Enduros/Supermotos/offroaders
.Bishbash.
PostPosted: 15:55 - 25 Oct 2012    Post subject: Enduros/Supermotos/offroaders Reply with quote
I intend to buy one of the above next year, preferably one with both offroad and supermoto wheels for all occasions and I want to get all muddy and fall off lots AND commute to work if needs be!
I would like to know what machine would be ideal for this? I am not overly experienced in these, the only one I have owned(KTM EXC 450) got nicked off me after a whole week of owning it.
So, what would you suggest?????????????
Current bike - GSX-R1000 k8
Kradmelder
PostPosted: 16:00 - 25 Oct 2012    Post subject: Re: Enduros/Supermotos/offroaders Reply with quote
A KTM of course.
the 690 will do you fine. The 990 is great for long trips but too big for mud and really technical single track.
Outside of KTM, you have the BMW 800 GS or dakar
the Honda XR range
the Kawa KLR
depends on what you want to ride. If you do distance, the thumpers are not the best option. if you do single track the thumpers are better. Sand and mud, the smaller the better.
There isnt really a shifting spanner 1 size fits all. All these bikes are a compromise. It depends what works for you. For me, it is long distance trips with lots of gravel. The big twins do it for me. It just means going slower on the really rough stuff.
2011 KTM 990 Dakar
2009 BMW 1200 GS
PostPosted: 16:20 - 25 Oct 2012    Post subject: Re: Enduros/Supermotos/offroaders Reply with quote
Kradmelder wrote:
A KTM of course.
the Honda XR range
the Kawa KLR
XR and 690 are the only ones near 'enduro'.
We don't have long stretches of gravel here. We do have a lot of tight forest tracks and lots of mud. Lots and lots of mud.
A big bike is far from ideal for a new rider to the muddy stuff.
I've taken my zx9r down a green lane fine, but given the choice wouldn't go heavier than that.
The commuting is what causes the problems - otherwise I'd go for a competition bike.
As you've got that issue, I think I'd consider something like an XR400, DRZ-400e (or CCM404), DR600 (not 650) or the like. Only the CCM of the smaller 'dual sport' bikes that has the option of supermoto wheels as standard.
However quite common to find one with a conversion and both sets of wheels provided.
.Bishbash.
PostPosted: 16:46 - 25 Oct 2012    Post subject: Reply with quote
Ah this is gold, cheers chaps! I will save these bike names. Had a look at CCMs and Husqavarnas, they look like fun. Anyone know if you can get supermoto wheels for Husq's?
Ta.
Irn-Bru
PostPosted: 16:54 - 25 Oct 2012    Post subject: Reply with quote
Sounds like a DRZ would be a good choice, but they are a bit under powered so I'd recommend an FCR carb & full exhaust. Cheap, plenty of bits, wheels are easy to get ahold of and swap, simple carb'd engine etc.
690's are great but expensive and have questionable reliability, mine was getting FI problems with only 4000 miles on it and I had stickers peeling off, leaking brake reservoir, missing bolts, horn stopped working, just little things that I don't think a 11 month old bike should have, baring in mind they are nearly £7K. I got a bit unsettled by the stalling and got rid of it, deciding a cheaper bike was for me, at least if it breaks it won't bug me so much. That aside, it's a lovely bike to ride and very quick and surprising economical.
.Bishbash.
PostPosted: 17:07 - 25 Oct 2012    Post subject: Reply with quote
Laughing Laughing Laughing I'm not thinking of spending that much! I would have to sell both my Yamaha's for that!
I was thinking more £2000 - £2500
DRZ, yes, I forgot about them! Good shout! Wink
Irn-Bru
PostPosted: 17:19 - 25 Oct 2012    Post subject: Reply with quote
Well that's brand spanking new, the 2012 SMC model is £7,200 but it is mighty sexy. Second hand they are 3.5 - 6K (<2012). DRZ's are 1.5 - 3K.
G mentioned DRZ's earlier btw Wink E model's typically sell for a lot less than SM's, could be cheaper to buy an E, then get some SM wheels although they are usually £400 a set, E wheels are typically £220+ depending on condition and with or without tyres. If you got an SM and converted it to E form you'd have the 310mm disc to worry about, not really suited to off roading due to its size but the E standard brake probably wouldn't be great attached to 17's on the roads either.
Pie-Roe
PostPosted: 17:38 - 25 Oct 2012    Post subject: Reply with quote
The husky te610 came as a supermoto and enduro model. I own a 610 that was amazing fun when it worked, had a good balance of power and weight, with a bit of reliability.
Surprised G hasn't gone over the three main points.
You get reliability/servicing, weight, and power. Something like an xt660 has a fair punch of power, good reliability/servicing but is really heavy.
A crf/rmz/kmx will be powerful, light but will need replacement valves/lots of oil and filter changes.
A DRZ is reliable with real servicing times, light enough but is fairly underpowered.
If you spend a fair amount (I know you aren't planning to) I believe I've seen figures suggesting the newer 690s are much well balanced, in that the power is up, the weight is down and the service intervals are miles not hours.
I would go for a drz e with sm wheels, or a husky 610. Wouldn't bother with ccm as the 644s are underpowered, the 404 has a drz engine, and the 604 rotax I've heard to be unreliable. Mine handled beautifully though. The price of these sort of bikes seems to have gone through the roof though recently.
PostPosted: 17:56 - 25 Oct 2012    Post subject: Reply with quote
My "supermoto" was a heavy 138kg TT600R with excel rims and talon hubs, you can get wheels for pretty much any bike, you can get your original hubs laced to different rims.
It was a great bike overall. Down geared it and kinda ruined it, yeah, you could wheelie but it ran out of puff at 80-85mph. Was fantastic riding position though, nice and high and noisy as hell Mr. Green
You could wheelie it in 2nd happily on normal gearing (16/41) and a good rider would be able to keep it up and all the way through the gears.
If I was to do something like that again as a 2nd bike, I'd be looking XR400/DRZ400E... miss mine really, but maybe again in the future! Thumbs Up
Fizzer Thou
PostPosted: 18:04 - 25 Oct 2012    Post subject: Reply with quote
My XR400SM is a whole bundle of fun and I still have the dirt bike wheels to resort to if necessary
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Honda%20750/My%20bikes/Picture051-1.jpg
Have a look here
https://www.supermotoforum.co.uk/bikes-bits-sale/
Nice XR400 here as well
https://www.enduronews.com/forsale.htm
Always have a 'Plan B'
Irn-Bru
PostPosted: 18:22 - 25 Oct 2012    Post subject: Reply with quote
Old LC4 654cc (65bhp) engine was 3,000 mile intervals, however the 2012 690cc (70bhp) LC4 has doubled that to 6,000 miles. Pretty amazing although I have heard it's a pain to have to bleed the oil system as it's got 2 oil pumps but if you only have to do it so infrequently it'll be worth it.
69chris
PostPosted: 18:24 - 25 Oct 2012    Post subject: Reply with quote
not the fastest, not the lightest, not the etc etc etc
https://i157.photobucket.com/albums/t78/71bugslug/002-8.jpg
but it makes me smile Thumbs Up
0l0dom0l0
PostPosted: 18:25 - 25 Oct 2012    Post subject: Reply with quote
2 stroke or 4?
2 stroke, something like a CR250 would be a good laugh. Really you want the CR500 but they are pretty rare now and not cheap.
4 stroke.... Honda CRF 450? Loads of those that are road registered around with both sets of wheels etc.
Wave2k
G's Stalker
PostPosted: 18:35 - 25 Oct 2012    Post subject: Reply with quote
I found my DRz400e fine for all the above.
matinence on these single thumpers is tiresome though.
and as there are no greenlanes near me, i was commuting 20-30 miles to them which chewed the hell out of my rear tyre.
Ducati 1299 Panigale
2009 Corvette C6 z51
KLR600
PostPosted: 18:50 - 25 Oct 2012    Post subject: Reply with quote
Not got a recommendation for a specific bike/make but I was looking to get an enduro/supermoto for the same reasons as you earlier in the year. (I did have an old Kawasaki KLR600 that I ran for a year but it was a bit old and tired and used 95% for commuting). I would suggest getting a bike that already has both sets of wheels as buying a set of supermoto wheels is expensive and a bit of a faff getting everything together like big brake conversion parts and maybe wheel spacers etc not to mention the possibility of having to sacrifice your off road rims to lace your hubs onto supermoto rims. You should easily be able to get a bike with both sets of wheels for £2.5k.
Just a note to say that unless you've moved recently I'd be a bit worried about buying another off-roader if the last one you had was stolen in a week. Definitely look at upgrading your security.
<Take Cool Photos!>
J D
PostPosted: 02:33 - 26 Oct 2012    Post subject: Reply with quote
Have a look on my fb pictures Neil , mate of mine is selling a husky 610 te
Kawksam
PostPosted: 09:19 - 26 Oct 2012    Post subject: Reply with quote
Yamaha ttr 250 not the quickest of cats but handles well good on fuel and a nice bike to use everyday
.Bishbash.
PostPosted: 09:36 - 26 Oct 2012    Post subject: Reply with quote
Bit early for me to buy one yet mate, as I need to sell R1 and move, but once I do, I will properly start on the market. I will have a look anyway. Thumbs Up Oh are you still buying one?
Will have a decent look at all these bikes, thanks all!
EDIT: Nice bike that! Thumbs Up Thumbs Up Thumbs Up How much does he want for it? Very Happy
Atomic Punk
PostPosted: 09:55 - 26 Oct 2012    Post subject: Reply with quote
I have had
2 x Husky SM610
1 X CCM 644
1 X MZ Baghira 660
1 x Aprillia Dorsoduro 750
Huskys are brilliant fun, good performance and realy light to chuck about on and off road. Servicing is needed often and they drink oil.
CCM is pretty bullet proof, doesn't have the same performance as the Husky but is a lot more reliable.
MZ is basicaly a Yamaha XT but will lots of uprated bits, brakes plastics, suspension also bullet proof but heavy.
I took a load of unnessasary metal off mine, ditched the realy heavy exhaust, swapped for a Viper and spent £2000 tuning the engine. It went like shit off a shovel.......... and then got nicked Sad
The Aprillia isn't realy an option for you Wink
I may have lost my way but I'm way ahead of schedule.
.Bishbash.
PostPosted: 10:09 - 26 Oct 2012    Post subject: Reply with quote
Ah thanks for that, good info on 2 bikes I was interested in(CCM and Husq)
Sounds like CCM might be on the cards for me, being British helps as well Very Happy
PostPosted: 10:12 - 26 Oct 2012    Post subject: Reply with quote
Indeed - you almost got an agree/helpful, but then you went on to suggest that xt660 has 'a fair punch of power' - ok, 47hp isn't too bad, but it's not up there with the BMW 650X, KTM690 or TE610, yet also weighs a fair bit more. Smile
Atomic Punk - if you think the Husky 610 is light you need to try some proper dirt bikes Smile.
Kawksam:
You weren't to know, but I'd say the OP is approximately twice the height of the rider's the TTR is designed for! Smile
Kradmelder
PostPosted: 10:38 - 26 Oct 2012    Post subject: Reply with quote
Kawksam:
If you are not a short shit the options for off road bikes shoots up.
The commute option however limits you to road worthy bikes, and preferably a larger capacity.
The 690 would be tops in enduro and commute class. The bmw 650 is a bit underpowered for me. But that depends on what you are used to. If your used to scramblers and 125s then the 650 is power.
A bike like the bmw g450X would be nice, but not very comfy on the commute. That is another problem with dirt oriented bikes: the plank seat which doesnt lend itself to a commute.
The next thing is tyres. full Knobblies will be eaten up quickly commuting.
if you only have one bike, then the commute will be 80% of the use, and weekend trails and tar the rest, with trails being maybe 5% of the km?
Unless you plan to trailer a dirt bike, or dedicate a bike purely to weekend trails, then obviously the best choice is a road capable bike that can do trails. There the bmw 650 dakar, ktm 690 excel. If you have the height for them. Of the jap stuff, probably the XT. I know you brits like suzuki, but not really popular here. One big plus for bmw here is the dealer network. Honda is crap and takes forever to even get things like brake pads.
Husky would fall under the more dirt oriented and it wont be pleasant to commute on.
2011 KTM 990 Dakar
2009 BMW 1200 GS
.Bishbash.
PostPosted: 11:09 - 26 Oct 2012    Post subject: Reply with quote
Yeah height really isn't an issue for me standing at 6'5" I happily had both feet on the ground and legs fully stretched when sitting on my KTM 450 exc Laughing Laughing
Kradmelder,
When you state 'weekend trials', what do you mean by this? I just intend to have some byway fun, nothing too serious! Wink
PostPosted: 11:11 - 26 Oct 2012    Post subject: Reply with quote
Have you ridden a G650X? Power seemed fine to me.
And the 690 isn't really 'enduro class' - well over weight. More 'rally' to my mind.
And the Husky discussed is very similar to the KTM 690; the only 'more dirt orientated' thing it has is the wider ratio gearbox; but even then, that's more 'dual sport' rather than pure dirt, which tends to go back to a closer ratio.
Kradmelder
PostPosted: 11:16 - 26 Oct 2012    Post subject: Reply with quote
Just rode the 650 dakar and 650 GS. Not my cup of tea.
Dual sport bikes are either more dirt or more road oriented. They are a compromise. We are discussing only dual sport bikes are we not? he wants a commuter and off road bikes. That leaves out proper dirt bikes
2011 KTM 990 Dakar
2009 BMW 1200 GS
The last post was made 13 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.37 - MySQL Queries: 13 - Page Size: 138.68 Kb
