as I'm doing that side, the right side isn't spinning,
SOMEONE COME AND GET THIS FUCKER OUT FOR ME
10 pints on me lol
Derbi senda R, 03
thomp1983
PostPosted: 20:01 - 10 Oct 2012    Post subject: Reply with quote
remove castellated nut, insert whatever your using as a drift in the hole where the allen key would go it will come up against something hard that's the bolt end then hit your drift squarely and solidly with a decent size hammer, make sure the other 3 engine mount bolts are back in the frame taking the weight off this bolt.
you'll see once you get it out it's a poor bit of design and easily corrodes, it also has pressure from the swing arm and rear shock on it but a hammer will get it out
chris
Dannylewis27
PostPosted: 23:47 - 10 Oct 2012    Post subject: Reply with quote
Thanks guys!!
I did manage to get it out Bout 3 hours ago
The person I was with yesterday tried tapping it through but said it wouldn't budge so I didn't bother trying
Turns out he tried tapping the hole nut! Not tapping inside the Allen hole
Knob'ed :p
Anyway it's off and out now Smile
Now the fun really begins
I have a really really loud rattling noise, like a coin in a washing machine and it won't select first gear!
I bought the bike and without realising it had no oil plug on the clutch cover
(Sill I know, my fault)
Anyway it ran for 5 minutes before it jammed I got it to run by re oiling it but dice then it won't click down to first and I have the above mentioned rattle
So I'm going to check the gear selector fork and bearings
Any advice on that?
Derbi senda R, 03
thomp1983
PostPosted: 10:19 - 11 Oct 2012    Post subject: Reply with quote
Im at work on phone so can't write a detailed reply. You can get to the gear change mechanism just by removing the clutch cover. I suspect you'll find it's not just a simple problem id expect your plastic balance gears to be ruined and possibly the bearings for the balance shaft all these can be inspected with the clutch cover off. Anything you remove keep in the exact same order it comes off including the directions circlips and washers face it needs to go back together in the exact same order. Post a picture up of the engine with the clutch cover off.
Chris
Ribenapigeon
PostPosted: 12:51 - 11 Oct 2012    Post subject: Reply with quote
My old man is a biker from days of yore and he is always saying how you shouldent ride a bike if you haven't taken an engine to bits put it back together then got it running again. So chin up! Your scoring more man points with my old man than I do! Smile
I used to spend hours when I was younger fixing up old bangers so I can sympathise. Stuck bolts are one of the most annoying frustrating things to deal with. That and having parts lft over after reassembly :-/
Dannylewis27
PostPosted: 16:20 - 11 Oct 2012    Post subject: Reply with quote
Ah finally some sympathetic people with real advice!
I got trolled last night for having an RS125 without a being a bike pro basically!
Fuck it I gotta learn somehow and it ain't exactly running at the minute so I got nothing to loose!
Derbi senda R, 03
Dannylewis27
PostPosted: 18:10 - 11 Oct 2012    Post subject: Reply with quote
https://i132.photobucket.com/albums/q28/joeymaybe/th_CC38CA65-CAFD-4852-9935-68BD26069424-1380-0000014D92F83918.jpg
Derbi senda R, 03
Dannylewis27
PostPosted: 18:11 - 11 Oct 2012    Post subject: Reply with quote
Okay the video didn't work
Watch it here
https://s132.photobucket.com/albums/q28/joeymaybe/?action=view¤t=CC38CA65-CAFD-4852-9935-68BD26069424-1380-0000014D92F83918.mp4&evt=user_media_share
Derbi senda R, 03
thomp1983
PostPosted: 11:17 - 12 Oct 2012    Post subject: Reply with quote
hmmm that's not good buddy, it shouldn't be locking up like that but you already know that. your probably going to have to split the gearbox apart, first remove the barrel and turn it over by hand again to see if it still locks up, that will rule out it being an issue with the barrel. at a guess id say one of the balance shaft bearings has seized and is causing the locking up. if it's still locking up remove the clutch assembly (undo the 6 bolts in the middle remove the plate/springs, remove the centre nut and pull off the whole clutch assembly.), with the clutch off then remove the two yellow plastic balance shaft gears, with them removed you should be able to turn the balance shaft itself by hand and see if it feels notchy/locks up.
either way id say your looking at replacing all the bearings (£40 set on ebay), a full gasket set (£20 ebay) 2 new balance shaft gears (£25 from pjme) as a minimum, plus anything elese that may be broken when you get the gearbox apart (probably nothing, the actual gear units themselves are quite robust it's the bearings that take the damage). removing/fitting the new bearings is a bit of a pain, getting the old ones out can be interesting and refitting the new ones includes several cycles of heating the engine casings in the oven and freezing bearings/crank at different stages but it's fairly straight forward to do.
when you drained the remains of the oil from the gearbox were there any traces of anything in it either metal shards or bits of plastic?
and tidy up your work space, you'll find it alot easier to do the job with some clear space to put things down in, in the order they were removed without having to scrabble around in piles of other stuff
chris
Dannylewis27
PostPosted: 15:34 - 12 Oct 2012    Post subject: Reply with quote
I am going to clear a space when I get home from work today, I just out it there out of the rain.
Oh well what you said about the gearbox is handy! Hopefully it's not broke
I really don't want to have to remove that
So can I access the everything I need without splitting the crank case or is that inevitable?
If its okay I will record videos of each stage and any noises it makes so you can help diagnose what it could be
And I'd be happy if it was just the bearings but that sounds like a lot of hassle putting it in and out of the oven and freezing!?
I didn't know I had to do that! :/
Derbi senda R, 03
The last post was made 13 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 125.41 Kb
