ke125 - blowing bulbs !!!
69chris
PostPosted: 21:13 - 15 Oct 2012    Post subject: ke125 - blowing bulbs !!! Reply with quote
hey guys, im having a spot of bother........again Laughing
im trying to get the mrs ke125 up together for her,
i fitted the loom, connected everything up and fired it up,
starts and runs great but when you switch on the lights they are really really bright - even at tick over, then with a lil rev they go into search light mode before blowing, the headlight/speedo/tach bulbs all blow together!!
iv had a search thru the wiring diagram and it would seem that the headlight gets it power directly from the mag so it would seem to me that the reg (rec ?) is ok
the battery is fitted but its proper dead - would that cause the bulb issue or is it more likely to be the mag playing up ???
thanks for any help guys Thumbs Up
russell210276
PostPosted: 22:59 - 15 Oct 2012    Post subject: Reply with quote
just do a simple check get a multimeter run the bike on idle check the voltage at the battery below your looking inbetween 12.5 and 14.5 volts then do the same at 3000rpm if anything like mine wen my regulator went i got 30 volts at the battery fried bulbs and battery
69chris
PostPosted: 23:47 - 15 Oct 2012    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
there may be a ballast resistor missing or damaged
thanks mate, there is a resistor bolted along with the coil, i think iv got a spare so ill swap it over tomorrow and report back Thumbs Up
69chris
PostPosted: 23:53 - 15 Oct 2012    Post subject: Reply with quote
cheers mate, i checked the voltage and got 7ish volts at the battery (6v system) but i dunno if ill get an accurate reading until i fit a new battery as this ones dead !!!
it was the bulb blowing that had me stumped........
i hate leccy stuff.......
its mysterious......
like voodoo Laughing
Raffles
PostPosted: 06:50 - 16 Oct 2012    Post subject: Reply with quote
If your battery is giving a reading of 7V, how is it dead? Do the checks suggested above and see what readings you get whilst running the engine at various RPM's.
69chris
PostPosted: 18:45 - 16 Oct 2012    Post subject: Reply with quote
If your battery is giving a reading of 7V, how is it dead? Do the checks suggested above and see what readings you get whilst running the engine at various RPM's.[/quote]
ahh i wasnt being very clear, what i meant was although the batterys dead - proper dead, i have only fitted it so hopefulty nothing else will get cooked whilst im fiddling with it,
i measured 7ish volts at the battery leads whilst the bike was running (fast tickover), anything above that (2k rpm ish) just blows the bulbs !!!
Turkish
PostPosted: 19:51 - 16 Oct 2012    Post subject: Reply with quote
Does the voltage increase significantly when you rev the bike above 2k?
Would point to dodgy reg/rec maybe? Maybe even the cause of the dead battery? Just a thought...
ZX-6R G2
CBR125R RW6
69chris
PostPosted: 19:03 - 21 Oct 2012    Post subject: Reply with quote
thanks for the input guys,
it was the mag playing up, it got so bad that even taking a voltage reading was impossible as it was fluctuating so badly the multimeter couldnt keep up Laughing
i ended up testing for a current using a test light which, when some power was actually found, 'pulsed' the bulb from very dim to very very bright Laughing
got hold of a s/h mag and it seems to have done the trick
thanks again Thumbs Up
The last post was made 13 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 61.6 Kb
