Suzuki GS 125 Rebuild - Passed MOT :-)
Efes123
PostPosted: 07:56 - 25 Oct 2012    Post subject: Suzuki GS 125 Rebuild - Passed MOT :-) Reply with quote
Being relatively new to the bike scene, about two years now, I passed my test last year, and decided it was time to learn a bit more about how bikes are put together. I didn’t think it would be wise, or healthy, to play with my daily ride (Honda VT500), so I started looking for a cheap 125 I could play with.
I didn’t want to spend too much, as I had a sneaky suspicion that I would be throwing a fair bit at the bike taking into account my noobness; I was bound to order wrong parts.
So, after checking on Fleabay and asking around, I ended up with a Cat B write-off 1984 Suzuki GS125.
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/Suzuki-Original1.jpg
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/Suzuki-Original2.jpg
As you can see, there’s no front end, but I wasn’t too bothered as I didn’t intend putting it back on the road. First things first, I botched some electrics, and got the engine to turn over, and to be honest, was surprised how good it sounded. So, the next thing was to strip it down. Being the impatient kind, I set about this with a vengeance and soon was the proud owner of a pile of bike bits, and an awful lot of bolts and nuts.
It was at this point that I had the bright idea that it would be good to get her back on the road. After a large amount of reading, I figured I’d need a new frame, as there’s no way a Cat B frame is allowed back on the road. A bit of begging later, and I was the proud owner of a new frame, and front wheel.
First off, strip the new frame and give it a nice coat of Hammerite;
Next, get a gallon of degreaser, a big bucket, and dump all the bits and bob into said bucket.
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/new_frame1.jpg
While that lot was soaking, I set about removing the engine from the old frame;
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/IMG-20120517-00047.jpg
Cleaning it up, and giving it a quick spray with high temp black and silver.
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/Suzuki-Engine_Wheels.jpg
I did spend a while cleaning the front wheel, but will need to spend a bit longer on the rear. Now, slap the engine back in the new frame, and attach the wheels. It was at this time that the other half decided she was going to do her CBT. Although I was very happy about that, it meant that I knew I would have to spend that little extra to make sure the bike looked as good as it could.
Starting to look half decent Laughing A complete re-wire later, and we’re starting to cook with gas.
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/Ipswich-20121019-00359.jpg
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/Ipswich-20121019-00360.jpg
The sharp eyed amongst you will have noticed the change in forks. The first lot I got for £20 off Fleabay, unfortunately, they were for the version with a front drum brake, so I had to go for a new set.
I've still a bit to do, as I'm having trouble starting her at the moment Crying or Very sad The missus has booked her CBT for the 10th, so I need to get the last bits done fairly quickly.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
mr-jermy
PostPosted: 08:48 - 25 Oct 2012    Post subject: Reply with quote
You've done and awesome job with that, looks awesome Smile
Efes123
PostPosted: 12:03 - 25 Oct 2012    Post subject: Reply with quote
Thanks, it'll be awesome when I get the bloody thing started Evil or Very Mad
Still learning about the actual engine mechanics side, so slow going.
GrumpyGuts
PostPosted: 12:32 - 25 Oct 2012    Post subject: Reply with quote
The engine is piss easy. I tore that bastard apart when I had my EN 125 (Exactly the same engine as the GS) so if you need any help, ask Thumbs Up
EDIT: Go on my profile and you'll see my thread about changing the head gasket, which led to the piston being replaced with me wondering why the cam chain was loose Laughing
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Efes123
PostPosted: 12:46 - 25 Oct 2012    Post subject: Reply with quote
Not when you're a noob like me Crying or Very sad
The engine was ruuning prior to the rebuild and I haven't really touched it Question
New spark plug, new carb, all electrics work. It turns over, but won't fire Evil or Very Mad
EDIT
Mmmm, probably the problem Evil or Very Mad
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/Suzuki-starter.jpg
Efes123
PostPosted: 08:03 - 27 Oct 2012    Post subject: Reply with quote
Right, brand new Jap starter motor fitted Shocked Could have got a chinese one for half the price, but as they seem to be made out of chewing gum and tin foil, I thought I'd go for quality.
So far I've bought new;
forks
carb
spark plug
battery
indicators
exhaust
and now starter motor
Along with new rubbers and seals etc. the cost is running at around £700. I don't mind, too much, as it's still cheaper than buying an equivelent, but I'd rather not spend much more.
I tried to start her again yesterday but despite firing for a couple of seconds, she died straight away. I'm thinking it's got to be mixture. So, more research, and more trial and error on the cards for today.
at106
PostPosted: 13:29 - 27 Oct 2012    Post subject: Reply with quote
The bike's looking good Thumbs Up When i rebuilt mine it cost a lot more than i expected but it didn't really matter as i also learn a lot!
A for the running issues have you checked the following,
fresh fuel
fuel flowing to carb
jets, float height and needle position correct, if you need specs from the manual let me know
tried playing with the choke while trying to start?
blocking the carb intake
put fuel down the spark plug hole to get it to fire
checked valve clearances
easy start
That's all i can think of at the moment but it should give you something to check!
Efes123
PostPosted: 17:49 - 27 Oct 2012    Post subject: Reply with quote
Finally got the bike started. Turned out to be some carbon build up on the kill switch. So, whilst it was off, it was putting a small resistance through the circuit. Engine sounds really sweet Very Happy
GrumpyGuts
PostPosted: 17:52 - 27 Oct 2012    Post subject: Reply with quote
Video or it didn't happen Laughing
Efes123
PostPosted: 18:00 - 27 Oct 2012    Post subject: Reply with quote
I know, if it wasn't for my mate, who's a mechnic of 20 years, I'd have never have found it.
Efes123
PostPosted: 10:20 - 28 Oct 2012    Post subject: Reply with quote
OK. I seem to have aome play in the yoke, and I feel as though I'm missing a part. The yoke looks like this;
https://www.ebay.co.uk/itm/SUZUKI-GS125-1988-BOTTOM-YOKE-BREAKING-BIKE-4-SPARES-/281002135833?pt=UK_Motorcycle_Parts&hash=item416d085119
All I have is a rubber cap that sits on the top, under the main screw. Looking at the top end of the yoke, there are 4 slots cut out, you can just see them at the bottom of the picture. What goes here? It looks as though something should slot into it, not just have a rubber cap, tope of yoke, then the screw Crying or Very sad
GrumpyGuts
PostPosted: 11:37 - 28 Oct 2012    Post subject: Reply with quote
Brooks Barn. They have everything you can imagine for this bike. Look there. I would send you the Haynes manual but the new owner has it Mad
pdg
PostPosted: 13:49 - 28 Oct 2012    Post subject: Reply with quote
The thing with 4 slots cut out is a nut, you do it up (or undo it) to adjust the steering head bearings. The slots are for a C spanner.
Efes123
PostPosted: 15:42 - 28 Oct 2012    Post subject: Reply with quote
Thanks, but thy only seem to have 10 producsts for the GS, and I have the Haynes, but it doesn't seem to detail the yoke.
Efes123
PostPosted: 15:44 - 28 Oct 2012    Post subject: Reply with quote
Yep, just found out, but thanks. I'll have a look later/tomorrow. It's odd, when I brake hard The whole front end moves forward about 1/4 inch. The forks are solid, but there seems to be play in the yoke.
cb1rocket
PostPosted: 16:47 - 28 Oct 2012    Post subject: Reply with quote
head bearings adjusted and done up?
GrumpyGuts
PostPosted: 18:53 - 28 Oct 2012    Post subject: Reply with quote
Efes123 wrote:
Thanks, but thy only seem to have 10 products for the GS, and I have the Haynes, but it doesn't seem to detail the yoke.
If you look under EN 125, 99% of the parts will fit the GS. Just make sure you double check before buying, even if you have to ring them.
Efes123
PostPosted: 11:34 - 29 Oct 2012    Post subject: Reply with quote
Now there's the problem Crying or Very sad
No bearings in the yoke Evil or Very Mad
So, now I have to find the right ones. I do have a spare yoke, with bearing, bu they are tapered, and this frame hase straight.
cb1rocket
PostPosted: 11:46 - 29 Oct 2012    Post subject: Reply with quote
don't skimp on this. Also its very dangerous riding the bike like that, instant MoT failure. Expect some headstock frame damage. Get new tapered bearings, don't use the old ones and stop riding the bike till this is sorted.
pdg
PostPosted: 11:50 - 29 Oct 2012    Post subject: Reply with quote
If by 'straight' bearings you mean round, then they should be 1/4". Usually 18 or 19 on each side (put them in, then when it looks like one more will just fit, leave a gap).
Proper bearing supplier will be cheapest, then pushbike shop, or if you're feeling very rich go to a Suzuki dealer (or ask in the dealer first to confirm the size and amount...)
pdg
PostPosted: 11:59 - 29 Oct 2012    Post subject: Reply with quote
I'm not sure the bike is being ridden, looks more like it's still being built.
I'd be very surprised if it's damaged the frame, unless the cone has worn through the cup sufficiently to allow the yoke to contact the headstock. It's more likely you can just pop new balls in with grease and it'll be fine - pictures would confirm either way though.
While tapered bearings are 'better' there's nothing at all wrong with using cup and cone ball bearings. Tapered are much less serviceable too.
Efes123
PostPosted: 12:06 - 29 Oct 2012    Post subject: Reply with quote
No, there are these;
https://www.ukbikeparts.net/acatalog/HeadBearing.gif which are tapered, and then there's these;
https://www.sip-scootershop.com/en/products/steering+head+bearing+set+_90124000 which aren't.
I do have an old frame which has the tapered fittings insike the yoke tube*, but these will be a bastard to get out, and I'll probably damage them in the process.
* This bit;
https://www.dogfriendlysuffolk.com/bikepics/Rebuild/Suzuki-yoke-paint.jpg
pdg
PostPosted: 12:19 - 29 Oct 2012    Post subject: Reply with quote
That scootershop link is for a set of ball bearings, pictured in races. They may even be captive, but they are still balls.
The gs never had captive bearings, they had loose balls running between two races.
Oh, and I know the difference between tapered roller bearings and ball bearings, I also know what a head tube is. But whatever.
Efes123
PostPosted: 12:30 - 29 Oct 2012    Post subject: Reply with quote
Yeah, I know they're balls, it's the container the balls are in that I'm talking about being tapered. The tapered ones won't fit into the existing yoke 'tube' Crying or Very sad
pdg
PostPosted: 12:38 - 29 Oct 2012    Post subject: Reply with quote
The picture of the bearing is of a tapered roller - it doesn't use balls, it uses rollers.
If your existing headset bearing race (bit in the tube) doesn't accept the tapered rollers then it needs balls - or you can tap out the ball race and press in new taper races.
At the top, there should be a bit under the nut (circle with 4 slots) on the yoke steerer tube that is the other race. At the bottom, the headset race will look the same as the top, but the yoke race will be pressed on to the steerer tube.
The last post was made 13 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 145.19 Kb
