| hobbit feet 82 |
 hobbit feet 82 L Plate Warrior
| Pete. |
 Pete. Super Spammer
 Posted: 20:08 - 17 Nov 2012 Post subject: |
Take the forks and bars off the blown up one and fit them to the not blown up one. If you disconnect the speedo drive, wiring, clutch and throttle cables and un-bolt the bar clamps you might be able to pull out the forks from the yokes and just slide the whole front end assembly out of one set of yokes and into the other. ____________________ a.k.a 'Geri'
| hobbit feet 82 |
| Pete. |
 Pete. Super Spammer
 Posted: 20:53 - 17 Nov 2012 Post subject: |
Yes it's loads easier. To change the engine you have to disconnect all hoses and wiring, cables, airbox, exhaust, sprocket cover, front sprocket (unless you can get the chain off with the sprocket on), remove engine bolts on BOTH bikes, then man-handle the engines out and one back in before re-fitting everything. Front forks just drop out of the yokes by un-doing the pinch bolts. ____________________ a.k.a 'Geri'
| J0Al1 |
 J0Al1 World Chat Champion
 Posted: 21:58 - 17 Nov 2012 Post subject: |
I think you should put down your glass of wine and get ya pink dungees on!
| Rob W |
 Rob W World Chat Champion
| pits |
 pits World Chat Champion
 Posted: 00:08 - 18 Nov 2012 Post subject: Re: turn 2 broken bike into 1 working bike |
Finally someone else, came into chat earlier asking same question, and no one got what I said when I put "Just one more question...." No one at all....
God Bless Columbo, shame he went batshit nuts and started feeding pigeons, then throwing his briefcase at said pigeons  ____________________ Stinkwheel: You have no right to free speech
00:33:00 Blau Zedong: the CB400 is my favourite road bike |
| Vincent |
 Vincent Banned
| _Iain_ |
 _Iain_ Banned
 Posted: 17:05 - 18 Nov 2012 Post subject: |
I'd be inclined to build a working one out of whichever has the lower mileage/is newer. Simply because then it'd have a better resale value. ____________________ Please be aware that the above post may be full of complete nonsense.
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 17:07 - 18 Nov 2012 Post subject: |
I'd dump the frame from the bendy forks bike,too much of a risk of it being bent. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| J0Al1 |
 Posted: 17:35 - 18 Nov 2012 Post subject: |
The biggest 'issue' has been taking the bar ends off, as one was badly crossthreaded on the bent bike and resulted in a hack saw!
Plus . . . Hobbit is is still out there trying to remove the heated grips from the engine bike! Super glued apparently!
Aside that it has been relativly simple.
From what I can see the forks in the bent bike are absolutly fine! The only problem is a bent handle bar which gave the illusion of agreater issue. So £300 for a bike with a bent handle bar and some scuffs was a steal
Still. . it is almost dark (we have no garage) and he has done brill.... Next weekend will put the forks and bars from engine bike on bent bike and away.
The enginer bike can become a project... take engine out.. look at damage etc.. might be worth repair and sell
| J0Al1 |
| hobbit feet 82 |
 Posted: 19:19 - 18 Nov 2012 Post subject: |
Engine bike has lower milage by 3k but condition not nearly as good.[/quote]
ahem, that bike was in mint condition. only crashed twice in 3 years
i was looking for a snorting pig for you. |
| i.p.phrealy |
 i.p.phrealy World Chat Champion
The last post was made 13 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
