| Briandude |
 Briandude Derestricted Danger
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:28 - 04 Nov 2012 Post subject: |
Make life easy for yourself:-
HOW2: Top End Rebuild Honda CB125 (Benley Motor)
You might be able to free the bores off, with two-stroke oil down the spark plug holes and gently working the crank round on the rotor bolt, BUT.
These bikes suffer horribly from long lay-up. They have tiny pistons & they are a very high performance motor for thier size, reving to 12,000rpm, and they start to go 'off' and loose performance just for slightly worn piston rings.
Layed up rings stick in the piston grooves, long before the pistons sieze in the bore. Freed-off, they will run, and often run reasonably well, but within 500 miles they will die... horibly. The gummed rings let the piston run on the bore, you get incredibly accelerated bore wear, burned oil and then the motor just stops running.
Other things is the valve seats rust, and need grinding, and you cant remidy that without opening the engine....
AND you presume the motor is siezed due to pistons stuck in the bores, I would not discount the fact that the engine was pre-siezed, by being run out of oil..... good reason it has sat for two decades unused that.... or two decades has seen oil replaced slowly by condensation & the main crank bearings rust.
I have done a number of these bikes, and have had to rebuild at least three engines from long-lay-up problems, which weren't so bad pistons were glued in bores.
New barels & pistons are about £90, I would PLAN on doing a top end rebuild as 'course', but hold of ordering expensive bits until I had opened the top and seen what I was dealing with and whether it was really worth doing, and had some idea whether the crank was serviceable. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Briandude |
| Briandude |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Briandude |
| Teflon-Mike |
 Teflon-Mike tl;dr
| honda cg 1992 |
 honda cg 1992 L Plate Warrior
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:41 - 10 Nov 2012 Post subject: Re: honda cb125 superdream fitted with a 250 engine |
| honda cg 1992 wrote: | hi dont suppose anyone could help i brought a cb125 superdream which has had the cb250 superdream engine fitted |
https://i.ebayimg.com/t/Honda-Cb-125-Cb125t-cb125-Cb250-250-engine-fitted-Street-Sleeper-Special-LOOK-/00/s/MTIwMFgxNjAw/$(KGrHqZ,!lwF!eTB8pnYBQUiH4P53w~~60_35.JPG LOR726Y by any chance?
Is so NOT a 250 'Super-Dream' engine.
250 Super-Dream was the Honda CB250N, and used a sleeved down 400N engine; that's a totally different 'family' of engine to the CB125 'Super-Dream' that uses the 'Benley' based engine.
VERY difficult to shoe horn a 250N engine into a 125 Super-Dream frame; its a lot taller, a lot longer, being basically a 500 lump, with counter-balence shafts and stuff, and has completely different engine mountings, meaning the frame would have to be very signiticantly modified to make it fit.
THAT bike, I suspect may be yours was sold a few weeks ago on e-bay, chap selling it spamming on Super-Dream threads on here.....
Fitted with a CB Two-Fifty engine..... IF its a 250 engine.
CB Two-Fifty, 'Night-Hawk' or CM250 Rebel (of the right era) uses the small-block benley engine, same as the CB125, and is almost bolt for bolt interchangeable in the frame.
Its not actually 250cc, its 233cc, and often called the 233 'engine', and it differs from the 125 Super-Dream motor in a number of ways, apart from the bore & stroke dimensions that are 53x53 instead of 41x44. Most of the Benley family motors use a 360 degree crank. that is the pistons in both barels rise & fall at the same time. 125 S-D has 180 crank, one piston up, one piston down. This gives a different firing interval, and where the 360 engines have a single 'siamese' coil firing both cylinders triggered by a single ignition circuit, Super-Dream has two almost independent ignition systems firing individual coils at the different timings. Likewise the cam-shaft has to open & close the valves at different intervals, so has different lobe phasings, and actually a much softer profile. Comporession ratio is also lower, and the engine is designed to run on a single carburettor, not the two of a Super-Dream.
| honda cg 1992 wrote: | but i am having problems it is only running on one cylinder and on the odd occation the second cylinder will fire up but not for long i changed the coil packs as i though it could be a dodgie spark but it didnt cure the problem it revs up to about 6-7 thousand if you let go of the throttle it will die and when the other cylinder fires it revs up fine its really confused me |
So we come to your problems..... and we need to know, first whether you have the bike I referenced, with the 233 Benley engine, or one like it with a 233 motor, or if it really is a 250N 'Super-Dream' motor.
We then need to fathom how its been hybridised into the 125 Super-Dream.
As said, 125 Super-Dream has twin ignition circuits..... if you bolted in a 360Degree 233 lump and plugged in the generator connectors and attached the HT cleads from the 125 'loom'... it would only run on one cylinder, the spark timing on the other would be 180 degrees retarded!
But might not be an ignition problem; Benleys are prone to starting on just one pot, and when the bores are worn or they are low on compression, they will fire on one pot, weakly, and then fire on the second when they pick up some revs, but die as soon as they are put on load.
Could be just a tired engine....
OR.... carburation. 233 motors are mostly intended to run on a single carb. Has it got the carb from the 233 engine & single manifold, becouse that would mean dumping teh Super-Dream air-boxes, and would put the mouth of the carb close to the mono-shock top mount, which can cause some eratic carburation.
If its got the 125's twin-carbs, well, then its probably rather more than a little under-carburated and the carbs will be jetted very wrongly for that engine.
UK spec Super-Dream 125 rund two 14mm Keihin carbs, but is teh de-tuned 'Reduced-effect' model. The full power 125 ran twin 26mm Keihins, with different jets, and that was to let the little 125 breath at the high revs it turns and make 17bhp.
Night-Hawk motor makes about 19bhp, but at lower revs..... so going by the power rating the twin-carbs from the 125 Super-Dream would be too small for the power of the night-hawk motor, while jetting in either 24 or 26mm carb would not necesserily suit the 233 motor that is in a very different state of tune.....
So, carburation problems could be a factor, and again, we dont know how the bikes been hybridised......
And then we have the common bug-bears of the Super-Dream of rusty tanks, silted up fuel taps, and sticky float needles, that could ALL contribute to the sort of symptoms you describe.....
and THAT is just if its as I suspect a 233 motor, not the older 250N lump!
To help you...... and it sounds like you need a lot!..... we need to know a hell of a lot more about your bike; what it IS, and what's been done to it, to give you the mongrel you got, because it ENT going to be in any Haynes manual..... its a Hot-Rod and this is the kind of problems you get buying one!
Oh.. and if it is LOR-Y, then we only have the 'suggestion' its a 233 motor, made by the e-bay seller, who claims to have identified it as a CB250 engine..... from pics in that add, I'm not so sure. Could be a CM250 engine, could be a CMX250 engine, could be a CD250U lump. Could also be a CD200 engine, or even a CM125 or CD125..... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 20:53 - 10 Nov 2012 Post subject: |
mike and i may help post the pic of the bike and the engine (close up) also the engine number itself will help ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Briandude |
| Briandude |
| Briandude |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:13 - 20 Nov 2012 Post subject: |
| Briandude wrote: | Ok finished the carbs, front and back wheels brakes, mono shock, engine back in, engine turns over but will not fire ;( , getting a good spark at both plugs, had carbs off again made sure they were spotless, that's it so far will keep at it, any advice always welcome... |
Suck-Squash-Bang-Blow... you need the three ingredients for 'life',
- compression
- spark
- fuel
So you have a spark.... is it at the right time? Try swapping the LT wires on the coils, see if they are the wrong way round (could have timed cam in 360 about to what it was)
Carbs are 'clean' - are they getting fuel. Sediment in the tanks is a bitch on these bikes. Fuel tap silts up, but even cleaned, tank can still have a lot of crap choking flow.
BUT.. compression. When I rebuild I use two-stroke oil as assembly lube to make sure that stuff is not rubbing 'dry'. Also helps give a little compression on first fire, BUT, first fire has to burn off excess assembly lube (why I use more easily combusted two-stroke oil)
Have you used assembly lube? Is there still a lot floating around?
If you haven't. then get some down the plug holes before you snag a ring! If you have, plugs out, charge battery & let it windmill on the starter for a while pumping oil round, and dispelling excess from bores down the exhaust & out the plug hole.
Clean plug, splash of neat petrol through plug holes before fitting, give it a waz, throttle wide open, see if it will catch. Then down to old fasioned de-bugging.
Before assembly did you clean the valves & seats after lapping properly? Have you set the tappets? After lapping best set a little on the wide side to let the valves 'bed' on first fire, then re-adjust after 'burn-in' idle running / first run, before final fettle.
Carb-Rubbers? Air-Leaks? Choke Mechanism?
Eliminate carbs with neat fuel down the throats and a wide open throttle, see if she kicks in, when mixture depleated to stoic!
All tinkering now, I reckon - fiddle long enough and logically enough, you'll get there.  ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Briandude |
 Posted: 03:09 - 21 Nov 2012 Post subject: |
It's alive woo hoo, I was getting a bit miffed with it all, re read manual, re read your articles, I used 2 stroke to lube everything on rebuild, I thought I may have done timing chain wrong, triple checked that and rechecked tappets they were fine, noticed a bit on oil on front of cylinder head bolt the one on its own at the front so downloaded conversion app and changed the pounds to Newton metric and retorqued head down, I thought sod it so got plugs out again and cleaned with emery paper and refitted, and it started first turn, so don't quite know what the problem was, but it works.
I was lucky enough to have another tde to rob from, it was a bike of eBay that was a bag of crap it had 12 months mot on it, god knows how it was falling to bits but nicked tank of it cos the one on elf y was rusty and the tap was blocked.
Anyways again thanks for your help teff, I will post some pics of it when I get chance,, then when that's finished I got a cb125rs to sort, glutten for punishment.. |
| Briandude |
The last post was made 13 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 107.75 Kb
