Can stones cause punctures? Is my tyre dodgy?
Snorty
PostPosted: 11:55 - 15 Nov 2012    Post subject: Can stones cause punctures? Is my tyre dodgy? Reply with quote
Just pulled over to find a stone embedded in my front tyre, pulled it out and it's left a nice little hole.
Was wondering how likely they are to cause punctures?
Also, my front tyre is a bit dodgy... it seems to be that the centre of the tyre is more raised than the rest... picture to explain...
https://img94.imageshack.us/img94/1169/tyrez.jpg
Where the arrows point to the tread pattern, if you run your finger across the gap, you can feel that the rubber in the middle is higher than the rubber after the tread pattern.
This is kind of what I mean, but obviously exaggerated due to poor MS Paint skillz.
https://imageshack.us/a/img15/9650/detailsm.jpg
DrDonnyBrago
PostPosted: 11:57 - 15 Nov 2012    Post subject: Re: Can stones cause punctures? Is my tyre dodgy? Reply with quote
Hard to tell about the stone holes from a pic but the tyre profile is pretty typical of a part worn front tyre.
The edges wear heavily during cornering giving it that profile. My fronts always have the same lipping around the tread marks too.
Snorty
PostPosted: 11:58 - 15 Nov 2012    Post subject: Reply with quote
The handling feels a bit off as well.
It's a combination of absolutely shocking roads around here and perhaps the tyre, not sure though.
Basically if I'm riding and there's a bit of an imperfection, for example a thin line where they've dug it up, it throws the bike off it, so to speak. Seems to direct my bike for me, which obviously I don't want.
When I'm tipping in to the corners, the handlebars feel like they're resisting further input as well. Say I'm turning left, to tighten the corner, I want to turn the handlebars to the right, but the handlebars seem to want to turn to the left. I realise this is probably what usually happens, but since riding the CBR I am looking after, it doesn't feel quite right.
DrDonnyBrago
PostPosted: 12:00 - 15 Nov 2012    Post subject: Reply with quote
Funny wear patterns can give it funky handling but you are probably overthinking it too.
Gouges in the road do that on all bikes, it's a bit unsettling but entirely normal. The trick is to avoid riding in them.
If you are worried about it, change the tyre Thumbs Up .
mickie
PostPosted: 12:06 - 15 Nov 2012    Post subject: Reply with quote
the little bits in the tread are your wear indicators, if they stand proud of your tyre its time to get it changed.
Stone holes are normal. You'll know if one gets through the carcasse because your tyre will go flat.
The wear is also normal. You obviously have a dual/multi compound tyre. They're harder in the middle than round the edges so they don't square off too much if you do a lot of riding in a straight line.
Yours have done the opposite so you obviously corner more than the tyre was designed for. I bet it's feathering across the tread pattern too.
All that aside, it's worn out, you're down past the wear bars round the edges. Tracking along linear defects is a common effect of riding on worn out front tyres. For what it's worth, unpleasant though it might feel, it doesn't seem to cause any actual problems.
T0MMY
PostPosted: 12:23 - 15 Nov 2012    Post subject: Reply with quote
Might be worth checking your headset bearings too...if they're notchy it can feel a little like you've described.
I wouldn't say stones are that likely to cause punctures. I work on a site where the roads are covered in very sharp bits of broken gravel and I have to pick out literally hundreds of stones from my car and bike tyres over the course of a year. Only once has one gone all the way through in 4 years (that was in the car) so they can do so but it's relatively unlikely I'd say.
ZX6R + CBR600RR
Acemastr
PostPosted: 12:41 - 15 Nov 2012    Post subject: Reply with quote
Yes they can! this happened on my driveway, Pilot Road 2 on 7k miles
https://acemastr.com/tyre.jpg
2016 Toyota Tacoma Limited
DrDonnyBrago
PostPosted: 12:49 - 15 Nov 2012    Post subject: Reply with quote
There are a few fairly deep gouges roughly parallel to the road on my way to work. I assure you it happens on tyres of any condition.
Acemaster - that is cheese.
Acemastr
PostPosted: 12:55 - 15 Nov 2012    Post subject: Reply with quote
everyone says it's cheese, damn sharp cheese!
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 65.85 Kb
