| Snorty |
 Snorty World Chat Champion
 Posted: 11:55 - 15 Nov 2012 Post subject: Can stones cause punctures? Is my tyre dodgy? |
Just pulled over to find a stone embedded in my front tyre, pulled it out and it's left a nice little hole.
Was wondering how likely they are to cause punctures?
Also, my front tyre is a bit dodgy... it seems to be that the centre of the tyre is more raised than the rest... picture to explain...
https://img94.imageshack.us/img94/1169/tyrez.jpg
Where the arrows point to the tread pattern, if you run your finger across the gap, you can feel that the rubber in the middle is higher than the rubber after the tread pattern.
This is kind of what I mean, but obviously exaggerated due to poor MS Paint skillz.
https://imageshack.us/a/img15/9650/detailsm.jpg ____________________ Current: Yamaha FZ1 '07 | GSXR 750 SRAD
Past: CB125TDC | TZR125 | GPZ500 | CBR600F3 | ZX9-R | GSXR1000 K4 |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Snorty |
 Posted: 11:58 - 15 Nov 2012 Post subject: |
The handling feels a bit off as well.
It's a combination of absolutely shocking roads around here and perhaps the tyre, not sure though.
Basically if I'm riding and there's a bit of an imperfection, for example a thin line where they've dug it up, it throws the bike off it, so to speak. Seems to direct my bike for me, which obviously I don't want.
When I'm tipping in to the corners, the handlebars feel like they're resisting further input as well. Say I'm turning left, to tighten the corner, I want to turn the handlebars to the right, but the handlebars seem to want to turn to the left. I realise this is probably what usually happens, but since riding the CBR I am looking after, it doesn't feel quite right. ____________________ Current: Yamaha FZ1 '07 | GSXR 750 SRAD
| DrDonnyBrago |
 Posted: 12:00 - 15 Nov 2012 Post subject: |
| snorty wrote: | The handling feels a bit off as well.
When I'm tipping in to the corners, the handlebars feel like they're resisting further input as well. Say I'm turning left, to tighten the corner, I want to turn the handlebars to the right, but the handlebars seem to want to turn to the left. I realise this is probably what usually happens, but since riding the CBR I am looking after, it doesn't feel quite right. |
Funny wear patterns can give it funky handling but you are probably overthinking it too.
Gouges in the road do that on all bikes, it's a bit unsettling but entirely normal. The trick is to avoid riding in them.
If you are worried about it, change the tyre . |
| mickie |
 mickie Renault 5 Driver
| stinkwheel |
 Posted: 12:06 - 15 Nov 2012 Post subject: |
Stone holes are normal. You'll know if one gets through the carcasse because your tyre will go flat.
The wear is also normal. You obviously have a dual/multi compound tyre. They're harder in the middle than round the edges so they don't square off too much if you do a lot of riding in a straight line.
Yours have done the opposite so you obviously corner more than the tyre was designed for. I bet it's feathering across the tread pattern too.
All that aside, it's worn out, you're down past the wear bars round the edges. Tracking along linear defects is a common effect of riding on worn out front tyres. For what it's worth, unpleasant though it might feel, it doesn't seem to cause any actual problems. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| T0MMY |
 T0MMY World Chat Champion
| Acemastr |
 Acemastr World Chat Champion
 Posted: 12:41 - 15 Nov 2012 Post subject: |
Yes they can! this happened on my driveway, Pilot Road 2 on 7k miles
https://acemastr.com/tyre.jpg ____________________ 2017 KTM 350 XC-F - 2014 Yamaha R6 - 2005 Yamaha YZ125
2016 Toyota Tacoma Limited |
| DrDonnyBrago |
| Acemastr |
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
