Any welders? advice required regarding galvanised steel
grant965
PostPosted: 13:50 - 09 Nov 2012    Post subject: Any welders? advice required regarding galvanised steel Reply with quote
Hi, got a massive sheet of 1mm galvanised steel but having trouble welding it neatly.
Googled it and Im suppose to increase the heat to melt the coating but as its only thin its putting far too many holes in it.
Any ideas?
Using a cheap Mig welder BTW.
Thanks, Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
dodgydog
PostPosted: 14:10 - 09 Nov 2012    Post subject: Reply with quote
Read up on Galv flu and metal fume fever as well....it's not nice.
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
grant965
PostPosted: 14:15 - 09 Nov 2012    Post subject: Reply with quote
Ive been using one of these, are they any good?
https://image.made-in-china.com/2f0j00ZMraAvcPksbq/Safety-Face-Mask-N95-WN10-16AF-.jpg
If weather picks up Il try to do as much welding as I can outside to reduce the risk.
Blackwolf
Burgerfist
PostPosted: 14:16 - 09 Nov 2012    Post subject: Reply with quote
Yeah I wouldn't want to weld galvanised steel.
I'm not too sire if you can grind off the coating then welf but.. :/
grant965
PostPosted: 14:26 - 09 Nov 2012    Post subject: Reply with quote
hm.... its for nothing structural so can I rivet and use some silicone to seal it?
.Chris.
PostPosted: 15:31 - 09 Nov 2012    Post subject: Reply with quote
Is this on a car? If so, what type of car and whereabouts on the body?
Chris
1985 Kawasaki Z550F
PostPosted: 15:50 - 09 Nov 2012    Post subject: Reply with quote
Galvanising is only a surface effect. Grind it off and then just use normal welding proceedures.
grant965
PostPosted: 16:20 - 09 Nov 2012    Post subject: Reply with quote
for a few bits n pieces for a bike. thinking chain guard, undertray, airbox
dransy
PostPosted: 16:42 - 09 Nov 2012    Post subject: Reply with quote
Just grind the coating off , also as said above galv flu is a cunt , either do it outside or wear a mask !
Made a roof rack out of galv for my mates landy and I was unaware of galv flu ! But all I did was just grind off all the coating
Spudly
PostPosted: 16:51 - 09 Nov 2012    Post subject: Reply with quote
Ask Warped?
The Old Apprentice
passifid
PostPosted: 16:53 - 09 Nov 2012    Post subject: Reply with quote
" I personally have been able to learn from the best at the mysterious art of welding and when working with galvanised steel was always told to weld it to around four thou' "
~~ Extract from the life of the grand welder Mark Roberts
CBT: 10/2011 | Theory:6/2012 | MOD1: 8/2012
kramdra
PostPosted: 17:25 - 09 Nov 2012    Post subject: Reply with quote
those face masks will not do shit.
mig-welding.co.uk
It doesnt make any difference to the weld settings..
so learn to weld, or how to set up your cheap mig. I imagine you need to reduce wire speed and power.
power sets voltage. wire speed sets current.
Sand off the zinc coating. dont breath it in.
fredsredhat
PostPosted: 10:16 - 10 Nov 2012    Post subject: Reply with quote
funny you should mention this as im poorly sick dying from this right now! had a big day welding galv angles on thurs and friday and today i feel like proper poo. my fault as i was rushing so much i didnt turn the extractor on. as for welding the 1mm, what size wire you using? like everyone has said, grind off the coating then it'll take brill.
Ariel Badger
PostPosted: 11:30 - 10 Nov 2012    Post subject: Reply with quote
Welding outside will mean that you lose your gas shield
mistergixer
PostPosted: 12:41 - 10 Nov 2012    Post subject: Reply with quote
It'll probably be down the back of the sofa.
Space Monkey #7
The last post was made 13 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 88.79 Kb
