Motorcycle Muffs + handguards.
C1REX
PostPosted: 12:18 - 28 Oct 2012    Post subject: Motorcycle Muffs + handguards. Reply with quote
Hi,
Can motorcycle muffs be fitted over hand guards?
I'm planning to fit something to let me survive winter riding and muffs seems to be the best option.
It's a VanVan with Venom guards
https://s19.postimage.org/9rx2q4co3/1_DSC_5585_001.jpg
images
Kris
MCForum meetup - One of the biggest motorcycle clubs in UK
BigDan1190
PostPosted: 12:30 - 28 Oct 2012    Post subject: Reply with quote
Yes, and its the best way to do it.
A lot of the time, muffs get blasted by the wind and actually push back on brake and clutch levers. Handguards eliminate this problem and keep the muffs in place.
C1REX
PostPosted: 12:36 - 28 Oct 2012    Post subject: Reply with quote
Big thanks!
Any suggestion on good muffs?
Kris
BigDan1190
PostPosted: 12:47 - 28 Oct 2012    Post subject: Reply with quote
I used the Oxford Bone Dry ones, because frankly all the furry stuff inside a lot of muffs these days isn't a good idea because they don't actually get or stay warm. They just get wet, take forever to dry, and get mouldy.
The bone dry ones are just plain textile, but they do a good job.
instigator
PostPosted: 12:56 - 28 Oct 2012    Post subject: Reply with quote
Or just take your bar end off, install muff, once in place and it's not fouling on the levers, use a screwdriver to stab a hole in the muff, through where it sits against where your bar ends fixes into....and then install bar end back on, on the exterior. Done.
ginny
PostPosted: 12:59 - 28 Oct 2012    Post subject: Reply with quote
If you get tucano urbano (neoprene) muffs you don't need to worry about them deforming with wind resistance at speed. They could/should be mounted on their own
C1REX
PostPosted: 13:02 - 28 Oct 2012    Post subject: Reply with quote
https://i.ebayimg.com/t/Oxford-Bone-Dry-Motorcycle-Handlebar-Muffs-OF82-/00/s/NDgyWDYwMA==/$(KGrHqJ,!pwF!Lrr1fBzBQWHOrNRVQ~~60_12.JPG
Do you think I can put this on without any modifications?
BigDan1190
PostPosted: 13:07 - 28 Oct 2012    Post subject: Reply with quote
I do that too Smile
i.p.phrealy
PostPosted: 22:40 - 29 Oct 2012    Post subject: Reply with quote
don't the hand guards keep your hands out of the wind anyway? I was going to buy some handguards as my fingers get REALLY cold on the bike, even in winter gloves.
bazza
PostPosted: 23:01 - 29 Oct 2012    Post subject: Reply with quote
This. They include a plastic bracer which prevents the muffs pressing back on the levers. Fitted mine back on yesterday in about 20 mins ready for the cold/wet weather.
Formerly known as
P.
PostPosted: 23:06 - 29 Oct 2012    Post subject: Reply with quote
Tucano Urbano.
I left my Oxford bone drys by the side of the M20 as they were;
A, Letting in water.
B, Pushing on my brake lever.
C, Hitting the switch gear turning the lights and killswitch off.
I have fitted the Tucano's, they don't go over the switch gear, they are totally waterproof and sealed, not like the Oxford SuperWets where they "popper button" together and they come with plastic guards inside that go over the grip and round past the levers to ensure they don't get pushed onto levers.
They also attach to your bar ends.
I've had no trouble with them, ever.
Noxious89123
PostPosted: 23:21 - 29 Oct 2012    Post subject: Reply with quote
If you do a forum search you'll see that plenty of people have asked about the oxford muffs and are often given the same opinion by many members; they're rubbish.
I tryed some myself, but they were unusable at even 30mph, they just fall straight back onto the levers. Sure you could probably use them with handguards if you have them, but tbh if I was going for muffs again, it'd be the tucano urbano ones. Read ;oads of great reviews of them, and they look well designed to avoid fouling the controls.
C1REX
PostPosted: 00:01 - 30 Oct 2012    Post subject: Reply with quote
Lots of people recommend tucano.
I'm just not sure witch ones.
Seems like there is few models and some of them won't go over my hand guards.
I don't worry that the muffs will push the levers as it's simply not possible with hand guards.
Do you know what model will go well with venom guards?
I don't want to pierce or tear my muffs.
Noxious89123
PostPosted: 00:48 - 30 Oct 2012    Post subject: Reply with quote
Why not remove the guards? Don't really need them if you're fitting muffs.
C1REX
PostPosted: 00:54 - 30 Oct 2012    Post subject: Reply with quote
I need the guards. Saved me and bike few times already.
sickpup
Old Timer
PostPosted: 09:47 - 30 Oct 2012    Post subject: Reply with quote
Never known a set to do that. In fact the furry ones have a metal band on the opening so you can close them when not riding so I'm intrigued as to how any get in this state?
Why did you buy the absolute worst brand of muff on the market exactly. Just wondering as they are expensive, not self supporting and don't actually fit anything without cutting. Just wondering like?
PostPosted: 09:57 - 30 Oct 2012    Post subject: Reply with quote
I've got Oxford muffs and found they sucked - however when used around the hand guards on my KTM did an ok job in combination with heated grips - while they don't offer the wind and rain protection of decent (to my mind) muffs, they are easier to get hands in and out of and moving around in when off-roading.
For normal road biking I'd much prefer to go for 'furry' ones like the urbano's - they get and stay much warmer, don't get as wet (never gone mouldy) and generally keep my hands much, much warmer.
pits
PostPosted: 10:57 - 30 Oct 2012    Post subject: Reply with quote
He needs to get his hand inside terh lawrz muff, so warm, soft and you feel all the inside, yet slightly cavernous, I know if I had a muff it would be like lozzies Wub
So big and warm that even Recluso managed to get her gash in there, or so I have heard.
goto10
PostPosted: 11:39 - 30 Oct 2012    Post subject: Reply with quote
I have Venom hand-guards on my ER5, I can't see how you'd get muffs over them without some butchering!
Last winter I used some canvas & cable ties to make little wind-breaks (tied some canvas from the handguards to my mirrors) kept the wind off a treat.
I have Tucanos (R361) on the NC, they have plastic spines that keep the muff from pushing on the levers.
iooi
PostPosted: 12:03 - 30 Oct 2012    Post subject: Reply with quote
Yes they deflect a lot of wind. But it then curls back over top/bottom.
So they are not the be all to end all in keeping your hands warm.
OP. Take the plastic off and leave the backbone in place and fits muffs over that.
Whosthedaddy
PostPosted: 12:22 - 30 Oct 2012    Post subject: Reply with quote
So what are the better muffs to use?
fatjames
PostPosted: 14:01 - 30 Oct 2012    Post subject: Reply with quote
On the Urban Rider website (https://www.urbanrider.co.uk/) you can chose muffs based on bike make/model fitment.
eg, for my er6f they recommend the "R361" @ £40
Formerly known as
P.
PostPosted: 14:07 - 30 Oct 2012    Post subject: Reply with quote
Brick Wall
Tucano Urbano Wink
barrkel
PostPosted: 16:49 - 30 Oct 2012    Post subject: Reply with quote
##Paddy## wrote:
Brick Wall
Tucano Urbano Wink
Well there are two basic types of TU - the textile furry ones and the neoprene ones. The textiles keep the switchgear on the inside, the neoprenes keep it on the outside.
Would be good if people recommending TU mention which type they have.
I have neoprene ones (361) on my SH300 scooter and they work well enough - I used longer bar end bolts and a couple of penny washers to keep them well stuck on, because the rubber cups on the inside don't stay on long on their own. Accessing the indicators / horn / start button is all fine, but accessing the main / dip beam is a bit of a stretch. If I were using muffs on my ER6, I think I'd go for the textile version.
Formerly known as
P.
PostPosted: 17:00 - 30 Oct 2012    Post subject: Reply with quote
Good point,
R361 Neoprene bar end ones.
Superb stuff, I've not had my cups fall off yet and have done ~1000 miles since fitting.
The last post was made 13 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 132.27 Kb
