Help please - R6 - White/creamy substance in engine...
Blunet600
PostPosted: 14:24 - 10 Nov 2012    Post subject: Help please - R6 - White/creamy substance in engine... Reply with quote
I got my R6 out today to start her up, check her over, and admire. Turned the bike off, and took the filler cap off the engine to look inside, and i saw a creamy white substance inside! it did not smell pleasant either... so now I'm panicking.
I checked the dipstick and there is none on it, just clean oil.
I took a couple of pictures.
It sounds fine too.
Honda - Power of Dreams - NSR 125R - Hornet 600
The Artist
PostPosted: 14:57 - 10 Nov 2012    Post subject: Reply with quote
Creamy mixture is usually oil with water. Check coolant level, if it is low then it maybe head gasket. Most probably is you just do short rides/not run it in a while, it may need a good run, get the oil hot and the water should evaporate.
Just make sure it isn't your coolant leaking into the water jacket.
Quote Me Happy
PostPosted: 15:04 - 10 Nov 2012    Post subject: Reply with quote
Most likely just condensation in the oil so don't panic just yet.
janner_10
PostPosted: 15:11 - 10 Nov 2012    Post subject: Reply with quote
A good long hard ride should clear that up.
Walloper
You should have asked for one without Mayo.... Rolling Eyes
It's probably just condensation from the shitty weather. As said short rides cause this a lot where the 'whole' engine doesn't get up to running temperature for long enough to 'burn' off the moisture from combustion. Fuel is a Hydrocarbon and burning it combines the hydrogen with oxygen to make H2O. The oil washes it off the bore/s as the engine runs.
When it gets hot enough the water is blown out as steam (water as a gas).
Cold engines allow the moistur from combustion condense on cold surfaces as mist does on cold glass/motorcycle visors.
If it's all milky in there then it is not simply condesation and you need to check cooling system.
Also worth checking the drain hose for the breather is clear. Smile
Blunet600
PostPosted: 15:34 - 10 Nov 2012    Post subject: Reply with quote
I hope so... so if its going to sit out for the winter, would it be best to not start it at all? surely this condensation cant be healthy for the engine?....
Ill check the coolant to be on the safe side.
My hornet doesn't get this condensation in the engine though...
The Artist
PostPosted: 16:05 - 10 Nov 2012    Post subject: Reply with quote
I say go out for a 30min ride
PostPosted: 16:17 - 10 Nov 2012    Post subject: Reply with quote
Condensation is normal in winter, especially on bikes used for short journeys. While it isn't doing the best for the engine, starting the engine but not getting it well and truely hot will make the problem worse.
Redoko
PostPosted: 16:41 - 10 Nov 2012    Post subject: Reply with quote
Not one jizz joke.
Come on BCF, he was basically asking for it.
Mattaria
PostPosted: 17:44 - 10 Nov 2012    Post subject: Reply with quote
Redoko wrote:
Not one jizz joke.
I know right? Since when were forums full of helpful people?!
Blunet600
PostPosted: 18:20 - 10 Nov 2012    Post subject: Reply with quote
I did fully expect a endless amount of jizz jokes, but am very grateful indeed for the lack of such jokes.
- is there anything i can do about it other than take it for a long ride? ...
The Artist
PostPosted: 18:32 - 10 Nov 2012    Post subject: Reply with quote
Leave it idling for an hour should get it pretty warm, needs to get hot really though.
0l0dom0l0
PostPosted: 22:47 - 10 Nov 2012    Post subject: Reply with quote
Change the oil or take it for a long ride.
Nothing other than that though really.
KDub
PostPosted: 22:54 - 10 Nov 2012    Post subject: Reply with quote
Someone's been fucking with your bike Wink
Coat. Hat. Gone.
Walloper
PostPosted: 06:39 - 11 Nov 2012    Post subject: Reply with quote
Coat. Hat. Gone.
Yeah... I have 'come across' an engine like that before.
Hold that taxi mate...
The last post was made 13 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 86.5 Kb
