CB500 what to look out for
open
PostPosted: 23:24 - 08 Nov 2012    Post subject: CB500 what to look out for Reply with quote
Hi,
Now I have my full licence I am looking for bikes!
Gonna hopefully view this tomorrow:
https://www.gumtree.com/p/cars-vans-motorbikes/honda-cb500-yello/1002147652#gallery-item-full-3
What things should I look out for as I aint got the foggiest?
My mate who knows more about bikes said he would come viewing with me, but he's not free till sometime next week and I dont want to pass up on the chance to get it by waiting.
"Calamity - A more than commonly plain & unmistakable reminder that the affairs of this life are not of our own ordering."
[s]Baotian BT49qt-9 --> Honda CG125 (4 speed) '51 plate ----- 03/11/2012 Mod 2 PASSED! --> Cb500s[/s] Revoked Sad
Hobgoblin
PostPosted: 23:34 - 08 Nov 2012    Post subject: Reply with quote
that ones been relisted on ebay twice by same seller https://www.ebay.co.uk/itm/1998-HONDA-CB-500-S-YELLOW-/221150906770?pt=UK_Motorcycles&hash=item337d9f0992
view it, like it, make an offer?
Try here: https://www.cb500club.net/forum
Plodding along on my CG
PostPosted: 01:05 - 09 Nov 2012    Post subject: Reply with quote
The exhaust is slightly dodgy-looking
Standard CB500 exhaust is black painted mild steel. That has what looks very much like aftermarket stainless headers fitted onto the back half of a standard exhaust (presumably cut-off) which has remarkably fresh paint on it.
Not the end of the world, it's a cheap bike but check they haven't snapped or bodged any of the exhaust studs on the cylinder head and have a good poke about around where the header pipes meet the silencer for signs of rust and to see how it's been attached. From personal experience, if the headers have let go, it would be almost impossable to undo the clamp on the back part of the system without destroying it.
A CB500 has a mild steel stud with a long, chrome-plated hex nut (long enough to totally cover the stud) holding the headers on, not a bolt.
Check for pulsing on the front brake at low speeds.
Also check for cracks round the holes on the rear disc, cracks in the fairing near the little storage compartment on the right and (since I've never seen a yellow CB500S) make sure it's a UK model with a MPH speedo and an E-marked healight (dips to the left, has a capital letter E in a circle on the lens).
_mjs_
PostPosted: 05:43 - 09 Nov 2012    Post subject: Reply with quote
Some old ones with sky high milage develop the 'clutch rattle' - a knocking sound when the clutch is disengaged. I'm sure there are videos of this on youtube... basically pull the clutch in while the bike it ticking over in neutral to test for it. It's supposedly caused by the basket becoming chipped or worn.
The older rear drum brake versions can develop a clunking sound when the brake is used. This is easily fixed by removing the brake torque arm and replacing with new washers.
Check the yokes and the frame above the rear wheel for rust.
None of these things really affect how the bike work, they're absolute tanks! Might help you haggle down the price however Smile
open
PostPosted: 10:27 - 09 Nov 2012    Post subject: Reply with quote
Thanks alot guys - with this I feel a lot more confident.
Will let you know how it goes.
open
PostPosted: 01:17 - 10 Nov 2012    Post subject: Reply with quote
So I got it in the end. Is a little scruffy but rides smoothly.
Rode it home - was the first time riding a big bike!
Was really fun.
Need to get it restricted ASAP, if not I will never get round to it.
_mjs_
PostPosted: 03:59 - 10 Nov 2012    Post subject: Reply with quote
Was really fun.
Welcome to the CB500 Master Race Thumbs Up
What did you pay for it in the end?
magicman-alex
PostPosted: 13:13 - 11 Nov 2012    Post subject: Reply with quote
Great bike. I've got the same one in black. It was my first big bike too. I kept it though. Still love it!
I'd recommend getting a Haynes manual and doing a service to start with.
Also - a common fault with this bike is that the fan earth (at the top of the radiator) breaks/comes away so your fan won't kick in. It's an easy fix, you can just re-make the earth, but it's definitely worth checking. Have you tested the cooling system or had the fan come on yet?
On my bike, the fan normally kicks in when the temperature reaches the halfway mark. Overall, they run pretty cool though.
covent.gardens
World Clap Champion
PostPosted: 13:53 - 11 Nov 2012    Post subject: Reply with quote
The reg/rect is worth checking as its a common problem, its on the left of the bike under the plastic cover and looks similar to this
https://img1.jpegbay.com/gallery/000658533/1_m.jpg
If yours has "fins" then it's a replacement part, if its smooth as in the pic its original, check it for any cracks and undo the bolts to check for corrosion. If it's corroded clean it, if its damaged replace it, as the minimum a faulty one will do is murder your battery.
The sub-air filter or whatever they call it, is probably worth replacing when you have the tank off next, nobody seems to change them and they just fall to bits
Ingah
PostPosted: 21:26 - 11 Nov 2012    Post subject: Reply with quote
Not so useful to OP now he's bought it, but i would say to check all the consumables carefully. Some have been mentioned above, but just a handful of consumables will add up to a goodly chunk of the purchase price.
I would avoid high-milers that have been looked after with anything less than meticulous care - bearings, bushes and seals could well be shagged out on a bike that's got an owner that only replaces the absolute bare minimum to keep it on the road. And nothing costs money like having to pay someone else to do the labour because a nice 'easy' repair job has been severely complicated by previous owner neglect.
About regs/rects: The cheapest 3rd party replacements on eBay were, last time i checked, the ones without fins... The ones with fins are sometimes better because they are likely to stay cooler (increased surface area).
-- Ingah
cimbian
PostPosted: 22:00 - 11 Nov 2012    Post subject: Reply with quote
Do the tyres have more than 2mm of tread Wink Twisted Evil Wink
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
The last post was made 13 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 73.38 Kb
