Just a couple of minor things I need help with
yaigi
PostPosted: 22:45 - 12 Nov 2012    Post subject: Just a couple of minor things I need help with Reply with quote
Hi guys, just a couple of things I'd like some help on if anyone knows anything...
Bike: YBR Custom, 2010
    1) My back brake has started squeaking. Only started in the last few days, bike has been kept outside and ridden along quite muddy roads the last couple of weeks - could this be part of the problem or are there other factors which could contribute?
    2) Clock bulbs - the rev counter one had gone when I bought the bike, but now the speedo one has gone so that's a bit annoying. I've tried looking for 'ybr clock bulbs' etc. but no luck - I'm guessing they're a common bulb for which people wouldn't feel inclined to write all it's uses, any idea what bulbs I need to get?!
Shaft
PostPosted: 23:06 - 12 Nov 2012    Post subject: Reply with quote
Brake could be almost anything, contamination, glazing, or plain worn out; only way to know for sure is take apart and check.
Instrument bulbs are typically 2w bayonet fitting, which normally translates to a serial number of 281 and can be bought in any car accessory shop, like Halfords.
yaigi
PostPosted: 00:12 - 13 Nov 2012    Post subject: Reply with quote
Awesome, thank you Thumbs Up
Shaft
PostPosted: 01:17 - 13 Nov 2012    Post subject: Reply with quote
No probs.
Actually, my XJ rear drum squeals a bit if I don't use it for a few days, but it lives outside, so it takes a few good prods to wear off the corrosion that's developed.
If the noise goes away with use and there's plenty of adjustment left, I wouldn't worry about it.
yaigi
PostPosted: 10:50 - 13 Nov 2012    Post subject: Reply with quote
I thought that could be a possibility as on my ride home last night it started off quite squeaky but by the end of the journey was much less so, and only really when I gave it a good stomp. I'll have to have a look at it as there is a chance I've sold it so I don't want to give them any reasons to come back crying.
PostPosted: 12:11 - 13 Nov 2012    Post subject: Reply with quote
Are you sure about that? They definately use them in a YBR125?
There reason I ask is you didn't seem very definate and it's been a while since I saw a motorcycle with bayonet cap lights in the instrument cluster.
I'd have expected a 2010 bike to have one of the capless, push-fit type bulbs which come in a bewildering array of sizes and wattages.
As such. You'd either want to take one out and see what type it is (it'll be printed on the bulb) or go into a Yamaha dealer and ask if getting to them is going to involve a lot of stripping down (which it shouldn't on an unfaired bike).
Matt B
PostPosted: 12:19 - 13 Nov 2012    Post subject: Reply with quote
Agreed. They look like this, and are used for some car sidelights:
https://www.fasteronline.co.uk/p/p.php?src=../images/hb501.jpg&w=600&h=600
Shaft
PostPosted: 13:04 - 13 Nov 2012    Post subject: Reply with quote
Nope, that's why I said typically, not definitely.
If it's a capless, it's probably a 504 (3w) or a 512 (2.6w), unless it's like modern car dashes, which tend to use capless bulbs with built in holders, that come in a huge variety of sizes.
TheSmiler
PostPosted: 13:49 - 13 Nov 2012    Post subject: Reply with quote
For the bulb just pull out the rubber clamp that goes into the clocks, take the bulb out and take it into the shop (car accessory or halfords) say I'm after one of these and your sorted. Had to get one myself recently as the clocks lights had gone replaced it for 10p.
Regarding the back brake I've got a similar problem but the brakes work fine no brake dust in them (drum brakes). So I've just left it gives that extra warning to motorists on the roads.
yen_powell
PostPosted: 14:38 - 13 Nov 2012    Post subject: Reply with quote
Drum brakes squeal when there is a build up of brake dust from the shoes wearing. Worth pulling the drum apart and use a damp cloth to wipe the dust out. Grease any spindles whilst you are at it. Takes a few minutes once the wheel is off.
XT1200Z and a DR350 in bits
yaigi
PostPosted: 17:53 - 16 Nov 2012    Post subject: Reply with quote
So I just discovered that Yamaha have a very handy parts catalogue on their website. It seems that the clocks have some different types of bulbs inside - six 12V-3W, and two 12V-1.7W. I can't imagine they will have all gone, would one going mean the rest wouldn't work?
They're only cheap things like but all adds up if I have to buy seven!
Shaft
PostPosted: 20:15 - 16 Nov 2012    Post subject: Reply with quote
Looking at that part diagram, there's 8 bulbs on those instruments:
5x 3w idiot lamps (oil, high beam, neutral, indicators)
1x 1.7w fuel gauge
2x 1.7w instrument illumination
The instrument bulbs are a T10 fitting (the fuel gauge bulb is smaller) which carries a generic part number of 517.
So, all you need are 2x 517 bulbs, shouldn't be more than a quid each and should be a lot less.
yaigi
PostPosted: 12:18 - 19 Nov 2012    Post subject: Reply with quote
1x 1.7w fuel gauge
Yep, I was clearly having a dumb moment, obviously it would be the bulbs of which there are only two of - one for each clock, haha.
So, I got the bulbs after shopping around a bit (everywhere was out of stock except on place in Burscough!).
Bike is now sold. Job done!
Thanks everyone! Now, if any of you are selling a Hornet for around £1400, lemme see!
The last post was made 13 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 82.64 Kb
