| MichaelWhite9... |
 MichaelWhite9... Derestricted Danger
| Alpha-9 |
 Alpha-9 Super Spammer
| MichaelWhite9... |
| ricklincs45 |
 ricklincs45 Nitrous Nuisance
 Posted: 10:29 - 18 Oct 2012 Post subject: |
Do you mean all the electrics are dying on you? If so, not sure the choke issue is the main problem.
Might be worth putting a voltage tester across your battery terminals and checking what voltage you're getting. Do this with the bike turned off, and then with bike running with no lights on, and then again with bike running with lights on. Write down what figures you're getting from each reading.
I'm assuming you're bike has 12v electrics. Once you have those figures, either post them here, or ring/pop in to your local Yam' dealer and ask them if your figures seem right.
It may be you've got a dead/dying battery (especially if it's the original item).
Rick @ www.80bikes.com |
| Alpha-9 |
 Posted: 10:34 - 18 Oct 2012 Post subject: |
So you can start the bike but it cuts out after a while?
Yours is the carbed model so different to mine, but when my fuse was gone I found the bike would still start on kick (electric rapes) but I could only get down the road, as soon as the revs dropped there wasn't enough power and it'd die as it was running purely off the generator i'm guessing, yours isn't FI so can probably run easier without the fuse intact
Check your fuse, should be in the relay next to the battery under your LH side panel (opens with a key)
Assuming the older models mostly the same!
So you can start it okay on electric start? Do you notice the lights dimming when you press the button? If so could be battery on it's way out or needing maintenance as above has said
If it starts fine then the spark plugs probably okay, but it's worth having a look at and checking the clearance anyway, easy job
Tool kit above the battery in your bike, everything you need in there  ____________________ Fzr-600 1999 |
| C1REX |
 C1REX Traffic Copper
 Posted: 10:58 - 18 Oct 2012 Post subject: |
Maybe you overheating the engine?
Did you left the choke for to long?
What is the oil level and when was it changed last time?
Battery can be old as well. It can also be a dirty air filter.
Many things if the bike is missing a good maintenance. ____________________ MCForum meetup - One of the biggest motorcycle clubs in UK |
| J.M. |
 J.M. World Chat Champion
| Islander |
 Islander World Chat Champion
| st3v3 |
 st3v3 Super Spammer
| Alpha-9 |
| MichaelWhite9... |
| Timmeh |
 Timmeh World Chat Champion
| J.M. |
| MichaelWhite9... |
| Islander |
 Posted: 21:39 - 20 Oct 2012 Post subject: |
If you've got a local Maplins then they do one for around a tenner.  |
| honda cg 1992 |
 honda cg 1992 L Plate Warrior
| MichaelWhite9... |
The last post was made 13 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
