How often should I?
Darth-Simba
PostPosted: 15:39 - 03 Nov 2012    Post subject: How often should I? Reply with quote
Check brake fluid levels, I check my oil every week. Also do I need to top up water/anti-freeze like in a car. Call me a noob if you want but this is my first time owning powered 2 wheels. Thanks guys n gals.
CaNsA
PostPosted: 15:44 - 03 Nov 2012    Post subject: Reply with quote
I do it whenever i remember.... which aint that often.
Kradmelder
PostPosted: 16:24 - 03 Nov 2012    Post subject: Re: How often should I? Reply with quote
Well it depends how much you ride. On a trip i check my tyres evvery 2nd day and lube the chain very day. Oil and water every few days.
Normal commute, ffluids every few weeks and tyres every week.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Magnet
PostPosted: 01:11 - 04 Nov 2012    Post subject: Reply with quote
Its posts like this that remind me to check my bike over Rolling Eyes I suppose if I were sensible I would say check your bike as often as possible. It only takes a few minutes to give it a going over and don't forget to lube that chain Wink
It’s not that I’m so smart, it’s just that I stay with problems longer.
GPZ600R Sold, Now ZZR600
covent.gardens
World Clap Champion
PostPosted: 01:55 - 04 Nov 2012    Post subject: Reply with quote
In the operators manuals for most motorcycles you will find that it'll include Brake fluid and Coolant under Daily checks... Shocked
I don't know anyone who actually does all the Daily checks, every day... I certainly don't (unless it's a new vehicle to me, then I check it more often because that gives me a chance to realise if it's burning oil or losing fluids).
Once I've "got to know" the bike, these "daily checks" get done when I start to feel guilty because I haven't done them in so long. Confused
Once a week is probably a sensible timescale to give the bike a proper check over.
PostPosted: 03:13 - 04 Nov 2012    Post subject: Reply with quote
Depends on the bike.
My enfield uses an extraordinary quantity of oil so I check the oil level at every fuel stop.
My VFR does not deplete any of its fuel or lubricant levels between services so I check them once in a blue moon.
In short. Check them frequently. You'll get used to how often you need to after a bit.
tom_m
PostPosted: 04:55 - 04 Nov 2012    Post subject: Reply with quote
not checked the brake fluid in my ybr yet, and ive done 7,000 miles since may, i may have a look tomorrow...
Current: 2005 Kawasaki Er-5 C5P
Past: 2012 Yamaha Ybr 125, 2004 Yamaha Neos 50, 1994 Suzuki Gn 125, 2005 Aprilia Sportcity 125, 1988 Yamaha Tzr 125
Theory: Passed... Mod 1: Passed 22/08/12 Mod 2: Passed 22/10/12
WillOdling
PostPosted: 10:22 - 04 Nov 2012    Post subject: Reply with quote
Just glance at the brake resevoirs every now and then but why not check everything every Sunday or something? Only takes 5 minutes to check over the bike and your proper Thumbs Up
2002 GSX R600
esullivan
PostPosted: 10:32 - 04 Nov 2012    Post subject: Reply with quote
I commute about 150 miles a week. This is the routine I've settled on:
Each day, usually in the morning before setting off, I do a quick walk around the bike, looking for anything obviously falling off, squeeze the front and rear tyres, and check the indicators and the rear brake light. The brake fluid is a little reservoir by the handle bars, so that just takes a glance. I've not had to touch that in 3,500 miles, but it's possible it was topped up at the 600 and 2,500 service intervals (I have a CBF 125).
Every few days, especially if I've done lots of filtering, I inspect the tyres more carefully for embedded pebbles or other road crap you find between lanes and look for any cuts: Put the bike on the centre stand, wet thumb and swipe across type, and then inspect until you see the mark again.
Each week (on Saturday or Sunday, whichever is drier), I check the tyre pressure, clean and lube the chain, check the oil. I usually clean the bike then too, at the local jet wash, if it is at all decent out. This week's routine also included spraying some ACF50 around the exhaust and engine, winterising.
Hope that helps!
CaNsA
PostPosted: 10:46 - 04 Nov 2012    Post subject: Reply with quote
That means going outside when its cold.
sod that for a game of soldiers
illuminateTHE...
PostPosted: 10:51 - 04 Nov 2012    Post subject: Reply with quote
most of the above ride big bikes which drink oil etc.. as you are on a 125cc your fluids on your bike will last allot longer.. try checking your owners manual for things like 'service intervals' to find out when you need to topup etc. Don't do this with engine oil, check it as often as you can.
thepuma
PostPosted: 12:21 - 04 Nov 2012    Post subject: Re: How often should I? Reply with quote
You lube your chain every day? Seriously?
765 RS
mentalboy
PostPosted: 12:37 - 04 Nov 2012    Post subject: Reply with quote
Krad's potholes don't seem to have Tarmac round them though!
Make mine a Corona.
Acemastr
PostPosted: 13:14 - 04 Nov 2012    Post subject: Reply with quote
Had a peek at the coolant once, wiggled the bike, attempted to see through the coolant tank... couldn't... gave up.
Brake fluid, I glance at the sight glass once... every couple months.
Oil, I really should check it more, it just doesn't really use any
2016 Toyota Tacoma Limited
WillOdling
PostPosted: 13:23 - 04 Nov 2012    Post subject: Reply with quote
My bike lives indoors in a heated garage. But Yeh if it was outside and cold, fuck that
2002 GSX R600
cimbian
PostPosted: 14:08 - 04 Nov 2012    Post subject: Reply with quote
When all else fails... RTFM Wink
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
barrkel
PostPosted: 14:27 - 04 Nov 2012    Post subject: Re: How often should I? Reply with quote
When touring, I'd do between 300 and 600 miles a day. At that rate, you want to lube your chain every day, if not more often; every second refuel is a handy rule of thumb.
I got a scottoiler instead, and bring a refill bottle with me rather than go with the touring scottoiler options.
Low tyre pressure has very noticeable effects on the handling on the bikes I ride. The extra friction of the tyre feels like dragging the brake, and on the front especially it makes the handlebars pull towards the inside of the turn. So I tend not to check pressures very often. I'll check my ER6 before any big trip and bring a gauge with me though, and probably check once every day or two over the long distances.
I've never gotten a puncture on a scooter in over 20,000 miles of riding, half split between London and touring to Scotland and Ireland. Got one on a YBR in a tenth that distance (plugged it). I check the tyres for embedded things perhaps once every 6 weeks, unless the pressure is off or I know I rode over something dodgy.
Kradmelder
PostPosted: 16:14 - 04 Nov 2012    Post subject: Re: How often should I? Reply with quote
On long trips I am doing over 500 km per day. Up to 900 km. And much is gravel so it is very dusty. If i dont remove the sdand and reoil chain and sprocket life plummet.
Moving metal and sand are not the most compatible bedmates, unless lots of lube is present Mr. Green
Takes less than 10 min to run a chain brush across the chain and relube at the end of the day. How long does it take to put on a new chain and sprockets?
2011 KTM 990 Dakar
2009 BMW 1200 GS
Kradmelder
PostPosted: 16:17 - 04 Nov 2012    Post subject: Re: How often should I? Reply with quote
Some parts of SA there are these things called 'bossies'. Little balls with small thorns on them. They are the seeds for thorn trees in the karoo. They blow across the road. In such areas, every 10 km I stop to pull them out of my tyres before they embed themselves too deep. And I have heavy duty tubes. Needless to say, average speeds drop to well below 50 kmh.
Better that than risk punctures.
2011 KTM 990 Dakar
2009 BMW 1200 GS
Kradmelder
PostPosted: 16:24 - 04 Nov 2012    Post subject: Reply with quote
True. Air cooled bikes, and high performance motors on synthetic oil tend to use more oil. But if my oil level is full I can easily do 3000 km trip without topping up. I find I top up once between services. But my bikes are newish.
Chinese bikes, checking for loose nuts and bolts becomes more important than fluids.
2011 KTM 990 Dakar
2009 BMW 1200 GS
The last post was made 13 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.55 Sec - Server Load: 2.51 - MySQL Queries: 13 - Page Size: 112.71 Kb
