| Dannylewis27 |
 Dannylewis27 Renault 5 Driver
| The Artist |
 The Artist Super Spammer
| thomp1983 |
 thomp1983 Crazy Courier
| Dannylewis27 |
| _matt |
 _matt Trackday Trickster
| Dannylewis27 |
| thomp1983 |
| thomp1983 |
| Dannylewis27 |
| The Artist |
| thomp1983 |
| thomp1983 |
| thomp1983 |
| Dannylewis27 |
| matto |
 matto Crazy Courier
 Posted: 17:56 - 10 Oct 2012 Post subject: |
You gotta learn somewhere and you'll learn that removing the stuck/corroded/fcknbstrd nuts is what seperates the men from the boys
Penetrating oil, heat, impact driver/wrench and patience, lots of patience because the worst thing is breaking something else while giving the stuck bit some welly. |
| Dannylewis27 |
| thomp1983 |
| Dannylewis27 |
 Posted: 23:47 - 10 Oct 2012 Post subject: |
Thanks guys!!
I did manage to get it out Bout 3 hours ago
The person I was with yesterday tried tapping it through but said it wouldn't budge so I didn't bother trying
Turns out he tried tapping the hole nut! Not tapping inside the Allen hole
Knob'ed :p
Anyway it's off and out now
Now the fun really begins
I have a really really loud rattling noise, like a coin in a washing machine and it won't select first gear!
I bought the bike and without realising it had no oil plug on the clutch cover
(Sill I know, my fault)
Anyway it ran for 5 minutes before it jammed I got it to run by re oiling it but dice then it won't click down to first and I have the above mentioned rattle
So I'm going to check the gear selector fork and bearings
Any advice on that? ____________________ Derbi senda R, 03
Aprilia RS 125 Extrema, 98 |
| thomp1983 |
| Ribenapigeon |
 Ribenapigeon Super Spammer
 Posted: 12:51 - 11 Oct 2012 Post subject: |
My old man is a biker from days of yore and he is always saying how you shouldent ride a bike if you haven't taken an engine to bits put it back together then got it running again. So chin up! Your scoring more man points with my old man than I do!
I used to spend hours when I was younger fixing up old bangers so I can sympathise. Stuck bolts are one of the most annoying frustrating things to deal with. That and having parts lft over after reassembly :-/ |
| Dannylewis27 |
| Dannylewis27 |
 Posted: 18:10 - 11 Oct 2012 Post subject: |
| Dannylewis27 |
 Posted: 18:11 - 11 Oct 2012 Post subject: |
| thomp1983 |
 Posted: 11:17 - 12 Oct 2012 Post subject: |
hmmm that's not good buddy, it shouldn't be locking up like that but you already know that. your probably going to have to split the gearbox apart, first remove the barrel and turn it over by hand again to see if it still locks up, that will rule out it being an issue with the barrel. at a guess id say one of the balance shaft bearings has seized and is causing the locking up. if it's still locking up remove the clutch assembly (undo the 6 bolts in the middle remove the plate/springs, remove the centre nut and pull off the whole clutch assembly.), with the clutch off then remove the two yellow plastic balance shaft gears, with them removed you should be able to turn the balance shaft itself by hand and see if it feels notchy/locks up.
either way id say your looking at replacing all the bearings (£40 set on ebay), a full gasket set (£20 ebay) 2 new balance shaft gears (£25 from pjme) as a minimum, plus anything elese that may be broken when you get the gearbox apart (probably nothing, the actual gear units themselves are quite robust it's the bearings that take the damage). removing/fitting the new bearings is a bit of a pain, getting the old ones out can be interesting and refitting the new ones includes several cycles of heating the engine casings in the oven and freezing bearings/crank at different stages but it's fairly straight forward to do.
when you drained the remains of the oil from the gearbox were there any traces of anything in it either metal shards or bits of plastic?
and tidy up your work space, you'll find it alot easier to do the job with some clear space to put things down in, in the order they were removed without having to scrabble around in piles of other stuff
chris |
| Dannylewis27 |
The last post was made 13 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
