zx6r a bitch to start when hot
bombom
PostPosted: 18:29 - 24 Oct 2012    Post subject: zx6r a bitch to start when hot Reply with quote
As title says, she is a real pain to start when hot, almost like its flooding.
It has its occasional fire but not anough to start and then eventualy will start up.
It will do it if i turn it off and try try to start it fairly quick afterwards, say about a minute or so.
its perfectly fine when cold, starts in mornings no problem.
cant say when plugs or air filter was last changed as i havnt had it a month yet and just havent even had the time to take the tank off yet but any suggestion on what to check as il have to spare time with weekend
zx6r f3 1997
cheers
Current: 97 zx6r f3
Previous: suzuki gsf400 bandit
Fizzer Thou
PostPosted: 22:24 - 24 Oct 2012    Post subject: Reply with quote
Next time that the engine is hot,perform a compression test.If all cylinders are reading a low result then check that the valve clearances are within spec.If they are below the specified clearance,once the engine is hot the valves can be open slightly,losing compression and causing the difficulty in starting.
If you have a multimeter then check that the spark plug caps are between 5-10k ohms.If any are way above 10k ohms then the internal resistive element might be breaking down causing insufficient power to get through to the spark plugs.
Always have a 'Plan B'
ricklincs45
PostPosted: 09:25 - 25 Oct 2012    Post subject: Reply with quote
Could also be a fuel starvation or evaporation problem, rather than flooding. If you have time to do so, might be worth taking a couple of plugs out when the engine is hot and is being a pig to start, then checking what colour the plugs are.
If it's flooding, chances are they'll be wet. If they're not, it's unlikely to be a flooding problem. Ideally the plugs should be something around the colour of a rich-tea biscuit.
As other poster has mentioned, valve clearances could be too tight - I take it you've not had the bike long? Doubt it's an air filter problem otherwise it would be difficult to start hot and cold.
It may also be part of the ignition system is partially breaking down when hot; these faults can often show up whereas they may not with a cold engine.
Best of luck, hope you get her sorted.
Rick
Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS.
cb1rocket
PostPosted: 12:32 - 25 Oct 2012    Post subject: Reply with quote
difficult starting can be knackered spark plugs.
You say its hasn't been serviced, so if I was you I would get it all the plugs replaced and the air filter, and an oil change if not already done
Symon27
PostPosted: 17:12 - 25 Oct 2012    Post subject: Reply with quote
My zxr 400 has a problem starting from hot, maybe Kawasaki suffer from it?
Honda Nsr 125 - Sold
Zxr 400 - Sold
Bandit 600 - Current (Y)
bombom
PostPosted: 19:11 - 25 Oct 2012    Post subject: Reply with quote
hi, yeah iv only had it a month and all iv had time to do is a quick oil and filter on it as its fairly easily accesable.
Im off work tomorrow so will finally beable to take the tank off and see what lurks beneath.
will update and thanks for the info
Current: 97 zx6r f3
0l0dom0l0
PostPosted: 19:54 - 25 Oct 2012    Post subject: Reply with quote
Don't start taking apart things.
I know exactly what the problem is..... Valve seat recession. The early ZX6R's suffered from this, so google it and you will find out what I mean.
I don't think there are any fixes but have a look before you start taking carbs off and things.
The last post was made 13 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 52.51 Kb
