Lithium-Iron-Phosphate(LiFePo) battery winter care?
Val
PostPosted: 12:54 - 18 Nov 2012    Post subject: Lithium-Iron-Phosphate(LiFePo) battery winter care? Reply with quote
Hello,
Several questions about winter:
I've got Lithium-Iron-Phosphate(LiFePo) battery. Somewhere read that Lithium batteries are better stored not fully charged.
1. If I remove the battery from the bike and keep it in the house without charging for 3 months is that fine for the battery?
2. If I start the bike each week without riding for say 5-10 minutes does this charges the battery? My question is shall I leave the battery on the bike for 3 months doing weekly engine runs?
thanks
janner_10
PostPosted: 14:01 - 18 Nov 2012    Post subject: Reply with quote
They are best stored unused, so I would take it off the bike.
Or: https://londonbikers.com/news/25490/optimate-lithium-the-worlds-1st-lithium-ion-battery-optimiser
Which isn't cheap by any stretch.
Walloper
PostPosted: 17:17 - 18 Nov 2012    Post subject: Reply with quote
Don't start the bike for 5-10 minutes.
The engine will only get wet internally as it will not get warm enough to drive off moisture from combustion.
If you are going to run it run it until the fan comes on then switches off, give the throttle a blip or three to clear it's throat of unburned petrol (and shit) then shut it down.
Also, the energy taken from the battery for the start cycle will need to be replaced and an alternator needs a bit of RPMs to effectively charge a battery. Over 2000RPMs A figure I just plucked out of the air there..
Get an optimizer.
Good ones are not cheap but cheaper than a couple of new batteries. Smile
C-Tek are the best that I've used. And I've burned out two Optimates. And two Hien Gericke optimizers.
Val
PostPosted: 18:27 - 18 Nov 2012    Post subject: thank you for your replies Reply with quote
will remove it then and look at getting optimiser...
The last post was made 13 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 40.61 Kb
