turn 2 broken bike into 1 working bike
hobbit feet 82
PostPosted: 20:04 - 17 Nov 2012    Post subject: turn 2 broken bike into 1 working bike Reply with quote
hey guys i have 2 honda cbf 125 2009 models, one has blown its engine and the other has twisted falks and handle bars. im a total begginer with mechanics and i am seeking advice on what to do for the best to get one up and running bike
PostPosted: 20:08 - 17 Nov 2012    Post subject: Reply with quote
Take the forks and bars off the blown up one and fit them to the not blown up one. If you disconnect the speedo drive, wiring, clutch and throttle cables and un-bolt the bar clamps you might be able to pull out the forks from the yokes and just slide the whole front end assembly out of one set of yokes and into the other.
hobbit feet 82
PostPosted: 20:20 - 17 Nov 2012    Post subject: Reply with quote
cheers, is that easier than swapping the engines?
PostPosted: 20:53 - 17 Nov 2012    Post subject: Reply with quote
Yes it's loads easier. To change the engine you have to disconnect all hoses and wiring, cables, airbox, exhaust, sprocket cover, front sprocket (unless you can get the chain off with the sprocket on), remove engine bolts on BOTH bikes, then man-handle the engines out and one back in before re-fitting everything. Front forks just drop out of the yokes by un-doing the pinch bolts.
J0Al1
PostPosted: 21:58 - 17 Nov 2012    Post subject: Reply with quote
I think you should put down your glass of wine and get ya pink dungees on!
Rob W
PostPosted: 22:11 - 17 Nov 2012    Post subject: Re: turn 2 broken bike into 1 working bike Reply with quote
hobbit feet 82 wrote:
twisted falks
https://mavrixonline.com/mavrixonline/photos/blog_peter_falk_02.jpg
pits
PostPosted: 00:08 - 18 Nov 2012    Post subject: Re: turn 2 broken bike into 1 working bike Reply with quote
Rob W wrote:
Finally someone else, came into chat earlier asking same question, and no one got what I said when I put "Just one more question...." No one at all....
God Bless Columbo, shame he went batshit nuts and started feeding pigeons, then throwing his briefcase at said pigeons Crying or Very sad Crying or Very sad
J0Al1
PostPosted: 17:35 - 18 Nov 2012    Post subject: Reply with quote
The biggest 'issue' has been taking the bar ends off, as one was badly crossthreaded on the bent bike and resulted in a hack saw!
Plus . . . Hobbit is is still out there trying to remove the heated grips from the engine bike! Super glued apparently!
Aside that it has been relativly simple.
From what I can see the forks in the bent bike are absolutly fine! The only problem is a bent handle bar which gave the illusion of agreater issue. So £300 for a bike with a bent handle bar and some scuffs was a steal Smile
Still. . it is almost dark (we have no garage) and he has done brill.... Next weekend will put the forks and bars from engine bike on bent bike and away.
The enginer bike can become a project... take engine out.. look at damage etc.. might be worth repair and sell Smile
J0Al1
PostPosted: 17:36 - 18 Nov 2012    Post subject: Reply with quote
_Iain_ wrote:
I'd be inclined to build a working one out of whichever has the lower mileage/is newer. Simply because then it'd have a better resale value.
Engine bike has lower milage by 3k but condition not nearly as good.
hobbit feet 82
PostPosted: 19:19 - 18 Nov 2012    Post subject: Reply with quote
Engine bike has lower milage by 3k but condition not nearly as good.[/quote]
ahem, that bike was in mint condition. only crashed twice in 3 years
The world's smallest violin player, just for you!
i was looking for a snorting pig for you.
i.p.phrealy
PostPosted: 23:53 - 18 Nov 2012    Post subject: Reply with quote
so by mint you mean "with a hole in the middle" Laughing
The last post was made 13 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 84.18 Kb
