| open |
 open Trackday Trickster
 Posted: 23:24 - 08 Nov 2012 Post subject: CB500 what to look out for |
Hi,
Now I have my full licence I am looking for bikes!
Gonna hopefully view this tomorrow:
https://www.gumtree.com/p/cars-vans-motorbikes/honda-cb500-yello/1002147652#gallery-item-full-3
What things should I look out for as I aint got the foggiest?
My mate who knows more about bikes said he would come viewing with me, but he's not free till sometime next week and I dont want to pass up on the chance to get it by waiting. ____________________ "Calamity - A more than commonly plain & unmistakable reminder that the affairs of this life are not of our own ordering."
[s]Baotian BT49qt-9 --> Honda CG125 (4 speed) '51 plate ----- 03/11/2012 Mod 2 PASSED! --> Cb500s[/s] Revoked  |
| Hobgoblin |
 Hobgoblin Trackday Trickster
 Posted: 01:05 - 09 Nov 2012 Post subject: |
The exhaust is slightly dodgy-looking
Standard CB500 exhaust is black painted mild steel. That has what looks very much like aftermarket stainless headers fitted onto the back half of a standard exhaust (presumably cut-off) which has remarkably fresh paint on it.
Not the end of the world, it's a cheap bike but check they haven't snapped or bodged any of the exhaust studs on the cylinder head and have a good poke about around where the header pipes meet the silencer for signs of rust and to see how it's been attached. From personal experience, if the headers have let go, it would be almost impossable to undo the clamp on the back part of the system without destroying it.
A CB500 has a mild steel stud with a long, chrome-plated hex nut (long enough to totally cover the stud) holding the headers on, not a bolt.
Check for pulsing on the front brake at low speeds.
Also check for cracks round the holes on the rear disc, cracks in the fairing near the little storage compartment on the right and (since I've never seen a yellow CB500S) make sure it's a UK model with a MPH speedo and an E-marked healight (dips to the left, has a capital letter E in a circle on the lens). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| _mjs_ |
 _mjs_ Could Be A Chat Bot
 Posted: 05:43 - 09 Nov 2012 Post subject: |
Some old ones with sky high milage develop the 'clutch rattle' - a knocking sound when the clutch is disengaged. I'm sure there are videos of this on youtube... basically pull the clutch in while the bike it ticking over in neutral to test for it. It's supposedly caused by the basket becoming chipped or worn.
The older rear drum brake versions can develop a clunking sound when the brake is used. This is easily fixed by removing the brake torque arm and replacing with new washers.
Check the yokes and the frame above the rear wheel for rust.
None of these things really affect how the bike work, they're absolute tanks! Might help you haggle down the price however  ____________________ Previous Bikes: 2006 Honda XR125L > 2003 Yamaha DT125R > 1996 Honda CB500
Current bikes: 1997 Kawasaki ZZR 600 E5 > 2006 Honda Varadero XL125V |
| open |
 Posted: 10:27 - 09 Nov 2012 Post subject: |
Thanks alot guys - with this I feel a lot more confident.
Will let you know how it goes. ____________________ "Calamity - A more than commonly plain & unmistakable reminder that the affairs of this life are not of our own ordering."
| open |
 Posted: 01:17 - 10 Nov 2012 Post subject: |
So I got it in the end. Is a little scruffy but rides smoothly.
Rode it home - was the first time riding a big bike!
Was really fun.
Need to get it restricted ASAP, if not I will never get round to it. ____________________ "Calamity - A more than commonly plain & unmistakable reminder that the affairs of this life are not of our own ordering."
| _mjs_ |
| magicman-alex |
 magicman-alex Two Stroke Sniffer
| covent.gardens |
 covent.gardens World Clap Champion
 Posted: 13:53 - 11 Nov 2012 Post subject: |
The reg/rect is worth checking as its a common problem, its on the left of the bike under the plastic cover and looks similar to this
https://img1.jpegbay.com/gallery/000658533/1_m.jpg
If yours has "fins" then it's a replacement part, if its smooth as in the pic its original, check it for any cracks and undo the bolts to check for corrosion. If it's corroded clean it, if its damaged replace it, as the minimum a faulty one will do is murder your battery.
The sub-air filter or whatever they call it, is probably worth replacing when you have the tank off next, nobody seems to change them and they just fall to bits |
| Ingah |
 Ingah World Chat Champion
| cimbian |
 cimbian World Chat Champion
 Posted: 22:00 - 11 Nov 2012 Post subject: |
Do the tyres have more than 2mm of tread  ____________________ 22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker |
The last post was made 13 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
