bike not used for 2 years, whats problems will i have?
saint gaz
PostPosted: 21:12 - 12 Nov 2012    Post subject: bike not used for 2 years, whats problems will i have? Reply with quote
hi, I have the chance of a er5 that i can use as a winter hack (once I have passed my test). The problem I have is that the bike has been left outside for nearly 2 years with little protection.
It doesnt look as bad as i thought it would and the battery is fooked.
I am a bit concerned with the tyres, they were new when it was first parked up but it hasnt moved at all, the rear one is in the air because its on a center stand but the front is on a cold concrete floor, will they need replacing? and what else will i need to check. Obviously it will need a lot of TLC and a new mot.
BUT should i leave it were it is or take a chance on it.
Mid life crisis has started,
Let the fun begin.
Honda VTR 1000 Firestorm
matto
PostPosted: 21:27 - 12 Nov 2012    Post subject: Reply with quote
It all comes down to cost in both money and time.
How much are you going to pay for it?
How much have you got to spend getting it on the road?
Have you got the time to fix it? (unless the answer to the previous question was "lots" and you are going to pay someone to fix it)
How soon would you like to be riding it?
(All these questions are rhetorical, I don't actually need the answers btw Very Happy )
However they're generally tough reliable bikes, if it runs, moves and stops then you're probably not going to bankrupt yourself fixing it.
mossi123uk
PostPosted: 23:34 - 12 Nov 2012    Post subject: Reply with quote
i bought my xj 600 after it was stood for 7 years in a garage tho and all that was wrong with that was out of date petrol and needed to get carbs cleaned cos of it
Joncrete Cungle
PostPosted: 23:46 - 12 Nov 2012    Post subject: Reply with quote
Carbs cleaned & balanced, check rubber and do tyre pressure if they are ok. New brake fluid and oil and a new battery. Fingers crossed it will start and all the bulbs still work, chain rusted to fook or will it clean and lube up? Pads might have siezed / rusted on to discs? Thumbs Up
Vracktal
PostPosted: 04:13 - 13 Nov 2012    Post subject: Reply with quote
Replace oil and coolant, get fresh petrol in it and a new battery if the old can't be salvaged, check carbs & airbox for insect nests (it happens, trust), spark plugs, brake disks/pads, lube chain, give all the mechanical controls a bit of grease or WD40. The front tyre could likely need changing as if it's not been rotated in two years it could have flatspotted.
PostPosted: 09:18 - 13 Nov 2012    Post subject: Reply with quote
The tyres will be fine. They don't flat-spot when parked up for a couple of years and they aren't affected by cold concrete or cold anything else. Brand new bikes can be stood that long before sold.
Check the oil, fit a new battery and give it a crank.
goto10
PostPosted: 10:11 - 13 Nov 2012    Post subject: Reply with quote
Let it crank with the kill switch on for a few seconds, give the oil a chance to flow around and gain a bit of pressure before it fires up.
Slacker24seve...
PostPosted: 10:55 - 13 Nov 2012    Post subject: Reply with quote
New battery and petrol and get on and ride the damn thing. Wash the cobwebs off if you must.
Banger rallies are ace
map
Mr Calendar
PostPosted: 11:32 - 13 Nov 2012    Post subject: Reply with quote
From my recent experience you might want to look at this thread.
Might be worth dropping 5 to 10cc or so clean engine oil down the cylinders via spark plugs. Once started it'll smoke but reduce chance of stuck pistons.
Watch the electrics as I've found with bikes if not used the wiring just rots. Use the bike and it's fine (go figure).
HTH Thumbs Up
saint gaz
PostPosted: 16:16 - 13 Nov 2012    Post subject: Reply with quote
cheers for all the replies guys
the front pads have siezed to the disc, whats the best way to free them and are they now goosed and need replacing?
looking like a good deal, its my brothers bike but he had a fall on it 2 years ago, got it fixed and lost his bottle. Im hoping once i pass my test and ride it he will get the urge again, but not until the winter is over and i can buy my nice shiny bike Razz
Let the fun begin.
PostPosted: 16:21 - 13 Nov 2012    Post subject: Reply with quote
Bounce it hard on the forks to free the pads. Mind you don't fall over when it frees off. There will be a horrible mark on the discs but don't worry it will soon disappear.
PostPosted: 16:41 - 13 Nov 2012    Post subject: Reply with quote
You might well find the clutch plates seized together as well. keep the front brake on when you put it in gear with the engine running for the first time.
Triumph Trophy Launch Edition
The last post was made 13 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 73.26 Kb
