ajs parts
andyhazell81
PostPosted: 13:31 - 08 Nov 2012    Post subject: ajs parts Reply with quote
hi only my second post on here but does anyone know about part compatibility on the ajs nac as i need a chain sprockets and have heard they might be the same honda cg parts just wondering if anyone knows this to be true as the parts from ajs are real expensive
ajs cr3
Zen Dog
PostPosted: 15:38 - 08 Nov 2012    Post subject: Re: ajs parts Reply with quote
No idea. Probably no-one else does either. But from having a quick look at pics and spec of the bike, I can be pretty sure that there won't be many, if any, compatible parts. The AJS is clearly a completely different bike, not a CG clone, which pretty much rules out most frame/chassis parts, and the engine is apparently a 125 twin, whereas the CG is a single, which rules out engine parts.
The chain and sprockets might be co-incidentally the same, but the only way to find out would be to buy both and compare. Also, there are loads of versions of the CG, so even if some versions were compatible, getting the right one would be blind luck. Is there an AJS forum? Might have more luck trying there.
Good Luck.
Zen Dog
truslack
PostPosted: 15:40 - 08 Nov 2012    Post subject: Reply with quote
Threads about Chinese "AJS" bikes make me sad Crying or Very sad
andrew
Mister Road Rage
PostPosted: 16:10 - 08 Nov 2012    Post subject: Reply with quote
This ^.
https://www.ajsmotorcycles.co.uk/new_AJS/docs/main.htm
"Our company's origin can be traced back to the early 1900's when the Stevens brothers - Harry, George, Jack and Joe set about producing AJS motorcycles.The initials AJS were taken from Albert John (Jack) Stevens, the only brother to have a middle name. "
Oh right. Rolling Eyes
UnspeedySam
PostPosted: 16:30 - 08 Nov 2012    Post subject: Reply with quote
Call up AJS in Alton I'm sure they'll help you. As has been said I'm not sure what it is based on, so it's difficult to know what parts will fit.
nightshaddow
PostPosted: 16:46 - 08 Nov 2012    Post subject: Reply with quote
chain and sprockets are the easiest to find to be honest you may have to research but jts have allot of info on there parts so cross reference between what you have and what they stock
www.jtsprockets.com/
i see what i can dig up for you, also pics of the sprockets will help narrow it down if you have the sprockets off a ruler across would be very helpfull
The last post was made 13 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 49.09 Kb
